Old 08-11-2008, 12:08 AM   #1
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Default where to get 2.8 litre...
so ive seen some people running 2.8 litre engines....is that something that could be straight bought? or is that something custom made by a machine shop?
vanillajuice is offline   Reply With Quote
Old 08-11-2008, 12:37 AM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
I know Crawford Performance used to sell them, but I am not currently seeing them on their website. I believe they ran an 84mm stroke crank, and a 102mm bore to reach a 2.8L displacement. It would by your definition be a "custom machine shop" engine. You would need to source an 84mm crank, custom pistons (with lower compression height), and have the block sleeved to facilitate a 102mm bore.
MartinSTi05 is offline   Reply With Quote
Old 08-11-2008, 03:03 AM   #3
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
ya crawford is what i saw a while back...but like u said...not anymore. ya sleeves i know are a must tho
Old 08-11-2008, 07:13 AM   #4
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
I don't know of anyone selling them now, the biggest I have seen lately is a 2.75L.
hauntedwrx is offline   Reply With Quote
Old 08-11-2008, 11:42 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I have a spare 0.3L in my garage, you can have that if you like. Just add it to a standard 2.5L and hey presto you have a 2.8L
mick_the_ginge is offline   Reply With Quote
Old 08-11-2008, 04:22 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
can I ask why you want a 2.8L in particular?
what are you going to use it for?
Just curious...
Mick, I like your answer
Old 08-11-2008, 09:48 PM   #7
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
^haha so do i.....why a 2.8? why not? no reason in particular. just figured itd be something a bit different, with a bit more torque and a bit less spool time.
Old 08-11-2008, 11:06 PM   #8
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Magnus Motorport sell a 2.8L wrx stroker kit for $4375.00 USD - which isn't too expensive. But you'll still need to pay the block prep/machining etc on top.
I'd expect at least $10K to get just the bottom end done and another $5k for heads that would do it justice. Then add that much ($15K) again for turbo, intercooler and other supporting parts.
I doubt you'd have much change from $50K just for the 2.8L engine build and its supporting parts - but you would definitely have one killer package
If you seriously want to go down this road, speak with a reputable Subaru/WRX engine builder/tuner - oh and your bank :P
wrxsti.l is offline   Reply With Quote
Old 08-11-2008, 11:23 PM   #9
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Ah before you pay that much look at the BC stroker kit 2.71L. I have one but if you where to ask me I wouldnt do it again. You can build a long rod, big bore, short stroke for far less and probably make same if not more power...
Sinister redlines is offline   Reply With Quote
Old 08-11-2008, 11:27 PM   #10
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
H6 if u want big capacity.. bigger than 2.5 i.e 2.8 and the stroke becomes too square..
tino is offline   Reply With Quote
Old 08-12-2008, 12:09 AM   #11
Homemade WRX
Member#: 33782
96 bastard child
I think you meant stroke becomes too long, making the rod ratio really short (which has perks and trade offs)...
nothing wrong witha square or even under square motors...once again more pro's and con's...
Old 08-12-2008, 12:41 AM   #12
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
square engines with long rods is a great combination however not very feasable in a subie. Not impossible but just to give you a hint a 86mm by 86mm is a 2L, and a 86mm stroke is GIGANTIC for a subie.. Even my 2.7L uses a 83mm stroke and like mentioned above a 2.8 magnuson uses a 84mm. These are considered pushing the envolope for stroke (again it is possible to go more but the deck height just doesnt allow for much of a rod length.).
Old 08-12-2008, 02:01 AM   #13
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
hmmm....looks like i may just end up getting a 2.7 litre "out of the box"
Old 08-12-2008, 02:20 AM   #14
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I wouldnt... Build a big bore, short stroke 2.5... just so happens a 2.0 crank and a sleeved 102mm bore = 2.5L You will get a better rod ratio and better revs..
Old 08-12-2008, 02:39 AM   #15
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
what ill prolly just end up doing is going with an axis signature series 2.5litre sleeved block to start....just keep it simple i spose
Old 08-12-2008, 08:13 AM   #16
Homemade WRX
Member#: 33782
96 bastard child
[sarcasm] thanks, I didn't know [/sarcasm]
There is actually one combo I would recommend over the one you list....the EJ20 crank would be a simple way but there is one that will yield a nicer rod ratio for most people and more displacement too
Also 102mm bore isn't bad but doesn't have the best ring selection though it is 4.040"...also there is a similar size that has better flow discharge coefficients
Old 08-12-2008, 09:59 AM   #17
tino
Top Scoob 019
Member#: 43630
hahaha yeah thats what i meant.. oopsss either way its not a good idea on a suby engine...
Old 08-12-2008, 10:46 PM   #18
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Okay so what is it? I know you have been playing with it so fill us in .
And I know you know it was meant for everyone else
Where to get 2.5RS grill/trunk badges? Xcasinonightzone Newbies & FAQs 6 11-26-2005 07:57 AM
Where to get 2.5RS decals for spoiler? 012.5RS Private 'Wanted' Classifieds 5 10-16-2005 08:45 AM
where to get 2.2kohm resistor in Edmonton R.C.Y.K. Canada Region Forum 9 02-21-2004 03:42 PM
Where to get 2.25" exhaust donut gasket Rubasu Normally Aspirated Powertrain 5 03-03-2003 10:15 AM
Where to get 1/8 BSPT bung? Is there such a thing? Corey Normally Aspirated Powertrain 0 08-02-2002 11:28 AM
