#1 |
Member#: 127215
**NEW PICS**
POST 76 I bought this car April of '07 after selling my '05 STi with the idea of building something just as fast/fun but for less money and cheaper on insurance. Its been just about a year later and shes almost ready to come back out. No its not swapped just yet but all in due time..... Anybody wanna go for a cruise once its back out on the road? **sorry for the big pics** ![]() ![]()
#2 |
Member#: 127215
New Rear:
![]() Factory brakes FTL! ![]() Test fitting wheels....Yeah they're Rotas wanna fight about it? ![]() ![]() Pulled the original EJ25, blown head gaskets and a nasty valve tap so I replace it with a lower mile motor. I broke 3rd gear on my trans so I also replaced that. I'm sticking with the RS drivetrain so I'm planning on PGG'ing the original trans when I'm ready for a swap. Oh yeah I also degreased the engine bay. ![]() ![]() |
#3 |
Member#: 158046
NESIC
Vehicle:8/05 C300/2500 HD |
So far so good. Any additional plans beside the above?
#4 |
Member#: 127215
"New motor" getting prepped to go in
![]() Had a friend of mine paint the manifold.....Lil splash of color never hurt anyone. ![]() Motor is in! ![]() ![]() New Drive shaft ![]() BC Coilovers and Rear brakes mounted.....stupid leaky garage ![]() ![]() |
#5 |
Member#: 127215
#6 |
Member#: 127215
Installing HID's in the fogs only and moving my Hella's around
![]() Interior Shot ![]() |
#7 |
Member#: 158046
NESIC
#8 |
Member#: 66622
Vehicle:2002 WRB wrx |
pretty cool man, should be a blast once swapped. I couldnt imagine going from STI to gc power
#9 |
Member#: 127215
Mod List
Suspenion Whiteline ALK Whiteline 22mm N/A Front Sway Bar Whiteline 24mm WRX Rear Sway Bar Whiteline Heavy Duty Rear Sway Mounts Whiteline Front & Rear Sway Bar Endlinks Whiteline Lateral Links Whiteline Rear Strut Tower Bar Whiteline Front Roll Center Adj Kit Whiteline Rear Toe Lock Out Kit Rota Boost 17x8 +48 Tein Front Strut Bar ARP Extended Wheel Studs all around '05 STi Brake Booster & MC Wilwood 6/4 Pot Brake Kit STi Group N Rear Crossmember Bushings ATE Super Blue Brake Fluid New Ebrake Pads STi Lower Control Arm Super Pro GC Lower Control Arm Bushing Super Pro Front & Rear Trailing Arm Bushing New OEM Hardware BC Racing Coilovers OEM Rack & Pinion Hankook K104 245/40/17 MRT Master Cylinder Brace Drivetrain Techna-Fit SS Clutch Line Super Pro Rear Diff Support Bushings Super Pro Rear Diff Bushings Kartboy Trans Crossmember Bushings Drive Shaft Shop Alum Drive Shaft ACT Heavy Duty Clutch Kit Fidanza Flywheel Cusco Motor/ Trans Mount Kit Kartboy Short Shifter Kartboy Front & Rear Shifter Bushings TIC Shift Linkage Update TIC Shifter Pivot Bushing Ixiz Concept Race Pitch Stop OEM Clutch Slave New Axels all around Engine STi Radiator Cap Kartboy Battery Tie Down New gaskets, pumps, belts, seals on the "new" RS motor Perrin Crank Pulley Borla Headers Kartboy Exhaust Hangers AEM Intake Braille Battery '08 Subaru Magnetic Oil Drain Plug OEM Battery Cable Stromung Cat-Back Walbro Fuel Pump Interior Splash Sports Steering Hub Sparco Steering Wheel (Off my old 240sx) OEM Carpet Gutted Rear WRX Pedals STi Spec C Shift Knob Exterior Wingless Trunk Subaru License Plate Bracket Osram Headlight Bulbs McColluch HID's in the Fog Lights EBay STi Fog Light Covers JDM Tail & Corner Lights EBay Clear Side Markers Tein Hood Dampers Last edited by A Guy with a STi; 03-17-2009 at 01:45 PM. |
#10 |
Member#: 127215
#11 |
Member#: 154914
Vehicle:2005 WRX UGM |
sweet man! I love me a clean GC! Mine will be getting there soon too!
#12 |
Member#: 6964
Vehicle:2001 impreza pearl ridge blue |
sick build.... Nice!!!
hey NIce extend lugs studs (5x100) anyway of letting me know some info on thoose... Part #? WHERE YOU GOT THEM ? thanks |
#13 |
Member#: 127215
The part# for the extended studs is ARP-100-7716. I ordered them from summit racing, $39.99 for a pack of 5 studs and they have pretty fast shipping. I would order 5 packs just in case you some how manage to cross threads a few of them.....not that I would know anything about that
. Install on the fronts is pretty easy and straight forward. The rears you're going to have to drill out your abs sensor holes with a 3/4" drill bit (19mm) so you can pass the longer studs through it. Your from LI? I went to Hofstra. |
#14 |
Member#: 127215
I'm trying to troubleshoot an issue I have with the brakes, if anybody has some insight check out my other thread:
http://forums.nasioc.com/forums/show....php?t=1574424 |
#15 | |
Member#: 6964
yeah i am from LI, About 10 mins from Hofstra... I'm located in L-town aka LEVITTOWN! if you're out here...hit me up... want to check out your ride, i've also got some things to finish up here and there with my RSti |
#16 |
Member#: 116691
Vehicle:2001 2.5RS EJ205 Silverthorn |
Very nice progress on the rebuild...I just swapped my rear subframe on an uneven driveway with nothing but hand tools and help from a few of my fraternity brothers haha
And to takumi, I work at the Hofstra bars and go to school out at Stony Brook. I never see any GCs around the Hempstead/Uniondale area... |
#17 | |
Member#: 6964
YOU can say its a trailor queen, well not really... i still have things here and there to finish up on it, I've been trying to do the swap since 02 and final finsh the pass year. its a long story. hopefully after the paint job in the next couple of months, I'll be posting a journal on the car. But ususally i drive it on the weekends.. watch out for me! |
#18 | |
Member#: 127215
Oh yeah its possible, but I also have a knack for breaking things. The rear wasn't that bad and I drilled the holes out after I remounted the rear knuckle assembly. All you have to do is unbolt the caliper, remove the rotor, unbolt your abs sensor, drill the hole out wider to pass the studs through, unbolt your abs tone ring (careful with the allen heads), move the ring off to the side a bit, bang out the old studs, slide the new studs in through the hole, use an open ended lug nut to pull the stud into the hub and presto extended studs! I also would recommend soaking the studs in WD40 and spraying the holes in the hub with brake cleaner or WD prior to installation, makes them slide in a bit easier.
I still have friends out in Franklin Sq so I'm out there from time to time, I'll hit you up once the car is out. Quote:
#19 | |
Member#: 127215
Hofstra bars FTL! Anybody remember Bogarts? lol. But yeah the rear end can be a pain and I had to take it apart twice. +1 for wrenching on your own car, why pay someone to do the work for you when its so easy to do yourself. The money you save not taking it to a shop is more money for mods!
#20 |
Member#: 118560
Vehicle:2002 2.5 RS Aspen White |
that looks like a fun project
#21 |
Member#: 127215
Got the tires mounted, but now I've got more bugs to work out. Starter is on the fritz, fuel pump died and my horns don't work.
Here's some crappy cell pics of the wheel/ tire combo.![]() ![]() Front Tire ![]() Rear Tire ![]() |
#22 |
Member#: 54802
Vehicle:2002 Impreza OBS Project Awessie |
siiiiiiiiiiiiiiiick lol
#23 |
Member#: 162365
Vehicle:06 |
impressive...
#24 |
Member#: 127215
#25 |
Member#: 167129
Vehicle:03 Wagon Mafia Too Low for Nasioc Mb#013 |
looks pretty good... that thing'll be nasty with a STi swap
| Thread Tools | |
| Display Modes | |
| My humble little 2.5RS | m_tee | Member's Car Gallery | 43 | 05-02-2008 11:40 AM |
| Finally, a post of my humble ride | last lemming alive | Member's Car Gallery | 19 | 08-17-2007 11:01 PM |
| My humble 05 STi and 2005 Monza GP F1 | schuey_1 | Member's Car Gallery | 17 | 02-27-2006 11:44 PM |
| My humble wagon | JB1 | Member's Car Gallery | 64 | 07-12-2004 01:57 AM |
| Rut-Ro....my humble ride. | Rut-Ro | Member's Car Gallery | 15 | 10-30-2003 07:13 AM |
