Old 08-10-2008, 02:51 PM   #1
islandboy78
Member#: 96163
2009 IMPREZA
Default Help White Smoke
Ok so the car sits for a week, I start it up very light white colored smoke appears from the exhaust and then as the car idles and coming out of the muffler looks like blackish water, I am thinking it's condensation and couple shops think it is and as far as the smoke it clears when the car is warmed up. What could be the problem and what shall I do. I just rebuilt the engine.
My second problem is Ok here is the situation I rebuilt my engine, after the engine built the car will idle and run sluggish when i clear the mis fire codes P301, 302, 303, 304 misfire detected code, but the minute the codes come back the car is running back to normal. I broke in the car at 1500 miles and got a conservative tune. After the break in process i bought new spark plug but just used the gap that it came with. I am running a blow through set-up with tgv deletes. I am using the okada boots with the stock coil pack. The radiator has like a powder looking on the cap, will be doing a flush soon. Any help or advice will help.
Mods below:
Utec EM
Okada Boot
TBE
Fp Green
turbxs FMIC
All in all with the check engine lights on and the car warmed up, she runs like a champ. Some guidance and advice would help....
islandboy78 is offline   Reply With Quote
Old 08-10-2008, 06:25 PM   #2
islandboy78
Member#: 96163
2009 IMPREZA
Did compression testing all compression numbers came out fine...
Old 08-10-2008, 06:46 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Have you tried using stock coil packs in case the okada units are not working as they should?
jigga is offline   Reply With Quote
Old 08-10-2008, 06:48 PM   #4
islandboy78
Member#: 96163
2009 IMPREZA
doing that as we speak. Thanks for the advice...
Help! White smoke still coming from exhaust. ChronicPoe Service & Maintenance 8 05-15-2009 01:28 PM
HELP! white smoke shemp321 Built Motor Discussion 9 02-19-2009 02:07 PM
help! white smoke!! please! RIRENTER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-31-2006 02:37 PM
Help!!! White smoke after resinstallation of stock injectors calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-24-2005 03:54 AM
HELP! White Smoke Problem...Experts needed blkwag Normally Aspirated Powertrain 7 08-30-2002 03:57 AM
