Old 08-10-2008, 08:57 PM   #1
drftwell
Member#: 182244
Default Drive by wire conversion help 02 to 04 sti ej257
doing an sti swap and im going to convert it to drive by wire . . . . ive got the complete dash harness, pedal,ecu, and engine harness..... anyone know of how easy/hard this is gonna be?
drftwell is offline   Reply With Quote
Old 08-17-2008, 05:09 PM   #2
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
i'm doing the swap right now with a 05 sti into a 03 wrx. pretty straight forward. the hard brake lines to the abs is probably the hardest. you need to buy a bracket for the gas pedal for the drive by wire.
RexRexRex is offline   Reply With Quote
Old 08-17-2008, 06:53 PM   #3
drftwell
Member#: 182244
Sweet where do I get the bracket? Also can you tell me a bit more about it so others can use this as well ? what do you have to do with the brakes?
Old 08-17-2008, 06:58 PM   #4
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
well i opted for the 6spd so i wanted the dccd. i bought a sti abs pump so the the hard brake lines are different from the wrx. East coast swappers makes a great bracket for the gas pedal.
Old 08-17-2008, 07:43 PM   #5
silentt
Member#: 119995
2004 Outback XT
Peachy
http://forums.nasioc.com/forums/show...php?p=22826173
Outlines the swap process, it should be fairly similar if you were to do that to the 02 WRX. If you got someone to do your wiring for you, they will do all the conversion necessary for you to use DBW.
silentt is offline   Reply With Quote
Old 11-03-2008, 01:16 PM   #6
White out
Member#: 46277
** LP640
Viper GTS
hey drftwell, I would like those injectors.
Nick
White out is offline   Reply With Quote
02 wrx to 04 STi front end swap, help with headlight wiring Unlikely Hero Electrical & Lighting 12 03-25-2011 01:40 AM
non drive by wire AEM EMS for 02 - 04 wrx 800 shipped anjion24 Engine/Power/Exhaust 24 04-14-2010 11:28 PM
need help! 02 to 04 bumper swap trouble birchwood Interior & Exterior Modification 4 05-11-2007 05:17 PM
Drive By Wire Gas Pedal Help 450hp STI sleepersy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-08-2006 05:59 PM
Need answer quick! Vishnu Signature TBE 02 to 04 STi? 409Industries Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-23-2005 07:44 PM
