Old 08-08-2008, 06:52 PM   #1
charliew
Member#: 125304
Default Blown headgasket test kit
It took awhile but I found a blown headgasket test kit and ordered one.
I found it on Thermagasket's site. 69.00 plus I ordered a extra bottle of solution for another 12.00.
http://www.rxauto.com/
To me it is easier to check the coolant than do the compression and leakdown and wonder if it's only leaking on high boost.
charliew is offline   Reply With Quote
Old 08-08-2008, 07:11 PM   #2
Dom'sGurl
Member#: 150837
2006 Legacy GT
It is very handy to have this kit. However, it is not always going to be correct.
I pulled my hair out for two weeks trying to figure out if I had a blown headgasket.
Compression test, leakdown test, coolant pressure test,coolant hydrocarbon test etc etc.
all of them said "no leak". however, when I pulled the engine out it was obviously a blown headgasket. Sometimes a headgasket can leak in ONE direction only (cylinder to cooling jackets and not the other way) and only under the high pressures found during combustion.
Dom'sGurl is offline   Reply With Quote
Old 08-08-2008, 07:17 PM   #3
charliew
Member#: 125304
Yes but that would put exhaust gas in the coolant. You probably know more about this than me though as it's a new thing to me.
Old 08-08-2008, 07:23 PM   #4
Dom'sGurl
Member#: 150837
2006 Legacy GT
yeah, normally you would think so.
But apparently it must not have been enough because it wouldn't trigger the hydrocarbon test.
Old 08-08-2008, 07:29 PM   #5
charliew
Member#: 125304
Every since we put the new motor in wittmer 25's car and it pucked the coolant twice we have worried about the headgaskets. It seemed to be ok after we made a bigger overflow can.
Old 08-08-2008, 11:27 PM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Nice find, for that price I am going to get one
mick_the_ginge is offline   Reply With Quote
Old 08-11-2008, 06:02 PM   #7
charliew
Member#: 125304
I ran into a coworker from a few years ago. He's a old hot rodder and a full time forklift mechanic and he also said the hydrocarbon tester sometimes wouldn't show up a headgasket leak. He also said you could save the used solution if you just sucked fresh air back through it, even if it had turned yellow it would go back to blue and put it in a glass jar to use the next time. Just don't put it back in with the virgin stuff to save.
Guys with blown headgaskets, rate your driving style MaddMax Legacy Forum 16 06-16-2004 10:00 AM
used Subbies and blown headgaskets? dugrant153 Impreza Forum 6 03-15-2004 03:20 PM
Blown headgasket, cylinder (!!!!!!!) C-daleRidr Normally Aspirated Powertrain 25 01-30-2004 12:55 PM
Blown Headgasket seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 7 12-03-2003 12:10 PM
('93-'01) 13.3 @ 108 with a blown headgasket Tarmac Terror Impreza Forum 0 05-25-2001 10:27 PM
