Old 08-10-2008, 07:48 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default 100% new 07 STI short block and I want to toss in some forged pistons. (questions)
1. Can these be just pressed in without going to a machine shop? I will be using standared bore cosworth pistons.
2. Will I need a retune? I dont plan on changing my set up right away from what it is now. I would go with the oem compression ratio.
3. Do I need to change anything else while Im in there. The car will never see more than 400 whp at the most and 380tq on a dynopack.
The car is a 2007 sti running stage 2.
mrtrex is offline   Reply With Quote
Old 08-11-2008, 03:34 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
standard bore drop in pistons should still be mic'd to
fit properly into cylinder bores.
the fact that you said "pressed" indicated that you
have not spent much time researching piston swaps.
but trying to obtain 400 whp with your wrx drivetrain
will shorten the lifespan of the drivetrain.
you might need a larger tmic or fmic to get to your 400 whp.
water / meth will help.
850cc injectors at least...and usual supporting mods.
be prepared to spend some cash..
Old 08-12-2008, 01:09 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
1) The piston to cylinder wall clearance always needs to be measured and adjusted as needed. The same applies to the ring-end gaps. Sometimes these measurements are way off and sometimes they are fine. Never assume it's correct.
2) If your previous engine or pistons were damaged then yes you need to be retuned as it's likely your first tune caused the engine failure. If you feel your motor was damaged from something other than tuning then make sure you find the cause before building a new motor.
3) You just need to make sure you have found the cause of the failure, you have replaced the failed part(s), and you have thoroughly cleaned all the oil passages, lines, and fittings.
When in doubt leave it to the pros.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 08-13-2008, 09:45 PM   #4
mrtrex
Member#: 12223
2005 WRX
Thanks for the info. My car is fine I am just building a short block for down the road. I think im going to just get the Raw Performance/Axis stage 1 block.
Old 08-21-2008, 12:10 AM   #5
Mechie3
Member#: 120152
How do you adjust the piston to cylinder wall gap? I know how to grind down rings, but not sure on the other.
Mechie3 is offline   Reply With Quote
Old 08-21-2008, 01:03 AM   #6
norexyet
Member#: 39149
11 elantra
yea i said elantra
That has to be done by a machine shop.
norexyet is offline   Reply With Quote
Old 08-21-2008, 01:33 AM   #7
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
A machine shop has to bore with a machine that is similar to a giant drill bit, or hone with a set of filing stones.
http://www.youtube.com/watch?v=MAfdq217CJI&NR=1
eastcoastbumps is offline   Reply With Quote
Old 08-21-2008, 10:14 AM   #8
Mechie3
Member#: 120152
So if the gap is already too big you need to buy new pistons?
Old 08-21-2008, 01:00 PM   #9
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
joke
Snap-on makes a piston expander. Its very expensive though, so you're just better off buying new pistons.
Old 08-21-2008, 01:12 PM   #10
novacivic
Member#: 117980
2005 sti
wr blue
Originally Posted by eastcoastbumps View Post
joke
they also sell a board stretcher too for when you cut a piece of wood a little too short.
novacivic is offline   Reply With Quote
Old 08-21-2008, 07:13 PM   #11
Robzilla
Member#: 166736
2005 WRX STI
All your questions can be answered with a little more research, try it.
Robzilla is offline   Reply With Quote
FS: 07 sti short block with new pistons vtboost NESIC Private Classifieds 33 06-11-2009 12:33 PM
03 wrx with sti short block and sti 6 speed tranny and 06 gsxr600 motorcycle platinum03wrx/sti Private Vehicle 'For Sale' Classifieds 4 02-16-2008 11:03 AM
2.5 STi short block and 6 new pistons ,rings and wrist pins LiquidForce Private 'For Sale' Classifieds 6 07-13-2006 08:44 PM
