Old 08-10-2008, 11:27 AM   #1
12.9$500rex
Member#: 78178
2004 LS1 WRX
Default EJ207 heads. cams?
What cams do you guys think I should go with for my ported ej207 heads with an axis stage 3 2.5 block and either a gt35 or gt40? Not worried about spool too much as long as it's somewhere in the high 3k's to low 4k's. Worried about pricing though....
12.9$500rex is offline   Reply With Quote
Old 08-10-2008, 07:09 PM   #2
MS WRX
Member#: 117780
2004 WRX
Low 4k's with a gt40??? keep dreamin.
MS WRX is offline   Reply With Quote
Old 08-10-2008, 10:04 PM   #3
gold rush
Member#: 90110
2004 wrx wagon
If your looking for good spool/mid-range, you should keep the stock cams.
gold rush is offline   Reply With Quote
Old 08-11-2008, 04:45 AM   #4
xb00stx
Member#: 186544
07 WRX Limited
stock cams IMO, but if you really wanna buy something BC 272s
xb00stx is offline   Reply With Quote
Old 08-12-2008, 09:52 AM   #5
12.9$500rex
Member#: 78178
2004 LS1 WRX
I don't think BC makes cams for the 207 do they?
Old 08-12-2008, 10:29 AM   #6
SLDWYZ
Member#: 85008
03 wrx
blue
SLDWYZ is offline   Reply With Quote
Old 08-12-2008, 03:49 PM   #7
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
I'm running Kelford AVCS 272/278 cams with a GT35R on a 2 liter. I am seeing 27 psi @ 4700 rpms. A 2.5 should see similar boost in the low 4000's.
def
dug-e-fresh is offline   Reply With Quote
Old 08-13-2008, 02:03 PM   #8
12.9$500rex
Member#: 78178
2004 LS1 WRX
Originally Posted by SLDWYZ View Post
those are for the ej257 heads... What about ej207 heads?
Old 08-13-2008, 02:19 PM   #9
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
AVCS cams will work in either head
ENGINE PARTOUT: JDM V7 RA-C EJ207 heads, shortblock, Tomei cams/turbo, FMIC, and more zeropsi MWSOC Private Classifieds 39 12-29-2009 11:33 AM
ENGINE PARTOUT: JDM V7 RA-C EJ207 heads, Tomei cams/turbo, exhaust, FMIC, much more zeropsi Engine/Power/Exhaust 27 12-20-2009 12:54 PM
ej205 heads/cams/ecu with ej207 shortblock? DKeen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-24-2009 08:20 PM
HELP!! V7 EJ207 Rear Cam Sensor NEEDED!!! Javier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-20-2005 12:48 AM
V7 EJ207 Rear Cam Sensor NEEDED!!! Javier Private 'Wanted' Classifieds 0 12-17-2005 06:12 PM
