Old 08-10-2008, 10:11 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default True pressure testing of the IC and manifold....A trick
Its hard and a pain in the ass.
Originally I was using a tube with a tire inflater thingy that I would install into the intake POST turbo. Then I would hook up the air compressor and "inflate" the system.
The good? The really OBVIOUS leaks will show up. But think about it. A BigAssTurbo moves a ****load more air than a compressor, even when all the valves are closed, so the secret problem leaks seldom show up. So thats the BAD, the leaks you have actually on boost, never show up. This is cause the actual cylinders DO leak some, no matter what.
So..... I made a plug for the throttle body tubing. ie I pulled the piping off the throttle body and blocked up the entire IC piping network. Now I was able to pressurize and HOLD pressure in ALL of the IC tubing/MAF/supercharger/BOV/IC piping connections. And suddenly all the secret leaks showed up. The BOV was leaking at its base, the blow through MAF was leaking out the top, the welded up supercharger intake was leaking at two weld points, and there was one annoying IC pipe connection leak.
And I was able to take care of ALL of them!
Old 08-11-2008, 01:29 AM   #2
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Or you can switch to MAP fueling
Splinter is offline   Reply With Quote
Old 08-11-2008, 01:31 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
MAP or MAF, it doesnt matter if there are leaks!
Old 08-11-2008, 01:56 AM   #4
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
While I was kidding, it does actually matter.
small pre-throttle leaks on a MAP system don't really affect performance. I can take my intercooler piping completely off and my car runs just fine. My IAC isn't even plumbed into my intake piping.
Unless the leak is large enough that you're losing pressure through it, it won't significantly affect anything.
Anyone know the route of the IC sprayer line? Nixlimited Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-22-2005 05:32 PM
Coating the inside of the stock exhaust manifolds, could that be done ? ronf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-18-2005 10:22 AM
Why the Color of the Food You Eat Can Trick You Into Pigging Out Janq Off-Topic 5 05-27-2004 04:07 PM
Thermo-Tec on the bottom of the IC? Narcisse91 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-19-2002 09:47 AM
A test drive of the Blitzen and its in English N/A General Forum Archive 7 07-22-2000 02:40 PM
