Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 05-02-2001, 04:30 AM   #1
Thug
Choke Artist
Member#: 603
Post How hard is it to remove ABS?
Im buying a master cylinder and single stage brake booster from an older Legacy for about $30. Now I believe this is coming from a non-ABS car. So do I have to remove my ABS to use it? I would like to remove my ABS anyways. It's useless and just gets in the way anyways. Has anybody done a master cylinder/booster swap that's willing to help? This will be my first and I will supply ample pizza, Coke and hoes.
Thanx for the help in advance guys/girls.
-X Nate X
[This message has been edited by y2k4door (edited May 02, 2001).]
Thug is offline   Reply With Quote
Old 05-02-2001, 04:41 AM   #2
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
Post
Forget brake booster, wheres da hoes?
Longshot is offline   Reply With Quote
Old 05-02-2001, 04:50 AM   #3
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
I was under the impression that you don't "have" to remove your abs.. however if you'd like to it's as simple as finding the right fuse and yanking it out... or so I thought.
Confirm this prior to the install of the new booster though.
Fitz
Fitz is offline   Reply With Quote
Old 05-02-2001, 05:00 AM   #4
Thug
Choke Artist
Member#: 603
Post
Id like to actually yank the ABS unit though, if possible.
Old 05-02-2001, 04:44 PM   #5
Ramsdale
Member#: 1951
08 M3
Post
I haven't replaced a master cylinder in quite a while, and it was on a '72 Camaro, but I would think you may be ok with the swap.
The only hangup may be if there is an extra hydraulic line (for the ABS system) going to the hydraulic control unit.
As for ripping out the ABS - that may be tricky. I'm guessing that the hydraulic control unit and the ABS control module are integrated. (The first controls hydraulic pressure to the different wheels, and the second does all the ABS balancing.) You would need to replace the system with a non-ABS one, and then get rid of the ABS sensors, and the wiring. It's possible though. Also, I would check to make sure the non-ABS control modules have their lines routed the same.
Maybe one of the other members or rally drivers (Subie Gal? Paul Eklund?) has done this on an Impreza. Anyone?
KR
[Edit - Spelling hydol.. hyrdal.. hydrau..)
[This message has been edited by Ramsdale (edited May 02, 2001).]
Ramsdale is offline   Reply With Quote
How hard is it to remove a door ?? IllNastyImpreza Interior & Exterior Modification 5 01-10-2008 04:28 PM
How hard is it to remove the front fender zentrandi Texas Impreza Club Forum -- TXIC 15 05-23-2007 02:05 PM
How hard is it to remove the fabric/covers on the 2005 WRX seats? grue Interior & Exterior Modification 10 12-02-2004 08:34 PM
How hard is it to remove the F/R lips on the OEM body kit? Butt Dyno Interior & Exterior Modification 6 09-11-2003 06:44 PM
How hard is it to remove Vinyl? Mike C Interior & Exterior Modification 7 04-23-2001 09:31 PM
