Old 08-11-2008, 02:39 AM   #1
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
Default knock sensor tq Specs
After my motor was built the guy that put it back into my car over tightend it and i was showing random knock but he went back and fixed the tq spec but it stilll showing a little random knock.. could he have damaged the sensor by over tq ing it and should i get i new one to stop all the knock
subaruNV is offline   Reply With Quote
Old 08-11-2008, 10:43 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Yes it can be damaged by over tightening it. It should be no more than 15 ftlbs as I remember it. It also had to be in the correct orientation as well.
Are you sure it's not real knock?
mick_the_ginge is offline   Reply With Quote
Old 08-11-2008, 03:24 PM   #3
subaruNV
Member#: 154549
2006 DOM 3 Powered
well its very random and u cant hear anything really. some times it knock during shifts sometimes it doesnt
Old 08-11-2008, 06:35 PM   #4
charliew
Member#: 125304
I read on I think Autospeed that a good listening device is better for tuners than relying on the stock knock sensor if you want to be real sure of knock threshold.
charliew is offline   Reply With Quote
Old 08-11-2008, 07:40 PM   #5
subaruNV
Member#: 154549
2006 DOM 3 Powered
well i found the random knock when i got tuned by my tuner. it was from his data log.
Old 08-11-2008, 09:46 PM   #6
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I have not checked to reference other models but the 06 wrx is 17.4 ft/lbs to be exact. Here is the page from the service manual, make note of the orientation of the sensor as well.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 08-11-2008, 11:03 PM   #7
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Hehe. Installing the knock sensor in the wrong direction--I found to be a bit difficult due to the confined space and relatively short wire connections.
GentlemenStylez is offline   Reply With Quote
Old 08-12-2008, 01:47 AM   #8
subaruNV
Member#: 154549
2006 DOM 3 Powered
could replacing this possibly help with my problem....the very and i mean very rendom knock after over tq ing the last one
Old 08-12-2008, 07:28 AM   #9
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Since the last one was overtorqued, I would replace it regardless of any other factor. It's sensitive equipment that needs to be installed properly to function properly. Who knows what could be wrong inside????
As far as knock is concerned, run higher octane fuel, that should help greatly with your knock problems. Just don't put any lead additives.
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
TQ specs and Timing on a hybrid--where to get specs??? quikcobra Built Motor Discussion 5 11-30-2008 06:32 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
knock sensor torque spec? 48th ronin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-27-2002 09:15 AM
