![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 181994
SCIC
Vehicle:2008 Imp 2.5i PP 5dr Silver |
Hi,
I'll be doing the install Sunday, photos below show what came in the box from Rallitek. In the 2nd photo, I'm not sure where those parts are supposed to go. Thanks!! ![]() ![]()
#2 |
Member#: 108557
NWIC
Vehicle:2003 PSM WRXWgn STG2 05 OBM LEGACY SDN |
They are collars that you install on the sway next to the bushings to keep it from moving around.
#3 |
Member#: 181994
SCIC
How can the bushings move around? They're inside the gold brackets, and the brackets are bolted to the car. The brackets actually fit into a recess on the bushings, so I don't see how there can be movement. Now, if the bushings were flat (no recess), I can see what you're saying is certainly possible, that the bushings can slide out from under the brackets.
Thanks, |
#4 |
Member#: 108557
NWIC
[====||U================================U||====]
My ascii skills are lacking today... |
#5 | |
Member#: 128721
Vehicle:2002 impreza WRX psm |
#6 |
Member#: 108557
NWIC
Here is a non-visual thread link http://forums.nasioc.com/forums/show...ht=collar+sway
I'm @ work and can't go pic hunting but a lot of people use hoseclamps etc to keep the bar from 'walking' under high load. This is just a more aestetically pleasing colution. Last edited by QuikWgn; 08-08-2008 at 05:26 PM. |
#7 |
Member#: 128721
this is a rear bar but same concept.
#8 |
Member#: 108557
NWIC
^^^Exactly...thanks for finding the pic...
#9 |
Member#: 181994
SCIC
Thanks for the explanation!
| Thread Tools | |
| Display Modes | |
| Word of warning for those installing front sway bar | skydes | Brakes, Steering & Suspension | 12 | 07-16-2007 08:38 PM |
| installing front sway bar bushings. can i jack the car up to do the install? | garie | Brakes, Steering & Suspension | 9 | 11-21-2004 06:29 AM |
| Need help installing front sway bar | applesauce683 | Mid Atlantic Impreza Club -- MAIC | 6 | 05-16-2004 12:23 PM |
| How hard to install front sway bar? | 2004TS | Brakes, Steering & Suspension | 4 | 04-16-2004 03:27 PM |
| Guide for installing front sway bar | au112 | Brakes, Steering & Suspension | 9 | 09-20-2003 10:09 PM |
