Old 08-07-2008, 12:11 PM   #1
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
Default Brian Crower - Anyone running their products?
http://www.briancrower.com/
I spoke to them at length yesterday. Don't know of anyone using their parts personally but the Crower name is pretty reputable in other circles. Need to get my 02' bugeye back on the road.
For the same price I can either go with a STi complete motor swap (turbo, intercooler, ecu) or build out one of the 3 - EJ20 blocks I've had laying around the house for like 2 years. Also have a set of heads I can port. Car will strictly be used on track, NASA events, open road races, AutoX, etc...
Thoughts?
STi swap
or
Brian Crower / or other built motor
Cams - Stage 2 Street/Strip Specification
VALVE SPRING/RETAINER KIT
STAINLESS STEEL VALVES (Complete Set)
SUBARU EJ205 2.29L STROKER KIT
ACL Race Bearings
Hotrodguru is offline   Reply With Quote
Old 08-07-2008, 12:55 PM   #2
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Why not go stage three if you're doing track only? Not enough down low?
I will have BC stage 3's in my daily in a couple of weeks (with any luck!)
Good luck with the build!
Jpizzzle is offline   Reply With Quote
Old 08-07-2008, 02:03 PM   #3
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Yeah in speaking with BC, they recommended stage 2 cams for road racing applications.
Old 08-07-2008, 02:18 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if you really want to go that route...get EJ257 block cases first. May as well spend a bit more for added bore...the 2.29L is also only when you have 96mm bore...needs sleeves to do that.
he also includes ACL bearings with his stroke kits...not that I ever deal with him
I like his stuff but am not a fan of stroker motors unless using them for auto-x, tight hill climbs and/or tight road course driving (small driving parks)...
Old 08-07-2008, 02:33 PM   #5
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I am running BC valves, springs and retainers in my EJ255. Their cams were not released yet so I have Cossie 278/274 cams to go with it. I wish I could give you my feeling on them but the car is being very uncooperative at the moment and is refusing to be tuned.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 08-07-2008, 02:51 PM   #6
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
-Rene
Hehe, good enough. Give me an update if she's ever tuned properly.
Old 08-07-2008, 02:52 PM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
why? just curious
Hyper is offline   Reply With Quote
Old 08-07-2008, 03:44 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
if you are drag racing, road course or any other motorsports where you use your engine predominately higher rpm's a short rod ratio engine (stroker motor) has a higher frictional loss and increased wear on the piston and rings when compared to a longer rod ratio motor because or rod angularity. Also the longer rod ratio has higher VE's (torque curve put simply) because of how it makes the piston dwell in the engine. The longer rod also has less stress on rod bearings, crank, rod, piston and wrist pin (at the same given rpm) because of lower acceleration rates on the piston. That allows a higher rpm to achieve the same internal stresses (assuming masses are the same). Also doesn't require clearancing your block (added machining and decreased block strength) and increasing harmonics in the crankshaft (vibrations to eat bearings on that weakened block). Also has more dwell at TDC allowing for more accurate timing control and prevention of detonation (more free CR or boost )
On my engine, my 4" pistons are only 6 grams heavier than a JE 100mm slug but I have a higher CR and thus more material...so done properly the long rod has quite an advantage over a stroker...also 4" has a much better ring package.
advantages of a stroker though is the same air flow can occur at a lower rpm, decreased lag (if you race out of your powerband). It will always have some instant "punch" over the long rod (hence the tight course advantage).
But to see more discussion, before I kill this thread, there is a long rod discussion thread
I think it has been stickied up at the top of this forum under "Great links" (I think)
Old 08-07-2008, 03:57 PM   #9
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I'll look for it, but thanks for good read
Old 08-07-2008, 04:56 PM   #10
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Yeah great stuff, checking out the stickies now.
Old 08-08-2008, 01:58 PM   #11
brcewane
Member#: 63990
Flat Grey
BC 272 cams, Springs, retainers in my EJ20 Heads (no porting) mated to an 05 STi shortblock (stock) with a Deadbolt TD06H-20G, 800CC injectors, Mega MAF, FMIC.
It is being tuned as we speak today.. should have some results by end of day today.
brcewane is offline   Reply With Quote
Old 08-09-2008, 08:30 PM   #12
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Sweet, I'll look forward to the update.
Old 08-10-2008, 09:01 AM   #13
brcewane
Member#: 63990
Flat Grey
Turns out the heads didn't get back from the machine shop until mid afternoon on Friday, so the engine was just going back together then...
Hopeful for a pickup time of end of day Monday.
Old 08-14-2008, 03:58 PM   #14
ellissti6
Member#: 170034
does anyone know if the brian crowers would drop right into some non avcs heads sti ver6 ?
ellissti6 is offline   Reply With Quote
Old 08-14-2008, 04:22 PM   #15
el tekk-O
Visiting NASIOC Timeout
Member#: 65223
2002 WRX-6 speed
130000 miles
hmmm i need to build my engine too
sup hotrodguru
share your info with me
el tekk-O is offline   Reply With Quote
Old 08-14-2008, 04:28 PM   #16
brcewane
Member#: 63990
Flat Grey
Cams are in and running strong... I'm waiting to get some more accurate dyno readings before posting the results.. Dyno Dynamics that it was on was calibrated for a 6-speed instead of the 5-speed for readings.
Old 08-14-2008, 04:59 PM   #17
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You would have to modify them just like any other AVCS cam you tried to run in a non-AVCS head.
Old 08-14-2008, 05:12 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
his EJ205 cams are drop in require no modifications...the lob is actually the same between both cam sets (or was when they were first designed)...
Old 08-14-2008, 05:24 PM   #19
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Will be waiting, car is sitting on a trailer in my driveway in need of a leak down test
-Rene
Old 08-14-2008, 05:35 PM   #20
el tekk-O
Member#: 65223
2002 WRX-6 speed
130000 miles
what does this mean?
"Note: Intake camshafts are setup for non AVCS operation. If running AVCS, you must completely remove the four set screws located in the front of each intake cam (dowel pin side) using a 2.5mm Allen wrench. This will allow oil to actuate the Active Valve Control System."
http://www.briancrower.com/makes/subaru/ej257.shtml
Old 08-16-2008, 01:52 AM   #21
sorrowfulkiller
Member#: 170439
I <3 Lamp
I would use brian crower stuff
my buddy has an evo 8 with an evo 9 turbo, aem ems, 272 bc cams, tbe and running e85 with about 420 hp to the wheels.
The cams are really what make that engine
sorrowfulkiller is offline   Reply With Quote
Old 08-27-2008, 10:22 PM   #22
mmmRex21
Member#: 149403
2005 Wrx
Grey
does anyone know if i can just drop bc 272 cams in my ej20 without getting a valve job done? ive already installed them and talked to BC and they told me it was just drop in with stock springs/retainers/valves. just wanted to get a second opinion. and also see what kind of difference in power people are getting out of these???? i would like to start my break in period, but subaru dealer takes forever to get in the parts i need. oh yea anyone know where the engine break in link went? i cant seem to find it.
mmmRex21 is offline   Reply With Quote
Old 08-27-2008, 10:54 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
you just did cam work right? or a new motor? cam break in is different from engine break in...
I know the BC cams aren't too aggressive but I wouldn't run on factory springs. Just asking for trouble in my book.
Who did you talk with at BC? Dustin? Brian?
Old 08-27-2008, 11:02 PM   #24
mmmRex21
Member#: 149403
2005 Wrx
Grey
i did race bearings and cams. pretty much a whole rebuild of my motor with stock parts sadly except for the bearings and cams. i hate being a broke soldier haha. how should i go abut engine/cam break in for the first start up? i found cobbs procedure. should i just go by that and use reg oil then switch to synthetic after 1k miles? and how soon after 1k miles can i go up to 18.5psi street/22-23psi strip w/alky injection to go get tuned???
Old 08-27-2008, 11:04 PM   #25
Homemade WRX
Member#: 33782
96 bastard child
Yes, Jeremy's (cobb's) break in procedures are actually quite good and very detailed. Follow them and you shouldn't have an issue.
Anyone running their CAI with the fog light cover off? treksofar Normally Aspirated Powertrain 3 06-05-2009 12:28 PM
Brian Crower - Anyone running their products? Hotrodguru Built Motor Discussion 14 08-08-2008 09:24 AM
