Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 08-08-2008, 01:29 AM   #1
toxin
Member#: 51259
2007 WRX
СGM
Default not hitting target boost, or boost reading is not accurate?
Hi everyone,
so, I have Stage 1 91oct. now, no engine or exhaust mods. I did a couple of 3th and 4th gear pulls on an open road and from the AP live data readings, we were seeing boost levels peaking at 9 PSI. WTH(?) Could it just be a non-accurate reading from the AP live data or it should be a boost leaking? I do not have the boost gauge to verify the AP reading. (AP live data shows boost from -11 psi on idling engine to 9 psi)
Still, the "butt feeling" is that car is running pretty much OK and better then stock.
So, I'm what to do?
Should I try to adjust the boost system mechanically? If so, how can I do that?
Appreciate your inputs guys.
Anton.
toxin is offline   Reply With Quote
Old 08-08-2008, 11:37 AM   #2
KevinG
Member#: 146091
14 Mazda 3
Red
if you have any buddies w/ a wrx/sti try the boost reading's in their car.
other than that do a ECU reset (with a full tank of good gas) and then let the car idle for 5 minutes without driving anywhere...
you might have had a bad tank of gas and the ecu is pulling timeing and stuff.
KevinG is offline   Reply With Quote
Old 08-24-2008, 02:41 AM   #3
efaroh
Member#: 166947
2006 WRX Sedan
Crystal Gray Metallic
i'm also not hitting target boost. i have the stock lamco boost gauge showing peak boost at .08 Mpa which is about 12 psi. I'm not hitting the 14.8 psi target boost level that Cobb says I should be hitting. What could be causing this underachieving condition?
a) helix catted dp is lesser flowing than cobb catted dp?
b) boost leak? (can't detect it anywhere)
c) wastegate acutator arm needs to be adjusted? how common is this?
efaroh is offline   Reply With Quote
Old 08-24-2008, 03:45 AM   #4
mostasz
Member#: 170512
2012 WRX
Ice Silver
Guys, remember!
Stage 1: Target is 15 PSI +- 0.7 tapering down to 12 PSI
Stage 2: Target is 16.5 PSI +- 0.7 tapering down to 13 PSI
Target boost level is peak level, that happens only sometimes under specific conditions. It all depends on temperature, air pressure and many other conditions.
Highest pressure I've seen on my Stage 2 was about 16 PSI, on 5th gear, accelerating with open throttle, when temp was about 60 degrees. Usually getting bit less when its hot outside.
mostasz is offline   Reply With Quote
Old 08-24-2008, 08:16 PM   #5
Rapp144
Member#: 39806
2003 WRX
BLK
9 psi is mechanical boost. If you have a friend with a WRX or a STI borrow his/her OEM EBCS to see if you have premature failure of the EBCS.
Or do as keving suggested, do an ecu reset and see if boost returns...get a better tank of gas. I've had to switch stations (same company) once, so far, for bad gas.
Rapp144 is offline   Reply With Quote
Old 08-24-2008, 08:22 PM   #6
WRXislander
Member#: 50064
'02 WRX
MBP
What's your altitude? You loose 1lb per 2000'
But that sounds messed up--too low. In fact, maybe I'm getting bars and lbs mixed up but that vacuum doesn't sound right either.
WRXislander is offline   Reply With Quote
Please help, not hitting target boost, rather yet stock boost either nexxus_01 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-22-2007 06:19 PM
boost fluctuations, not hitting target boost! SILVERHKSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-17-2005 09:23 AM
AP stage 1 not hitting target boost line Engine Management & Tuning 8 02-20-2005 10:27 PM
Not hitting target boost, what could be wrong? rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 10-14-2004 05:00 PM
Not hitting target boost after an installation :( rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-15-2004 02:07 PM
