Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 08-09-2008, 05:21 PM   #1
ehime
Member#: 125281
2011 LGT Limited
Crystal Black Silica
Default Stuck Clutch Pedal MY98
just trying to confirm or deny that this is the
Master/Slave clutch cylinder before I go order
the parts. Stealers are charging 130 for Master
and 50~ for the Slave. Just don't want to be
200$ in the hole and have the same problems.
Symptoms: Clutch pedal sticks when depressed,
hard to push into forward gears, grinds bad when
put into reverse. Happened recently after high heat
times. Fine on start-up after been sitting, continuos
driving seems to start showing symptoms. Stop and
go on a hill will pretty much lock up my transmission.
Car: MY98 Subaru Forester S, 5spd Exedy stg3 clutch '
and lightened flywheel under 7k on it. Thanks ahead guys
and girls.
Found this thread, not sure if it will apply to me though.
Subaru TSB for Sticking Clutch:
http://forums.nasioc.com/forums/show....php?t=1065466
ehime is offline   Reply With Quote
Old 08-09-2008, 05:56 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Try bleeding the system first. There are multiple threads with how to info, search.
flstffxe is offline   Reply With Quote
Old 08-09-2008, 08:44 PM   #3
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
I'd be stunned if it wasn't one or the other, and it's best to just replace both at the same time. I don't think those prices are actually that horrible, based on other cars I've worked on.
NotAnRS is offline   Reply With Quote
Old 08-10-2008, 01:16 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
that's your slave cylinder
change the slave + the hose
my car does the same thing and has done for a while
but only in 80F + temperatures
me = too lazy to change it
that's defo the cause.
Jamie
Old 08-10-2008, 02:05 PM   #5
Gorge
Member#: 97449
2007 WRX
Yah, definitely change the slave. Those are the exact symptoms my Supra had. I had to use my left foot to pop my clutch out a lot.
Gorge is offline   Reply With Quote
Clutch pedal stuck to floor Change Transmission (AT/MT) & Driveline 30 10-13-2012 07:32 PM
Stuck clutch pedal in cold weather? ASpec818 Transmission (AT/MT) & Driveline 4 12-26-2007 09:30 PM
Stuck Clutch Pedal MKXIII Transmission (AT/MT) & Driveline 6 02-25-2007 12:33 PM
My leg gets stuck on a clutch pedal! *sigh* paulney Outback Forum 2 12-22-2005 05:26 AM
Clutch pedal keeps getting stuck to the floor. powerlabs Transmission (AT/MT) & Driveline 9 07-06-2005 11:12 PM
