Old 08-10-2008, 08:31 AM   #1
84cj
Member#: 85261
1993 Impreza L 1.8
white
Default engine width?
Anyone know the width of a Subaru engine? Valve cover to valve cover?
What is the weight of a subaru turbo or twin turbo engine?
Thanks.
84cj is offline   Reply With Quote
Old 08-10-2008, 02:11 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
which subaru engine
the DOHC is wider than the phase 2 soch is wider than the phase 1 sohc
Old 08-10-2008, 07:30 PM   #3
84cj
Member#: 85261
1993 Impreza L 1.8
white
EJ20TT to be exact. I'm not too worried as I will make room if need be.
Thanks.
Old 08-10-2008, 08:03 PM   #4
Consense
Member#: 183577
1998 Legacy
On a JDM 1996 Ej20R
29.5" valve cover to valve cover.
31.5" timing belt cover to timing belt cover.
Not sure on the weight.
Consense is offline   Reply With Quote
Old 08-10-2008, 09:22 PM   #5
84cj
Member#: 85261
1993 Impreza L 1.8
white
Looks to be around 300 pounds.....
And thank you for the measurements!!
Old 08-13-2008, 09:10 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well i happen to have a ej20tt in the garage.... if u still need the measurements pm me.
azn0boi04 is offline   Reply With Quote
Old 08-13-2008, 10:35 PM   #7
Letze
Member#: 143323
1990 Celica Alltrac
Gray
Palleted weight w/ exhaust mani and up pipe and turbo is roughly 340
just had an EJ205 shipped from Tennessee and those measurements are about right
Letze is offline   Reply With Quote
Old 08-14-2008, 06:16 PM   #8
84cj
Member#: 85261
1993 Impreza L 1.8
white
cool, thanks guys! azn, PM sent.
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Is there engine problem with the 2011 STI? speed12sil Warranty Issues & SOA Problems 19 06-14-2010 11:10 AM
Tire width and rim width numbers? Any resources? ciper Brakes, Steering & Suspension 5 07-23-2002 10:43 PM
How will Kumho V700 section width change with wheel width? Patrick Olsen Brakes, Steering & Suspension 5 08-06-2001 11:19 AM
tread width vs section width? WRXhauls Brakes, Steering & Suspension 2 06-13-2001 07:12 AM
