Old 08-08-2008, 10:53 AM   #1
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
Default New downpipe, new noises...concerned.
I installed an Invidia V2 DP last Sunday, used my Cobb APV2 and reflashed my base map to the stage 2 93 oct. (cat back is from a 05 STi with 2.5 id) .I've been driving it for a week now, and I'm loving everything except the noise. Maybe I'm just not used to it. Due to the fact that that it is a tubular DP I'm hearing all of the turbo noise. But I only hear it at lower rpm's and when my boost gauge is on the vacuum side (10 in/vac). It sounds like the exhaust gasses causing turbulence against the vanes of the turbo.
I checked all of the exhaust mating points...turbo to DP, DP to center pipe and CP to axel back and they are all tight and leak free.
Is it normal to hear all of this turbulence while the exhaust gasses start to spool up the turbo? Once the turbo gets going and the boost picks up to the positive side the swirling turbulence noises dissapate.
2subiesinyard is offline   Reply With Quote
Old 08-08-2008, 10:58 AM   #2
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
You're probably just hearing the wastegate flutter. It kinda sounds like a helicopter right? It's perfectly normal.
ammo0000 is offline   Reply With Quote
Old 08-08-2008, 10:59 AM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
^^ That's a great analogy, and I think that is in fact what he's hearing.
Audiosavvy is offline   Reply With Quote
Old 08-08-2008, 11:03 AM   #4
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
yeah thats what it is man. im having issues with it as well and have been since i instaled my invidia v3 on my02. it does sounds kinda goofy though ha. im pretty positive that ive got a leak right off of the turbo but cant find it as the bolts are all tight. im eventually going to just get some rtv and put a seal around it and clean it up and see if that takes care of it...but im lazy
resideinva is offline   Reply With Quote
Old 08-08-2008, 11:05 AM   #5
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Just step on the gas and the noise goes away
Mavrik is offline   Reply With Quote
Old 08-08-2008, 11:38 AM   #6
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
It's not an "issue". It's perfectly normal. If you're concerned about an exhaust leak at the turbo, pull off the heat shield and look for black soot on it. If there isn't any, then there's more than likely nothing wrong. Also, I would advise not to put RTV on your exhaust. It'll likely just burn off and possibly catch something else on fire.
Old 08-08-2008, 12:21 PM   #7
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
I checked for a leak at all flanges. No soot ...all bolts/nuts tight. I took my time putting the DP on, about 3 hrs in the driveway. The wastgate flutter explaination sounds like what I hear. After I lift off the gas pedal it "bleeds off", but it's as loud as a normal conversation.
Should I be hearing wastegate flutter when my wastegate duty cycles are 0???
and I agree, no rtv at the flange...NO WAY!
Old 08-08-2008, 01:20 PM   #8
BaNaNaS
Member#: 171902
2004 WRX Sport Wagon
PSM - Stg 2
check out youtube and watch some in car pulls of stage 2 cars... see if your car sounds similar.
BaNaNaS is offline   Reply With Quote
Old 08-08-2008, 01:43 PM   #9
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
^^^^^ I will, good idea thanks.
Old 08-08-2008, 01:50 PM   #10
subenerd
Member#: 72630
2004 STi
Whooshing air noise is normal with a big free flowing exhaust. My 4" TurboXS downpipe makes crazy whooshing and tea kettle whistling noises - its pretty cool
subenerd is offline   Reply With Quote
Old 08-08-2008, 02:54 PM   #11
Ranyart
Member#: 152897
2007 WRX, FXT
Same downpipe here, sounds pretty much like this. Now if it sounds like "angry bees in a tin can" it might be an exhaust leak after the DP.
Ranyart is offline   Reply With Quote
Old 08-08-2008, 04:24 PM   #12
jalm111
Member#: 119074
2008 STI
Same here. Wastegate flutter is what you're hearing OP. It's normal, I got used to it and don't even really notice it anymore. Every now and than a friend will get in the car with me and say that something's not right because of the noise....
jalm111 is offline   Reply With Quote
Old 08-08-2008, 04:28 PM   #13
Glenn Hough
Member#: 111276
2009 07 SWP WRX Wag
and 09 SWP Forseter XT
Wastegate flutter. Just like everyone else has already said. Search for it, and read up. We've all been there.
Glenn Hough is offline   Reply With Quote
Old 08-08-2008, 04:30 PM   #14
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I can't hear it over the screaming from the passenger seat anyways
Old 08-08-2008, 09:41 PM   #15
Stivie
Member#: 162845
2007 Audi RS4
2008 CBR 1000rr
I like how this man thinks
Stivie is offline   Reply With Quote
Old 08-08-2008, 09:43 PM   #16
obsti2
Member#: 174278
2004 WRX
JavaBlackPearl
if you want to quiet down the noise/flutter get some heat wrap for the downpipe,night + day difference,also helps keep the heat away from the tmic.
obsti2 is offline   Reply With Quote
Old 08-08-2008, 11:23 PM   #17
Mdub
Member#: 152847
2007 WRX
the blue one
Why is this a problem. I'd love to be able to hear my turbo and wastegate flutter. It sounds so badass.
Mdub is offline   Reply With Quote
Old 08-09-2008, 06:15 AM   #18
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
I checked out some youtube videos and between that and all of the posters in this thread I know now it's the wastegate flutter. Thanks all, this puts my mind at ease.
Old 06-29-2009, 03:26 AM   #19
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I'm having the same issue with this "badass" air/turbulence going on with my Stage 2 wrx. It's been scaring the crap out of me. I followed the instructions word for word/step by step. Everything seems tight and in place. The only thing I noticed was that the downpipe to Catback gasket was visible and when I had installed the donut gasket, it was very loose around the diameter of the Downpipe ring. (Would this cause any exhaust leakage?) It looks similar to this person's setup:
See how the flanges of the pipings aren't lined up?
But now that everyone says the sound is normal, I'm thinking about putting the springed bolts back on because I'm sure they allow a certain amount of give when used.
ejicon is offline   Reply With Quote
Old 06-29-2009, 03:34 AM   #20
Impreza541
Member#: 160822
2007 Forester XT
Beige
Its such a unique noise. Ive never heard it on any other car but a subaru...
Impreza541 is offline   Reply With Quote
Old 06-29-2009, 04:31 AM   #21
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I've been hearing 50/50 answers about all of this. 50% say: "It's normal and enjoy it" while the other half say: Exhaust leak/Boost Creepage/BPV Loose. Meh.
Old 06-29-2009, 04:34 AM   #22
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
STI's don't have 2.5" exhaust.
It's 60mm. 2.36".
Byzantium is offline   Reply With Quote
Old 06-29-2009, 10:55 AM   #23
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
I'm not sure why you would want to hear wastegate flutter...
Wastegate flutter is when the wastegate goes back and forth from open to closed under part throttle low boost conditions, it has a ticking sound that can be mistaken for an exhaust leak or misfire.
here is a thread on how to reduce wastegate flutter
http://forums.nasioc.com/forums/show...lutter+arm+fix
and another thread with a pic
http://www.scoobymods.com/wastegate_...tegate+flutter
T-37 is offline   Reply With Quote
Old 06-29-2009, 12:30 PM   #24
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Thanks T-37. I'll check out those links
Old 06-29-2009, 12:59 PM   #25
SLDWYS
Member#: 58877
BMW 340xi
From JDM to DTM
If you used the gasket that came with the DP or the CB then I'd ditch it for the OEM gasket. The gaskets that have a comb like center are horrendous. Mine actually tore and fell out of my newly mated UP to my turbo. I went and bought an OEM and it never had another problem.
SLDWYS is offline   Reply With Quote
Downpipe and uppipe install. now noise? concerned pittsburghscoobie Newbies & FAQs 13 11-17-2009 06:16 PM
exhaust noise concern FRWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-29-2008 04:00 PM
Q: noise concern Azn-Jap STI Vancouver Impreza Club Forum -- VIC 17 09-30-2005 02:33 AM
new owner, a little concerned about 5MT alacrity024 Newbies & FAQs 19 02-02-2004 12:45 PM
New TurboXS muffler question/concern MikeSilverWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-06-2002 06:38 PM
