Welcome to the North American Subaru Impreza Owners Club Sunday November 29, 2015
Old 08-12-2008, 10:08 AM   #1
Member#: 161122
Chapter/Region: HIIC
1998 GC8 EJ255 swap
Default Help With A Swap
Ok i picked up a 2006 WRX TR the car was put in to a wall at 120 the motor and tranny is still good. Pretty much ever thing is still good but the driver side doors and rear fender. Any ways i drive a 1998 gc i am looking at doing the swap motor trans every thing i was looking around for some help on what else i would need to buy to do the swap and what i need. I was also wanting to know if any one has done it yet and how hard it was and if they ran into any problems with the imoblizer. thanks for your time
Relax_Tampax is offline   Reply With Quote
Old 08-12-2008, 12:20 PM   #2
master c
Member#: 168226
wrong forum
master c is offline   Reply With Quote
Old 08-12-2008, 01:09 PM   #3
Member#: 119995
2004 Outback XT
You can use most, if not all of the mechanical bits with your car. You need to buy little else, basically just a set of rear top hats if you plan on using the WRX suspension. You will need to merge your harness or have it merged. PM me if you have any more questions.
silentt is offline   Reply With Quote
Old 08-13-2008, 03:35 AM   #4
Member#: 129737
04 Sweet Impreza
or just swap out the whole harness
auslyle is offline   Reply With Quote
Anyone NJ or near by want to help with a swap serg Tri-State Area Forum 20 08-16-2004 01:14 AM
Help with Engine SWAP Damaged 04 Wrx 2004SWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-23-2004 05:32 AM
Help with AWD swap- Part Deuce scoobyimprza Mid Atlantic Impreza Club -- MAIC 4 05-04-2004 01:26 AM
help with head swap evo2rex Normally Aspirated Powertrain 3 03-04-2004 11:04 AM
Install help with drivetrain swap, 1.8 to 2.5 cindergarden Tri-State Area Forum 6 11-05-2002 07:00 PM
