Old 08-06-2008, 04:25 PM   #1
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Default Do not use the 11mm 08 sti pumps
I have had two of these pumps (part #15010aa360) fail in the exact same manner.
Excuse the large picture but it's easier to show the detail this way. Basically a manufacturers' defect is causing the pressure relief plunger to get stuck open. This will cause the car to have 0 oil pressure.
Here is the picture:
You can see the end of the pressure relief plunger through the window and the gap between the edge of the plunger and the pump housing. This has happened on two different pumps causing bearing failure in each.
This is what the relief valve should look like with no pressure on it:
I recommend the 91-94 Turbo Legacy Oil pump part#15010aa300
Drac9 is offline   Reply With Quote
Old 08-06-2008, 05:23 PM   #2
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
did both the failures occur on stock blocks?
ec2k1gt is offline   Reply With Quote
Old 08-06-2008, 05:27 PM   #3
Drac9
Member#: 9861
They were both built blocks with rods and pistons and ACL Bearings.
Old 08-06-2008, 05:27 PM   #4
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
I noticed when I had mine apart that the journal that the plunger rides on was machined kinda crappy and the plunger did not ride nearly as smooth as any of my other pumps but I thought it was just me....
I cleaned mine up and shimmed it, havent had any problems so far...
54 psi hot idle, steady 97 psi hot above 3k....
Also built block, rods, pistons, acl race bearings...
Turbo_Mike is offline   Reply With Quote
Old 08-06-2008, 05:28 PM   #5
Ace009
Member#: 70353
2004 WRX
I almost ordered one of these today, luckily the guy was on vacation
Ace009 is offline   Reply With Quote
Old 08-06-2008, 05:32 PM   #6
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
I wouldnt stop using them, they are a great pump at a great price... just take the pressure relief valve out and inspect the housing before installing it... no big deal.
(this is how widespread NASIOC hysteria starts)
Old 08-06-2008, 09:40 PM   #7
WRXINTX
Member#: 96712
sounds like some preventive care before use is required but well worth it with these pumps....
Take out the bypass plunger and polish it with 400 grit or 600 grit sand paper, then, check the hole for burrs or sharp edges...
re-install with some proper assembly lube and oil and voila, no more worries...
Thanks for letting us know this is a very potential problem if no preventive care is taken before installation!!!!
RYNO
WRXINTX is offline   Reply With Quote
Old 08-07-2008, 12:33 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
so is the plunger just hanging up? any striations or anything on the sides of the plunger or housing?
Old 08-07-2008, 03:15 AM   #9
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Pulling the pump apart, sanding it and re-assembling it sounds a little scary to me. I can't imagine the tolerances being correct. You're making more clearance which could cause the plunger to get cocked in the hole more easily.
I'll happily pay an extra $50 for the 12mm pump.
rlavalle is offline   Reply With Quote
Old 08-07-2008, 08:29 AM   #10
WRXINTX
Member#: 96712
well, obviously, the clearances are too tight, that is why they are hanging up in the hole.... I am not saying to sand it down to a nub.... I am saying just to polish any super sharp edges off of it....
HAVE YOU EVER WORKED ON an Automatic Transmission valve body??
if not, you don't understand the concept of plungers hanging up and how a light polish makes everything right.....
Old 08-07-2008, 08:30 AM   #11
WRXINTX
Member#: 96712
yep, I think that is all it is....
Or, Scrubaru just made the plunger a little too tight in the hole.....
(probably needs .001-.002 removed by polishing)
Old 08-07-2008, 11:03 AM   #12
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I just wouldn't trust my motor to the theory that the plunger is hanging up because there are some rough areas that simply need to be sanded down. Depending on the design of the plunger, too much clearance could also be the issue, hence the cocked idea.
Either way, I wouldn't hang a $2,000 to $10,000 motor's life on the thread that maybe the failures are caused by imperfections that can be sanded away. Just not worth the risk.
Old 08-07-2008, 11:08 AM   #13
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I've seen this happen on a standard STi pump (2 shims) so if you ask me it's not just limited to the 08's (not to worry you all or anything) The plunger on the oil pump that I removed from my built block that spun out all the bearings was like this. At the time I wondered if it jammed before or after the failure. The pump was full of metal so I put it down to happening after the failure.
mick_the_ginge is offline   Reply With Quote
Old 08-07-2008, 11:08 AM   #14
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
I talked to Drac9 yesterday about this in person. both cars (i was riding in one when it happened) ran perfect oil pressure when the car was shut off. then when they went to restart them the pressure was 0. it seams that the plunger gets stuck open and when you shut the car off it pump looses its "prime" and then just sucks air through the bypass hole. not sure if that make sense, but that is my take on it.
anyway, i am running one of these 11mm pumps, and i watch my pressure closely at startup. if it is fine then, i feel comfortable running it.
cnstman is offline   Reply With Quote
Old 08-07-2008, 11:29 AM   #15
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Yeah this has happened to the standard 10 mm pumps also as I had one customer this happened to and he used a brand new 10 mm pump. On any newly built motor an oil pressure gauge is really important to keep an eye on things.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 08-07-2008, 01:37 PM   #16
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Looks like I'll be running the 12mm jdm pump. I bought both 11mm and 12mm pumps to see which one wins in this debate. I guess I have to check the pressure relief valve journal of either one I'll be using.
methaddict is offline   Reply With Quote
Old 08-08-2008, 02:42 PM   #17
charliew
Member#: 125304
cnstman, your description sounds very logical. The startup check of the oil pressure seems very important.
Also polishing a piston bore is no real scientific feat. Good mechanics have been fixing problems like this forever. There is noway you could cause the plunger to hang in the bore, it's too long for that to ever happen, the only thing is it might let the pump loose it's prime a little. The idea is to polish the bore not ream it.
A easy way to polish it would be to take a 1/4 wood dowel and cut a slot in the end to hold some emory cloth and chuck the dowel in a drill and work it in and out of the bore, the burrs are probably where the hole meets the bore.
charliew is offline   Reply With Quote
Old 08-08-2008, 03:38 PM   #18
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
hmm.. so this issue is happening on brand new pumps, and not on engines that have been running the same pump for some time now?
jigga is offline   Reply With Quote
Old 08-08-2008, 03:48 PM   #19
MartinSTi05
Member#: 145145
2006 wrx STi
Keep in mind the angle cut at the end of the plunger is what does the sealing. Polishing the sides will not affect bypass flow. And as Charliew said, the piston is much to long to become cocked in the bore.
MartinSTi05 is offline   Reply With Quote
Old 08-08-2008, 03:49 PM   #20
methaddict
Member#: 159738
2004 WRB STi
Also polishing a piston bore is no real scientific feat. Good mechanics have been fixing problems like this forever. There is noway you could cause the plunger to hang in the bore, it's too long for that to ever happen, the only thing is it might let the pump loose it's prime a little. The idea it to polish the bore not ream it.
I was looking for some specific tool to polish out the bore like some type of long pipe cleaner with wire bristle that I can also attatch to a drill. I think I saw some in a harbor frieght sale ad.
Old 08-08-2008, 04:12 PM   #21
MartinSTi05
Member#: 145145
2006 wrx STi
Two words, flex hone.
Depending on what grit stones you use they can remove very little ID, while leaving a glassy smooth finish. I used to use them all the time on aluminum paintball gun barrels. I could remove under .001" and still leave an excellent finish depending on what I started with.
http://www.brushresearch.com/flex-ho...FRQEIwodxQyWrQ
Oh, and use WD-40 for your working fluid, it will keep the temp down, and prevent the stone globules from clogging with AL.
Old 08-08-2008, 04:13 PM   #22
gold rush
Member#: 90110
2004 wrx wagon
I thought these pumps lacked the belt guide needed on the newer set ups.
gold rush is offline   Reply With Quote
Old 08-08-2008, 07:07 PM   #23
methaddict
Member#: 159738
2004 WRB STi
Thanks for the info. Which one would you use for this?
Old 08-08-2008, 07:21 PM   #24
MartinSTi05
Member#: 145145
2006 wrx STi
I always used aluminum oxide hones in 600 grit on anodized aluminum paintball gun barrels. With liberal dosing of WD-40, I could get a finish that was perfectly reflective and smooth to the touch. Keep in mind though, anodizing is a rather hard coating, so the cast AL of the pump may go away slightly faster. I would say go with an 800 grit stone, and do as little honing as possible to ensure a good finish. The fine grit stones with lube do very little to change the dims of the bore. If I were not out of country now I would bust out my ID gauge and tell you what size to get. But my spare pump is over 2,000 miles away at the moment.
Old 08-08-2008, 07:24 PM   #25
charliew
Member#: 125304
I've been using the wood dowel tool for a long time and it's real easy to make. You could use some scotchbrite in it also. With a variable speed drill it will be real easy. Add a little wd40 and clean it real good when your through.
Do you think the new 08+ WRX and STI will make a good autocross car? RS_Racer Motorsports 13 06-27-2007 10:40 AM
attn: Kisabne, the condoms were over 10 years old. DO NOT USE! SubEd Off-Topic 17 07-09-2006 12:20 AM
the 99 obs and 01 wrx do not take the same filter the 99 obs and the 01 wrx do not kaisersouse General Community 20 05-24-2005 02:57 PM
Guys, If someone is in the crapper at work, do not use the stall next to them. Eric SS Off-Topic 77 07-26-2004 08:36 PM
STi Owners not using the "Subaru Owner's Manual" break in? STiLL WILL STi Forum Archive 10 06-08-2003 02:23 PM
