#1 |
Member#: 6307
NESIC
Vehicle:what I has no car... am carless |
This weekend besides weekend house crap that I finished, I also got work done onthe BAJA...
Installed the STi Intercooler... pain in the butt without my fathers shop to work out of. Also It would have been better if I had the OEM BPV hose from an STi instead of the Ebay X02 racing hose that did not fit so I adapted the OEM BAJA BPV hoses to fit with the X02 hose... 710 fluid change.... annoying random whiff of oil smell and no wet filter or drain plug / pan.. ugh hate that feeling. Now for the QUESTION in this thread. I installed the two heated mirrors and the switch. The passenger side works like a charm, hence forth the switch does too! However the drivers side does not. Is there a procedure to test it, maybe just replace the glass / element part? It took me forever to find a mica black pair of mirrors... anyone???
#2 |
WCSS Drunk
Moderator Member#: 8914
NWIC
Vehicle:2005 Baja Sport Regal Blue Pearl |
could you swap the mirrors??? like just plug in the drivers mirror on the passenger side and see if you get it to power up over there?
#3 |
Member#: 65681
Vehicle:13 XV Limited gray |
yeah do what he said...that seems really strange but maybe you got a bum mirror.
#4 |
Member#: 105920
Vehicle:2006 Baja 5 Speed |
Use a volt meter, verify you're getting voltage to the pins.
#5 |
Member#: 6307
NESIC
the mirror adjusts... when it stops raining ill take it apart and try those ideas...
does anyone have a wire diagram for the doors? |
#6 |
Member#: 105920
I do, no way to scan though
I can post the pins and what they do if you like? |
#7 |
Member#: 6307
NESIC
that sounds good, OH!
I just remembered, don't the heated mirrors have the little defroster icon on the drivers side one? |
#8 |
Member#: 105920
yes they do, actually the both do
#9 |
Member#: 105920
SO on both the Yellow/red 4 and Yellow/Green 5 wires are the heater circuit
and Red/blue 3 stripe is the common for the mirror motors Right only blue/ green 1 stripe is the up/down motor blue/ white 2 stripe is the left right motor Left Red/white 2 stripe is the left/right Red/yellow 1 is the up/down looking at connector face on tab 3,2,1 6,5,4 |
#10 |
Member#: 105920
sigh now if i could only add the heated wipers I'd have the ultimate factory baja :/
#11 |
Member#: 65681
#12 |
Member#: 105920
ordering the parts for the seat tomorrow 850$ for the motors, leather and frame. I'm debating a new cushion just for grins while i'm at it.
#13 |
Member#: 137951
South East
Vehicle:2006 Baja Turbo Blue Phat Botti Tuned |
#14 | |
Member#: 65681
I can tell you how to do it with a junk yard seat. I did mine for hardly any money then i sold what was left. Don't do this without hearing me out... |
#15 | |
Member#: 105920
I have the lights and mirrors done. Seat will be ordered next paycheck. I might do the lighted ignition ring, then I'll have all the turbo options :-D btw Jeff, the computer is built. However now the real fun has been trying to get a workable front end interface. I'm toying with roadrunner right now. It's gonna take a lot of work to make it look clean. I also might have to send the xenarc head unit back to see if they'll fix it. Lots of software bugs still, and the front pre-amp outputs have zero volume. :/ Last edited by steven765; 08-17-2008 at 02:49 AM. |
#16 | |
Member#: 105920
#17 | |
Member#: 65681
well placed zipties FTW. If you do it right it is just as good ![]() |
#18 |
Member#: 65681
talk to me about the lights... I know they look different but what about wiring and is there a difference in seeing with them at night?
#19 |
Member#: 105920
You mean the head light swap for the 4 beam? It was caaaake, just order the 4 beam ones where ever you can find them cheapest. I then went and bought watertight automotive connectors, cut the factory, put mine on, snapped them in.. you're good to go! They're both 3 wire, you just have to map them out. Voltmeter will do. I can go find the colors if you really ask nicely.
They look great, the 4 beams look far more aggressive then the 2. I haven't cleared them yet. I still debate the safety factor of doing so as the orange is meant to shine the light back over the corner. I also like the vision pattern more. With the 4 beams I was able to replace everything up front with the real orsama bulbs from europe, not the overpriced silverstar's. So it could be a combination of both. |
| Thread Tools | |
| Display Modes | |
| My weekend project...2nd SC is in! | reddevil | North West Impreza Club Forum -- NWIC | 4 | 05-21-2006 12:40 PM |
| My weekend project (GT4) | 8Complex | Mid West Subaru Owners Club Forum -- MWSOC | 48 | 03-07-2005 04:26 PM |
| Questions about my turbo project. | GameMastyr | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 03-13-2003 03:52 PM |
| My weekend project | christoph1371 | Normally Aspirated with bolt-on Forced Induction Powertrain | 23 | 07-06-2002 05:47 PM |
| My weekend project! | subee_love | Brakes, Steering & Suspension | 0 | 05-07-2001 05:16 PM |
