Old 08-08-2008, 05:01 PM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default Big IC ou not???
I have a Gready FMIC ( 9 1/2 X 27 X 2 1/2 inch=641cu/in) and I did 348WHP with it! My target was to have 450whp!But I thinking to change my small IC for a bigger IC!
Do you think my Gready Ic is enough to support 348whp and MORE??? Do you think a bigger IC, I can do more HP???
I did seek a Yonaka FMIC (12 X 26 X 4 inch=1248 cu/in) to replace my small Gready, do you think it will did a good job???
The question: Do you think I should go big or keep my actual IC???
OB2 is offline   Reply With Quote
Old 08-09-2008, 06:21 AM   #2
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
In general, a bigger intercooler will always give you more power. This is due to the temperature drop of the air from expansion (low pressure). When you're able to cool air molecules at a higher rate, you can pack more of them into the same amount of volume, thus increasing the amount of air your engine can get. Of course, this will up your fuel consumption. It's your call. =P
GentlemenStylez is offline   Reply With Quote
IC spray not working? patsy630 Newbies & FAQs 11 03-19-2008 12:20 AM
front mont IC or not??? OB2 Normally Aspirated with bolt-on Forced Induction Powertrain 9 09-23-2005 05:18 AM
Grooved Rotors a big deal or not?? FargoRS Brakes, Steering & Suspension 1 11-12-2001 01:34 PM
JC Sports turbo kit is burning oil and IC is not working (its cold!) Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-08-2001 10:55 PM
How come Big 3s have not variable Gambit General Forum Archive 2 10-30-2000 10:47 PM
