Old 08-07-2008, 11:45 AM   #1
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Default Question on cyl Sleeving
Hi i had my block built 257 je pistons etc. i am thinking of having it sleeved. do i need to purchase different size pistons? thanks.
DemiSlayer is offline   Reply With Quote
Old 08-07-2008, 12:06 PM   #2
Dom'sGurl
Member#: 150837
2006 Legacy GT
if you buy the correct size sleeves, no.
After install, the sleeves still need to be bored and honed to match your pistons.
Dom'sGurl is offline   Reply With Quote
Old 08-07-2008, 12:23 PM   #3
DemiSlayer
Member#: 120339
02 WRX
Thank you. do you happen to know the info for the correct size?
Old 08-07-2008, 12:32 PM   #4
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Sleeves the slightly smaller than the pistons you have in there so you can bore match each hole to a piston. You probably have 99.5 or 100mm pistons so don't get 102mm sleeves. Better yet, ask your builder, he's the one that will be doing the machine work.
Old 08-07-2008, 12:35 PM   #5
DemiSlayer
Member#: 120339
02 WRX
I will at lunch. Thank you for your response!
Question on cyl misfire: CEL P303 P301 p3Ch4 Service & Maintenance 5 12-24-2009 12:04 AM
Question on 207 Cyl wall 02WRXNY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-11-2008 06:59 PM
Question about cyl. walls and motor. ASPEN06 Built Motor Discussion 2 03-02-2007 10:12 PM
Egt question, 3rd cyl on manifold, also graham my greddy type s GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-06-2004 10:24 PM
Piston failure on Cyl #1 looks like...... silverscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 02-13-2003 08:18 PM
