Old 08-10-2008, 11:49 PM   #1
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
Default EGT on 20 thou overbore
Hey guys, I just rebuilt my 2.0 V7 JDM STI with a 20 thou overbore and was wondering what the EGT should be.
I am currently breaking in the motor so I am not running any boost.
I have noticed while driving (in no boost) at about 60mph constantly the EGT approaches 1400F. Is this normal for an engine with the slightly greater compression ?
Any input would be great, thanks!
chanders is offline   Reply With Quote
Old 08-11-2008, 10:46 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Depending on where the EGT sensor is that sounds about right to me, I used to see 1525 on cruise. What you need to do is check the fueling and timing under those conditions. Under cruise you should be at 14.7:1 AFR and loads of timing.
mick_the_ginge is offline   Reply With Quote
Old 08-11-2008, 02:29 PM   #3
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
^^ Thanks Mick. The sensor is actually located in the exhaust manifold about 4" from the flange. I am yet ti install my wideband to determine the AFR's in that area.
Thanks for your input. Anyone else with some info?
Old 08-11-2008, 08:40 PM   #4
remowgn
Member#: 41149
04 09 FXT
SSM
I see numbers in line with what you're getting with my stock EJ205. It's completely normal to have high EGT's at cruising... with the ECU keeping things at stoich and a comparatively low amount of air going through the motor, they will be right up there. It's nothing to worry about and is actually a good thing, as it means you're getting a more complete burn and the cats (well, if you have any) will do their job better.
remowgn is offline   Reply With Quote
Old 08-11-2008, 10:55 PM   #5
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
^^ Thanks. I was beginning to get a little worried when I saw 1400F!!
John Stossel special on 20/20 tonight Mike Wevrick Political Playground 8 03-13-2009 06:46 PM
High EGTs on 93 Low on c12? BradsWRX Factory 2.0L Turbo Powertrain 3 01-13-2009 10:51 AM
BABYLAND on 20/20...rediculous *rant inside* imblown-ru Off-Topic 28 08-23-2008 04:17 PM
Drunk chicks on 20/20 now... Layman Off-Topic 3 03-10-2006 10:30 PM
so who saw me on 20/20 last night??? sho0tme Texas Impreza Club Forum -- TXIC 14 08-04-2001 01:18 PM
Message Board Statistics All times are GMT -4. The time now is 10:39 PM.
