Old 08-12-2008, 09:15 PM   #1
jstam
Member#: 103489
2003 WRX
Undetermined
Default oil pickup tube.
i cut the o ring that goes on the oil pickup tube to the block. and its a SOP from my dealer. wont be in til late friday or monday. can i just use fuji-bond instead of waiting for that part or no?
jstam is offline   Reply With Quote
Old 08-12-2008, 10:13 PM   #2
BlackFlame
Member#: 100082
id wait...
BlackFlame is offline   Reply With Quote
Old 08-12-2008, 10:21 PM   #3
colingilchrist
Member#: 138516
2011 Audi A3 2.0 TDI
Lava Gray
Just use mighty putty...
J/K
colingilchrist is online now   Reply With Quote
Old 08-12-2008, 10:37 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
jigga is offline   Reply With Quote
Old 08-12-2008, 10:39 PM   #5
novacivic
Member#: 117980
2005 sti
wr blue
wait. the last thing you want is your motor sucking air into the oiling system
novacivic is offline   Reply With Quote
Old 08-12-2008, 11:00 PM   #6
Legba
Member#: 88589
2005 STI
the best one
Take the o-ring to the hardware store. If they don't have the right size they can likely make one for you.
Super pickup...
Legba is offline   Reply With Quote
Old 08-13-2008, 07:55 AM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
i would wait.
LiquidForce is offline   Reply With Quote
Old 08-13-2008, 11:08 AM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
When I used to have an oil pick up tube I would always use a new O'ring and a little fuji bond, you can't be too carfull with that one.
mick_the_ginge is offline   Reply With Quote
Old 08-13-2008, 12:21 PM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
*getting overcome by jealousy all of a sudden*
Old 08-13-2008, 02:01 PM   #10
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
ditto !
sense of nature is offline   Reply With Quote
Old 08-14-2008, 10:38 PM   #11
Legba
Member#: 88589
2005 STI
the best one
um yeah
Old 08-14-2008, 11:10 PM   #12
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Originally Posted by Legba View Post
um yeah
I don't run a pick up tube, I just let the oil swish around in the pan
Old 08-15-2008, 01:42 PM   #13
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
um yeah
two words... dry sump...
Old 08-29-2008, 10:53 PM   #14
Legba
Member#: 88589
2005 STI
the best one
Mach V http://www.fastwrx.com will be stocking these soon.
The improved tube section is over 3 times the thickness of the stock tube, it's tig welded at the flange and since it's made from a stock pickup the fit and functionality are the same as from the factory. I have one in my car and worry no more.
Old 09-02-2008, 12:27 PM   #15
charliew
Member#: 125304
After putting any pickup on my motor I always put tape over the inlet and use modelers clay to check the clearance between it and the pan. You will be surprised at the variances on the clearance. Especially if you've ever jacked the motor up by pushing on the bottom of the pan.
charliew is offline   Reply With Quote
Old 09-02-2008, 05:17 PM   #16
Legba
Member#: 88589
2005 STI
the best one
Charliew, I was concerned about that as well after a few had told the that thier factory one was rubbing the pan. The pickups (that I've made, see post #14) are a wee bit shorter than factoy ones to accomodate that scenario.
Old 09-02-2008, 06:17 PM   #17
jays05
Member#: 78165
05 STI 35r + e85
Charliew I believe that variance in pan/pickup depth is exactly why Moroso included a pickup tube with their pan.
jays05 is offline   Reply With Quote
Old 09-02-2008, 11:24 PM   #18
Legba
Member#: 88589
2005 STI
the best one
IMO the Cosworth is a better unit for the price. The Moroso only holds 1/2 quart more than stock. Don't get me wrong here, I typically like Moroso components and that oil pan sure is sexy, but their pickup looks like it was fabricated by drunken sailors.
Old 09-03-2008, 01:25 AM   #19
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
does the cosworth unit work with twin scroll exhaust manifolds though?
Old 09-03-2008, 04:44 PM   #20
Legba
Member#: 88589
2005 STI
the best one
jigga I have no idea, but I do know that both of them have incompatability issues with certain manifolds. The factory pan is quite good, and IMO if you don't see a lot of track time there is no reason to change it.
Old 09-04-2008, 06:45 AM   #21
Legba
Member#: 88589
2005 STI
the best one
For anyone interested...
http://www.fastwrx.com/upoilpitu.html
Old 09-04-2008, 08:03 AM   #22
nicad
Member#: 33971
2006 WRX
I've done some pretty badass stuff while drunk!
nicad is offline   Reply With Quote
Old 09-04-2008, 09:26 AM   #23
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
good golly!!
they want $229 for essentially sleeving (outside) the factory tube...no bigger but just stiffer. I'll bust out my tig and 3 strips of steel and welding them down the sides
Ok, but really I'm already working on a larger pick-up. so ignore me
Old 09-04-2008, 11:21 AM   #24
Legba
Member#: 88589
2005 STI
the best one
I've said this before, but just for fun here goes again. There is no point to having a larger diameter pickup because the pickup is not the smallest restriction in the oiling system. Having a larger diameted can or tube only adds more volume of oil into the pickup and out of the pan, where it should be, increasing (marginally) your chances for oil starvation. The can itself cannot be made bigger because there is just no room to spare in the bottom of the pan. Subaru added the "restriction" to the bottom of the can (04-05 STI and ALL Impreza/Legacy models from 2006 and on) with dimples because the can is so close (and sometimes rubs the bottom or sides of the pan) that there is potentially a risk of sucking against the bottom of the pan creating a restriction.
If you're going to mock one up yourself just keep in mind that there are good reasons the Subaru engineers made this part the way it is. They fail because of a manufacturing process defect not a design flaw.
Old 09-04-2008, 02:56 PM   #25
Homemade WRX
Member#: 33782
96 bastard child
Yes, manufacturing killed that newer age pickups that have plagued a few...and the tolerance between the pan and pickup are too close (hence your dimple explanation)...those are both common knowledge.
Now for my comment: sorry, when I said larger I wasn't referring to tube size (I mislead, sorry)...I'm working on a complete wetsump oil system with a bigger pan where a larger "can" (re-shaped) is beneficial.
As for having a larger tube I can argue that with the larger tube, the pipe flow losses are reduced, thus reducing the pumping losses on the oilpump and ultimately crank thus yielding a power gain
or something like that
oil pickup tube failure thread unclemat Warranty Issues & SOA Problems 851 04-12-2016 10:37 AM
Oil pickup tube failure mikeb01453 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-24-2009 09:39 AM
Oil pickup tube torque spec? LeeC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-11-2008 12:15 PM
Oil pickup tube torque spec? LeeC Built Motor Discussion 0 07-24-2008 05:54 PM
oil pickup tube, need help asap please ihadmail Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-10-2008 11:25 PM
