Old 08-07-2008, 01:54 PM   #1
WRBEJ257
Member#: 185764
06 大集
青い
Default Lock/Unlock Beep stopped working
So a few months ago the awesome beep sound that you hear when you unlock and lock your car stopped working on my WRx. I tried the lock button 3 times and it would sometimes work now it just stopped completly. has this happened to anyone else?, if so HELP!
WRBEJ257 is offline   Reply With Quote
Old 08-07-2008, 02:14 PM   #2
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
PPG's,Polka pickled,ewg
Yes it happened to me a few months after I got my 06 wrx..it works randomly every once in a great while but is now silent the majority of the time.. I never looked into it because as long as the doors still lock and unlock it wasn't a big concern at the time.
blazzin06wrxdude is offline   Reply With Quote
Old 08-07-2008, 03:03 PM   #3
Benhart21
Member#: 149617
Did you maybe accidentally hold both buttons down at the same time? That enables and disables the chirp
Benhart21 is offline   Reply With Quote
Old 08-07-2008, 03:12 PM   #4
WRBEJ257
Member#: 185764
06 大集
青い
I could have done that, Ill see.....nope nothin,
i think ill run by the dealership and see if I just have to replace a fuse or something simple like that.
thanks for your help
Old 08-07-2008, 03:23 PM   #5
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
PRess and hold both buttons on the remote for about 5 seconds or until the chirp comes back. All doors have to be shut and the vehicle has to be unlocked
RexyGirl is offline   Reply With Quote
Old 08-07-2008, 04:01 PM   #6
WRBEJ257
Member#: 185764
06 大集
青い
AH HA rexygirl solved it
thank you very much
Old 08-07-2008, 04:37 PM   #7
DapRex
Member#: 53308
2004 Impreza Wrx
the bestest colour
There is also Valet mode, which I did a few months back on accident, it where the lights stop flashing and the chirp goes a way.
I had to lock the doors with the driver side door open. or something
nevermind you fixed it.....
DapRex is offline   Reply With Quote
Old 08-07-2008, 04:49 PM   #8
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
still doesnt work for me hahah.. lights just flash
SUBYDOODIE is offline   Reply With Quote
Old 08-07-2008, 04:58 PM   #9
WRBEJ257
Member#: 185764
06 大集
青い
VALET MODE... go on?
im intrigued
after I held the two buttons for awhile I pushed lock about 3 times then it stared working for me
Old 08-08-2008, 03:48 AM   #10
Propaganda Panda
Member#: 149735
2007 2.5i
urban grizay
Mine has done this as well... Will be trying these tricks in the morning
Propaganda Panda is offline   Reply With Quote
Old 08-08-2008, 03:33 PM   #11
RexyGirl
Member#: 63616
with mods :)
All of this is in your owners manual
Valet mode is just that.....when you don't use your remote to open the door and use the key only. It keeps the alarm from going off when using the key to open the door.
To activate valet mode, open the drivers side door and press unlock on the remote for a few seconds. THe security light on the dash will start to blink. You can now open the car with the key only....to disable, repeat the same steps. The lights will not flash though.
To turn the beep/chirp on/off when locking or unlocking the doors, make sure the car is unlocked and all the doors are shut. Press and HOLD both buttons on the remote until the horn/chirp sounds one time. Now, when locking or unlocking the doors, the horn/chirp will sound. To turn it back on, do the same thing. You shouldn't have to press it 3 times for it to sound. When you press it 3 times and it goes off, the alarm is telling you "dippy, I am already locked/armed"
Old 08-08-2008, 09:47 PM   #12
XmikeX
Member#: 184768
05 WRX
toasted white
you can also look on the back of the remote and it tells you in little writing what each thing doies. like press unlock then hold both buttons to make it chirp or not chirp. you can also set the alarm of this way. sweet to do to people who are standing near your car looking at it.
XmikeX is offline   Reply With Quote
Old 08-08-2008, 09:55 PM   #13
RexyGirl
Member#: 63616
with mods :)
Not all remotes are like that...the older ones didn't have 'explanations', but yes, you can set off the alarm by pressing lock on the remote and holding it. (the old-fashioned vehicle finder...)
Old 08-09-2008, 12:16 AM   #14
ganker
Member#: 131941
05 WRX
my car is just locked and cant' open it with key/remote.... can anyone help
ganker is offline   Reply With Quote
Old 08-09-2008, 01:48 AM   #15
Propaganda Panda
Member#: 149735
2007 2.5i
urban grizay
Tried to reactivate the chirp beep thing today, and no dice. all 4 doors unlocked and closed, I held both buttons for 5 seconds, then 10 seconds, kept trying, and nothing. Maybe a loose wire? Every once in a while, it will beep when I lock or unlock...
Old 11-11-2008, 09:55 PM   #16
sharpe
Member#: 160784
02 wrx
so is there a way to get the lights to flash again? i had success at turning off the chirp...but would like it if the lights flash to let me know it is locked or unlocked.
never mind...just found it i think...going to check to see if it is in valet mode.
sharpe is offline   Reply With Quote
Old 11-11-2008, 10:02 PM   #17
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
prob a blown fuse in the park light wire from the alarm. Usually its a white wire with a 10-15amp fuse)
06AZREX is offline   Reply With Quote
Old 11-11-2008, 10:02 PM   #18
sharpe
Member#: 160784
02 wrx
bingo!
Old 11-17-2008, 06:43 PM   #19
oogiesfaded
Member#: 172402
2007 impreza 2.5i
urban grey
mine went out, under warrenty at the dealer. took them hours to replace. but it works great now.
oogiesfaded is offline   Reply With Quote
Old 11-17-2008, 09:50 PM   #20
nixgame22
Member#: 101219
It's not the buttons. It's the actual chirper itself. There's two wires inside that "always" break at the soldering point from continued vibration of the vehicle. The wires are very tiny, and have a crap soldering job, and bumps will break the soldering point, rendering a useless chirper.
There's a HUGE thread here, too lazy to search, acknowledging this issue, and one member decided to open up the chirper-module, and re-solder the connections, and it worked. so, I opened up mine and re-soldered the two wires to their places and mine now works again.
nixgame22 is offline   Reply With Quote
Old 11-18-2008, 02:41 AM   #21
Jowie
Member#: 193291
2009 WRX Sedan
Here's the post with the fix:
http://forums.nasioc.com/forums/show...&postcount=410
Jowie is offline   Reply With Quote
Old 11-18-2008, 08:51 PM   #22
almostJDM
Member#: 163239
2013 STI
omg woot just fixed mine after it hadnt worked for a few months, i finaly got around to figureing it out, YAY!!!
almostJDM is offline   Reply With Quote
Old 11-18-2008, 09:45 PM   #23
bikergreen
Member#: 192157
04 BMW 325xi Wagon
Grey
Smile
Originally Posted by Jowie View Post
Unreal!! I have been having this problem as well so annoying when you don't get the beep to confirm lock or unlock!! I'm am going to pull out my beeper as I am sure that is the problem as it works randomly!! thanks so much for starting the thread I wasn't quite at that point yet and would have most likely spent way to much money on a new one from the dealer!!
bikergreen is offline   Reply With Quote
Turning off the Lock/Unlock Beep jcoble Newbies & FAQs 8 11-25-2008 05:16 PM
lock-unlock beep highvoltage Mid West Subaru Owners Club Forum -- MWSOC 19 02-12-2008 05:47 PM
How to disable remote lock/unlock horn beep? Aken Legacy Forum 12 04-09-2005 12:45 PM
Any way to make the keyless lock/unlock beep/flash instead of honk? Butt Dyno Car Audio, Video & Security 6 03-25-2003 01:50 AM
