Old 08-08-2008, 10:13 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Normal to hear Internal Wastegate?
So I turned the boost up towards 18psi this morning and went for a quick jaunt near some school zones to see if everything was kosher and check for more smoke and oil leaks.
Previously, @ 12-13 psi, no noise when the set boost was hit.
But now?
Seriously, it sounds ALOT like an EWG! I let off the pedal at first cause I thought something broke. But then I did it a few more times and bingo, evertime I hit targeted boost, the internal wastegate was LOUD.
gt30 turbo.
Old 08-08-2008, 11:17 AM   #2
dmross
Member#: 2818
2000 2.5RS
Sure you don't have an exhaust leak?
dmross is offline   Reply With Quote
Old 08-08-2008, 11:45 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Pretty sure, as it only happens once targeted boost happens. But I havent looked under the hood since I got back to the shop.
Old 08-08-2008, 12:57 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Internal WG...GT30? What turbo is this? Just curious, since this also impacts your other thread about smoking on throttle lift.
flycaster is offline   Reply With Quote
Old 08-08-2008, 02:24 PM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
While it may not be a true gt30, when I purchased it I measure the both wheels inner and outer spec and compared them to the garrett side and thats what it match 100%. It has a "Precision" exhaust housing.
Old 08-08-2008, 05:58 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
[edit] You just answered my question in the other thread - it's a journal bearing CHRA. Knowing that, disregard my comments on the oiling problems since they don't apply.
Old 08-09-2008, 03:08 AM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Might be a boost leak, I only hear it in 3rd....
Testing testing testing.
Old 08-09-2008, 05:48 AM   #8
norbs
Member#: 135787
Yeah, when I had my motor rebuilt I set the boost to 10PSI during run in. After a weekend of driving, it developed a noise just as you describe. On boost, loud wastegate noise. I new this because I adjusted the boost to a higher threshold and the noise come on later i.e more boost, and was more faint. Now that motor is run in, boost is set to 16psi and no more noise. Haven't bothered investigating as am waiting on a new turbo anyways. Perhaps running it at 10PSI overworked the wg??
norbs is offline   Reply With Quote
Old 08-10-2008, 03:37 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I ran it tonight @ the track and "compensated" for the boost drop by turning up the boost......
Then last run it didnt leak and boost jumped to 30+ psi and and an intercooler hose blew off.
So I called it a night.
I am pressure test sections of it and have found quite a few pinhole leaks, nothing major. But I did find one LARGE leak which I thought I fixed before I went out. A section of straight pipe connecting to another section is leaking. Weird. Fix it tommorrow.
Is it normal to hear the sound like water dropping inside car? mizh Water/Methanol Injection, Nitrous & Intercooler Cooling 10 10-20-2006 12:49 PM
Is it normal to hear noises when "engine braking" SinisterMinister Transmission (AT/MT) & Driveline 6 08-28-2005 01:32 PM
Normal to Hear? Alxaguiar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-23-2002 03:09 AM
Is it normal to hear the brakes engage under normal braking conditions? Robmat Brakes, Steering & Suspension 0 09-13-2001 01:01 PM
Is it normal to hear the brakes engage when.... Robmat Brakes, Steering & Suspension 2 07-08-2001 10:41 AM
