Old 08-10-2008, 06:17 AM   #1
col5555
Member#: 142017
Default Rod length dilema
Hi,
I would like to order some Eagle rods for a 2.35 build I have in the works. I will be using a EJ20 sleeved to a 2.2 bore size with a late model EJ25 crank.
Now my dilema is the Eagle rods come in two sizes 5.137 and 5.181 if my memory serves me correct. As I have not decided which pistons to use as yet(either WISECO or CP) what would be the compression outcome if I used the WISECO EJ22 hybrid pistons which are designed around using 2.5 crank and rods with the shorter EJ20 Eagle rods.
col5555 is offline   Reply With Quote
Old 08-10-2008, 10:47 AM   #2
Dom'sGurl
Member#: 150837
2006 Legacy GT
I think you are going about this all wrong.
If you are going to choose a rod, be sure it is the length the piston is designed for. Otherwise you have 1mm of clearance you are either gaining or losing. That 1 mm makes a huge difference in more than just compression ratio.
My strongest recommendation is to get the longer rods and use the correct pistons.
Longer rods are SO much better in SO many ways. There is no benefit to running the shorter rods.
Dom'sGurl is offline   Reply With Quote
Old 08-10-2008, 10:54 AM   #3
MS WRX
Member#: 117780
2004 WRX
Cobb Ti long rods ftw
MS WRX is offline   Reply With Quote
Old 08-11-2008, 12:10 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
match the pistons and rods together. wiseco tells you which lenght rod the piston is supposed to be used with...
Old 08-12-2008, 11:17 AM   #5
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Unless you are building something custom and you know what you're doing then go with the standard rod length that matches a standard piston. If you go with a longer rod, and don't relocate your wrist pin, or alter the crank, then your quench will be all wrong or worse the piston will actually hit the head.
There is an optimal amount of quench and you shouldn't mess with it too much. If you don't know what I'm talking about I rest my case
5.137 rod with a standard piston and you are good to go.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 08-12-2008, 12:40 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by Element Tuning View Post
Unless you are building something custom and you know what you're doing then go with the standard rod length that matches a standard piston. If you go with a longer rod, don't relocate your wrist pin, or alter the crank, then your quench will be all wrong or worse the piston will actually hit the head.
the first part I agree with completely...but if you either add rod or add crank you have to shorten the compression height or else you will hit the head!!
79mm stroke and 130.5mm rod...add 2mm to the rod (the infamous long rod ) and you have to pull 2mm from the compression height of the piston.
of course you can do combinations in-between too
Old 08-12-2008, 01:04 PM   #7
oldskoolWRX
Member#: 66248
1983 turbo brat
black and white
i'd like to throw some theoretical questions into the mix.what is the "long" rod length based on. common theory says the stroke to rod length proportion of the 2.0L is "perfect" to eliminate losses from piston to bore thrust and allow quick rev. if you crunch the numbers, dosen't 2.5 79mm stroke require around 5mm to be in proportion? or is the 2mm a compromise. what if you throw an 80mm stroke into the mix, can you get longer than 2mm over. i like the cobb ti pieces, just don't like trey. anyone else doing custom lengths in ti? i agree with homemadewrx, weisco seems pretty on top of the pistons, plus higher silica content for street engines (not as much clackety-clack like the je full race stuff).
oldskoolWRX is offline   Reply With Quote
Old 08-12-2008, 01:09 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
I noticed my wording was unclear so I edited but yes I agree with you. What I meant was that the crank and or the piston needs to be modified with a longer rod.
Thanks,
Phil
Old 08-12-2008, 02:40 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
the limiting issue for our EJ is our short deck height...so working around it is the issue...
long rod it based on the rod to stroke ratio, not the actual rod lenght. So, you are correct.
Old 08-15-2008, 01:23 PM   #10
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
I would like to know what rod lenght to choose from 5.138 or 5.181 ?, thats what Pauter is offering for EJ25.
For a ej257 with only CP piston .WrX head .
vulpina is offline   Reply With Quote
Old 08-15-2008, 01:34 PM   #11
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
I just bought K1 Technologies 5.180" rods (H-beam), just to let you know that there are alternate less expensive options.
Kosmic is offline   Reply With Quote
Old 08-15-2008, 01:42 PM   #12
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
i know the pauter are pretty expensive at 800$ for a 4 set , eagle is at 365$ for 4 set ...
Old 08-15-2008, 02:34 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
for an EJ257 you want the 5.138, that's assuming you bought pistons for an EJ257...the NA subies has a longer rod and a shorter compression height on their pistons. Hence the two rod lengths and different pistons being available.
there's a reason for that too...
Old 08-15-2008, 04:51 PM   #14
Trox
Member#: 36785
05 STi (broke)
98 Metro
I have been looking at the Manly Turbo Tuff 5.141” Rods but it doesn’t seem like Weisoc makes a piston for that application.
Trox is offline   Reply With Quote
Old 08-15-2008, 09:28 PM   #15
Kosmic
Member#: 99140
GD Racing chassis
Well, that's only 0.003" difference, I'm sure you can use them as if they were 5.138" rods.
Old 08-15-2008, 10:33 PM   #16
Trox
Member#: 36785
05 STi (broke)
98 Metro
Thanks for the advice. the manly piston suggested for the 5.141" rod has the same Comp Height. as the wiseco’s
Boy do I have a steep learning curve ahead of me.
Old 08-16-2008, 11:31 AM   #17
Dom'sGurl
Member#: 150837
2006 Legacy GT
I have a set of those as well. I modify those rods to have piston oil squirters.
Old 08-18-2008, 12:59 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
I order mine that way
Rod Lengths sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2003 04:16 PM
Stock DOHC 2.5L Rod Length.. sponaugle Normally Aspirated Powertrain 4 12-05-2002 06:36 PM
Rod lengths? n2xlr8n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-07-2002 05:12 PM
WRX Rod Length... Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-17-2001 12:08 AM
