Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-06-2008, 05:27 AM   #1
bloopsta26
Member#: 131371
05 buy my parts so
i can get my sti running
Default Need help, valve clearance? pic included
Okay so ive ran into a problem with my build. I had gotten my motor back and well ran into some things i donno if im to sure about. here is the thing..im running cosworth 272 cams with brian crower valves/springs/retainners. we decided to measure the valve lash or clearance. this is the clearance btw the valve and the cam. here is what i got. i was bored and desided to draw it up on paint lol. im not to good but here it is ....
what would you guys do? have the guy redo them or would u run it? i need alot of help and advice....
help
bloopsta26 is offline   Reply With Quote
Old 08-06-2008, 07:17 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Are you serious?
Old 08-06-2008, 07:23 AM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
unfortunately he is. I can almost hear the ticking now. Good luck looper.
MartinSTi05 is offline   Reply With Quote
Old 08-06-2008, 07:38 AM   #4
bloopsta26
Member#: 131371
05 buy my parts so
yeah im going to take it back to him but i just wanna know what people think of it
Old 08-06-2008, 09:09 AM   #5
Mechie3
Member#: 120152
I don't know much about engine building, but I thought you were supposed to measure clearances and then add or remove shims (for shimmed setups) or change the buckets (for shimless bucket setups) to achieve the proper clearances.
Mechie3 is offline   Reply With Quote
Old 08-06-2008, 09:13 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
take them back or you could just get different buckets and
do it yourself.
Old 08-07-2008, 03:47 AM   #7
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Did you torque the heads to the block before measuring them? Clearance can change when torqued down. Cosworth mentions this in their build docs.
rlavalle is offline   Reply With Quote
Old 08-08-2008, 07:36 PM   #8
charliew
Member#: 125304
This gave me the thought that maybe the thicker headgaskets from cosworth might be getting torqued and the crush is slightly different after the heads are torqued pulling the heads down more or less differently.
charliew is offline   Reply With Quote
Old 08-08-2008, 07:43 PM   #9
MartinSTi05
Member#: 145145
2006 wrx STi
A thouhght. I wonder if it would really matter that much though? I don't think the yield of the surface will change, all your doing is making a slightly thicker MLS section. I am not sure the crush properties too much, otherwise you would have mucho sealing issues on thicker head gaskets. Only the terminal layers of the laminate have a crush ring if memory serves. Otherwise the intermediate layers are simply stamped steel, with nothing other than holes punched for coolant flow.
Need 2 Part numbers, Pic included Jus Blaze Private 'Wanted' Classifieds 6 04-16-2009 10:40 AM
need local help, valve clearance problem bloopsta26 Mid West Subaru Owners Club Forum -- MWSOC 11 08-12-2008 03:15 AM
Need HELP!! valve stem question? g-man Tire & Wheel 3 11-28-2007 12:45 AM
Need help locating 22b pic going sideways in higher resolution latinskllz General Community 20 10-24-2002 09:01 AM
