Old 08-07-2008, 11:07 AM   #1
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
Question Brian Crower - Anyone running their products?
http://www.briancrower.com/
I spoke to them at length yesterday. Don't know of anyone using their parts personally but the Crower name is pretty reputable in other circles. Need to get my 02' bugeye back on the road.
For the same price I can either go with a STi complete motor swap (turbo, intercooler, ecu) or build out one of the 3 - EJ20 blocks I've had laying around the house for like 2 years. Also have a set of heads I can port. Car will strictly be used on track, NASA events, open road races, AutoX, etc...
Thoughts?
STi swap
or
Brian Crower / or other built motor
Cams - Stage 2 Street/Strip Specification
VALVE SPRING/RETAINER KIT
STAINLESS STEEL VALVES (Complete Set)
SUBARU EJ205 2.29L STROKER KIT
ACL Race Bearings
Hotrodguru is offline   Reply With Quote
Old 08-07-2008, 11:13 AM   #2
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
If you're going to build a track motor, do it with something a little stronger than an EJ205. This is something I'd ask of the Built Motor forum. I've been browsing throught there myself trying to learn some stuff. Easiest thing to do is an STi short block, upgrade the pistons and rods, throw on your WRX heads and go have fun.
Scooby921 is offline   Reply With Quote
Old 08-07-2008, 12:07 PM   #3
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Cool, didn't even know we had a built motor forum now.
Old 08-07-2008, 12:56 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes, come on over and play
Old 08-07-2008, 01:48 PM   #5
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
^^^and this man provides 1/3 of the wisdom I've managed to absorb!
Old 08-07-2008, 01:49 PM   #6
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Just get what butterz got.
TyrannoSullyRex is offline   Reply With Quote
Old 08-07-2008, 02:04 PM   #7
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
More info or a link please Sully if you have.
Old 08-07-2008, 02:31 PM   #8
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
http://forums.nasioc.com/forums/show....php?t=1532987
Old 08-07-2008, 02:35 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
i dunno jack about cams (for now) but have you looked into gsc cams?
results from topspeed with the gsc s2 cams: http://forums.nasioc.com/forums/show....php?t=1456543
Old 08-07-2008, 03:56 PM   #10
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
most cams push the power band into the higher rpm range. This is fine for a track car, but not really what you want for an autocross car. I have a feeling the OP will do more track than auto-x though.
Old 08-07-2008, 04:10 PM   #11
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
That is correct, AutoX will just be for fun. Will mainly be a road racing application.
Old 08-07-2008, 04:40 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
then you should see your other thread for some build considerations. Its just food for thought though.
Old 08-07-2008, 04:55 PM   #13
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Sweet, thanks for the info on the other thread.
Old 08-08-2008, 08:44 AM   #14
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Moved the thread for ya.....Good Luck
Old 08-08-2008, 09:24 AM   #15
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Could probably lock this one...OP started a separate thread in the correct forum already.
Anyone running their CAI with the fog light cover off? treksofar Normally Aspirated Powertrain 3 06-05-2009 12:28 PM
Brian Crower - Anyone running their products? Hotrodguru Built Motor Discussion 25 09-18-2008 08:02 PM
