Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 08-06-2008, 06:21 PM   #1
BeanerMan_L3
Member#: 39665
1998 Legacy 2.5gt
Default hand brake issues on my 98 gt.
Hey guys, I have a 98 gt sedan and my hand brake does not work unless I pull it to the highest click. Any of the other settings and my car will roll..... What can I do to fix this?
BeanerMan_L3 is offline   Reply With Quote
Old 08-06-2008, 11:00 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There are two different adjustments. If you remove the center console (not all that hard, I think it's 6 or 8 screws total) you'll see where the 2 cables connect to an equalizer bar that connects to the handle. There's a threaded portion that's dual nutted (one nut with another nut acting as a jam nut) - loosen the jam nut and you can take up some of the slack, then lock down the jam nut again.
At the rear brakes, on the backs of the backing plates (so you can see it as you're lying under the car looking outwards) is an oval-shaped rubber plug. Remove that plug and inside there is a little toothed wheel that you can rotate to adjust the positioning of the shoes for the drum brake. I can never remember which way you need to go to tighten or loosen , so I just do the the trial and error bit.
The first adjustment is much easier, so I'd try that first.
Pat Olsen
Old 08-07-2008, 08:26 AM   #3
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Yup. Sounds like it just needs to be adjusted.
blackfang is offline   Reply With Quote
Old 08-07-2008, 07:52 PM   #4
BeanerMan_L3
Member#: 39665
1998 Legacy 2.5gt
Thank you very much guys for the quick response. I will try he first one as it sounds like it is alot easier.
Cost to fix the torque bind problem on a 98 GT MaddMax Legacy Forum 18 04-08-2011 02:22 AM
Lead on 5spd 98 GT wagon in MD Lee MD Legacy Forum 3 05-30-2007 11:43 PM
Bank 1 Sensor 1 on a 98 GT....... VOLTIS5 Legacy Forum 3 05-02-2006 01:43 PM
towing question on a 98 GT jslegacy Legacy Forum 11 10-20-2003 03:25 PM
Pls Help me...Check List for brake job on a 98 RS funscooby Brakes, Steering & Suspension 7 11-28-2001 07:20 AM
