Old 08-07-2008, 07:39 PM   #1
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Default 2.0L to 2.5L Shortblock Build/ Turbo Options?
Long story short my 2.0L shortblock is done and I am going with the following:
2.5L Shortbolck (EJ25)
Kelford Cams
CP Pistons
Cosworth Headgaskets
Valve Springs
Head Studs
Oil Pump
Walburo 255 Fuel Pump
Perrin TMIC
Perrin Turbo Inlet
DW 660CC or 750CC Injectors
I am unsure of which turbo to get, as all my research has been for 2.0L and I need to make a decision ASAP. I was reading that an 8cm turbine housing was better for the 2.5L, as it helps against boost creap (is that true?).
So I was thinking either:
Big Evo III 16G w/ 8cm turbine housing or
18G w/ 8cm turbine housing
This car is my daily driver, and I autox occasionally so lag is a concern. My goal is around 300whp with a conservative/safe tune, but I don't really care about HP #'s, just want it fun to drive. Also, my tranny is stock '05 Tranny, I don't drag, launch too hard, or generally shift like an ass, but don't want too much power to grenade my tranny. So???
csmithwrx'05 is offline   Reply With Quote
Old 08-07-2008, 07:54 PM   #2
Endymion
Member#: 91595
Be wary of buying an FP. Blouch Dom 2.5 or 3 would get my cash with your setup.
Endymion is offline   Reply With Quote
Old 08-07-2008, 08:01 PM   #3
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
I am planning on Blouch. But, the DOM 2.5 is way more turbo than I need or even want. I'm looking for a max of 350whp and will be very happy with low 300s. It would be too easy to grenade my tranny with a Dom.
Old 08-07-2008, 08:58 PM   #4
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
one thing i would look at...
make sure the CP pistons are matched to the cyclinder heads of the non AVCS 2.0 motor... the normal sti piston design is specific for the ej257 head.... not the 2.0 head... crawford offers pistons that match the combustion zone of the head
i believe these are the pistons...
http://store.crawfordperformance.com/store/products/27
All4bSpinnin is offline   Reply With Quote
Old 08-07-2008, 09:12 PM   #5
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
IC. I will talk to my mechanic. Getting everything done at Machines Gone Wild in Kendal, FL. I have heard good stuff about his work and I don't have the sizes/numbers on the Pistons or the cams yet, as he said he was going to call CP and Kelford to get the right sizes for my setup.
Old 08-08-2008, 12:25 AM   #6
urfsin
Member#: 128975
2005 Outback XT
Golden Thunder
If you want a good auto-x / street turbo, don't go with anything over a 20G.
urfsin is offline   Reply With Quote
Old 08-08-2008, 11:50 AM   #7
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
APS SR30 sounds to be the turbo you are looking for. Slightly better flow than the VFxx turbos so you will be right in that near or slightly above 300 whp range and will have full spool by 2750 rpm. Full ball bearing spool from hell, it makes the turbo cars feel near NA. Fun Turbo for sure.
Stames_wiltz is offline   Reply With Quote
2.0l to 2.5l swap, and what AVCS means to you keaniegenie Built Motor Discussion 56 04-05-2011 06:11 PM
2.0L to 2.5L Swap in progress. Motor/trans at same time? uberspeed Subaru Conversions 6 12-10-2010 11:27 PM
Carrying an 18G from a 2.0L to 2.5L wrx...worth it? subenerd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 11-14-2006 05:28 PM
2.0L to 2.5L short setup: Dyno session questions? MarylandEcstasy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-02-2006 12:54 AM
2.0L to 2.5L Wrx Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-08-2002 10:42 PM
