Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Closed Thread
Old 08-11-2008, 04:32 PM   #1
Edo Performance
Vendor Sales Rating: (54)
Member#: 70537
Default Greg's August Coolant and Service Specials!!!!!
EDO PERFORMANCE is now offering coolant services from $35.00 and up depending on cooling system and type of coolant! Is your car protected from the summer heat? Did you know coolant is recommended to be changed every 1-2 years by the manufacturer? We will check the freeze protection and mixture as well as the radiator cap for leaks. Don't be stuck on the side of the road because your coolant couldn't protect your vehicle from heat or corrosion.
Feeling the heat! Edo is now certified to perform A/C repairs and to do performance testing!
Summer is in full effect. New WRX's, New STi's, New parts to install! Okay...just another excuse to give you all discounts on our services. With hot temperatures comes hot hot hot prices!!!!!!
Oil Changes
- Mobil 1 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $68 NOW $60
- Motul 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $75 NOW $70
- Motul 300V 5W-30 Synthetic Oil with Zero/Sports Oil Filter WAS $99 NOW $90
Transmission and Differential Fluid Changes
- Transmission: Motul 75W-90 Synthetic Gear Oil WAS $110 NOW $100
- Differentials: Motul 75W-90 Synthetic Gear Oil WAS $70 NOW $65
- COMBO Trans and Diff: Motul 75W-90 Synthetic Gear Oil WAS $175 NOW $150
Brake Services
- *Motul Brake Fluid is used on EVERY Brake Service!
- **Add an additional $7 for Motul RBF600 Fluid!
- Zero/Sports Stainless Steel Brake Lines (Front and Rear) $240 INSTALLED!
- Zero/Sports Front "Street" Brake Pads $175 INSTALLED
- Zero/Sports Front "Sport" Brake Pads $225 INSTALLED
- Zero/Sports Front "Circuit" Brake Pads $255 INSTALLED
- Zero/Sports Rear "Street" Brake Pads $165 INSTALLED
- Zero/Sports Rear "Sport" Brake Pads $215 INSTALLED
- Zero/Sports Rear "Circuit" Brake Pads $245 INSTALLED
- COMBO Front and Rear Pad Packages available! Please PM for pricing!
Clutch and Flywheel Installations
Clutch/Flywheel Install $500*
* Motul Gear Oil will be used to refill your transmission.
Factory Mileage Maintenance Services
30,000 Mileage Service
- Inspection of drive belts and camshaft belts
- Inspection of fuel system, lines, and connections
- Inspection of air filter (replaced with Zero/Sports N1 Filter if necessary)
- Inspection of brake pads, linings, and lines
- Inspection of ATF/Power Steering Fluid
- Inspection of front and rear axle boots and axle shaft joints
- Inspection of clutch, steering, and suspension systems
- Inspection of tires (and rotation if permitted)
- Engine oil replacement with Motul 5W-30 Synthetic Motor Oil
- Engine oil filter replacement with Zero/Sports Oil Filter
- Engine coolant replacement and system/hose inspection for cracks/leaks
- Transmission and Differential fluids replaced with Motul 75W-90 Synthetic Gear Oil
- Brake fluid replaced with Motul Brake Fluid**
- WAS *$480! NOW $470
60,000 Mileage Service
- 30,000 Mileage Service is performed
- Fuel Filter replaced
- Spark Plugs replaced
- WAS *$560! NOW $550
90,000 Mileage Service
*Additional fees may be added for automatic transmission vehicles and for replacement of air filter. Customer will be notified of charges in advanced.
**$7 additional fee if Motul RBF600 Brake Fluid is requested
Stay tuned as I will keep this thread constantly updated with up-to-the-minute sales and installation specials!
We also stock a lot of Motul Fluid
Motul
8100 5W30 Oil - Call/PM for Price!
8100 5W40 Oil - Call/PM for Price!
300V 5W30 Oil - Call/PM for Price!
300V 5W40 Oil - Call/PM for Price!
75W90 Gear Oil - Call/PM for Price!
90PA LSD Oil - Call/PM for Price!
Dextron III ATF - Call/PM for Price!
Inugel Expert Coolant - Call/PM for Price!
MoCool Radiator Additive - Call/PM for Price!
RBF600 Brake Fluid - Call/PM for Price!
Thanks
-GREG
EDO Performance
16182 Gothard Street, Unit P
Huntington Beach, CA 92647
714-602-5741 ext. 15
__________________
[B][COLOR="Red"]U[/COLOR].[COLOR="White"]S[/COLOR].[COLOR="RoyalBlue"]A[/COLOR]. [/B][COLOR="Black"]Master Distributor for:[/COLOR]
[B][COLOR="Blue"]Cusco[/COLOR], [COLOR="Magenta"]Tomioka Racing[/COLOR],[COLOR="SeaGreen"] Zero Sports[/COLOR], [COLOR="Red"]Motul[/COLOR][/B]
[COLOR="Black"]Phone:(714)602-5741[/COLOR]
[COLOR="Blue"][B][U]Follow us on:[/U][/B][/COLOR]
[/URL]
Edo Performance is offline
Old 08-13-2008, 09:48 PM   #2
illmatic
Member Sales Rating: (38)
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
You might want to edit one of those pics.
illmatic is online now
Old 08-13-2008, 10:01 PM   #3
Edo Performance
Member#: 70537
Done Account was hacked GRRR!!!!
__________________
[/URL]
Old 08-15-2008, 01:31 PM   #4
Edo Performance
Member#: 70537
Bump Bump!!!!!
__________________
[/URL]
Closed Thread
EDO Performance Service And Install Specials! This Weekend Only! Edo Performance SCIC Vendor Classifieds 19 06-30-2007 01:10 AM
EDO Performance Meet, Service and Install Specials! Saturday, June 30 Edo Performance Services 1 06-19-2007 06:32 PM
EDO Performance Service And Install Specials! This Weekend Only! Edo Performance Services 2 06-05-2007 09:14 PM
Happy 420 Brake Service Special!!!! Slotted rotors and other parts included!! SpeedElement BAIC Vendor Classifieds 1 04-29-2006 06:30 PM
Oil Change and Brake Service specials! HRE | giulio Tri-State Area Forum 0 09-24-2001 09:57 AM
