Old 08-12-2008, 09:56 PM   #1
Taras
Member#: 146018
Default 08 Spec.b Tire pressure light after putting after maket wheels
Got new wheels and now the light is blinking. What should i do? How to turn it off.
Thanks, Taras
Taras is offline   Reply With Quote
Old 08-12-2008, 10:03 PM   #2
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
you have to have the sensors reset at the dealership...unless they didn't put the tire pressure monitoring sensors back onto the new wheels...they would have had to dismount your old tires/rims to get to the sensors...or if they did put sensors on your new wheels...then they need to be calibrated at the dealership..
Bill
Old 08-12-2008, 10:34 PM   #3
Taras
Member#: 146018
I put the wheels on myself. So would i have to get new sensors installed onto the new wheels? I just want to turn the light off and not even worry about it. Those sensors are useless.
Old 08-12-2008, 10:47 PM   #4
codean
Member#: 10186
tape...
No really.... take the cluster out and put tape over the led.
Did it to my 07 spec b when I had it.
codean is offline   Reply With Quote
Old 08-12-2008, 11:00 PM   #5
Taras
Member#: 146018
Originally Posted by codean View Post
tape...
Might have to do it.
Old 08-13-2008, 12:21 AM   #6
rs6er
Member#: 55660
2007 Legacy SpecB
I have Blizzaks on Rota Tarmac 2's for my winter tire. I just ignore the light during the winter. I barely see it. If it bothered me I'd put a piece of tape over it too.
rs6er is offline   Reply With Quote
Old 08-13-2008, 12:36 AM   #7
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
Unfortunatley it's illegal to disable that useless system (thanks firestone)
snovvbrdr is offline   Reply With Quote
Old 08-13-2008, 08:54 AM   #8
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Not the threadjack........ but for those of you that switch tires in the winter on your specB what size rims are you using?
I have a set of 17" Rota Subzero's off of my 02 WRX that I was gonna throw some winter tires on and bolt up to my specB for winter.
Will they clear the brakes?
Also I have heard of the different size rims throwing off the speedo, is this true? If so I will go with a 50 series sidewall and hopefully come pretty close to the same circumference.
Thanks!
RALLYT-WRX is offline   Reply With Quote
Old 08-13-2008, 10:18 AM   #9
T WReX
Member#: 179377
08 WRX
Om Nom Nom
Only thing that will affect the speedo is the circumference of the contact patch of the tire. In fact, wearing down your tread even affects it to some extent (you're actually traveling a shorter distance per wheel revolution on smaller tread). Speedo works on wheel revolutions x adjustment constant based on contact patch circumference.
T WReX is offline   Reply With Quote
Old 08-13-2008, 11:58 AM   #10
Tire Rack Moderator
Member#: 1215
ext. 4362
you need to get a set of sensors in order for the systm to operate properly. You could take the sensors from your other wheels and install them in the new wheels providing they are designed to accept them. If you opt for new sensors you will need to have them activated by a Subaru dealership. And as state dbefore it is illegal to disable the system
Luke@tirerack is online now   Reply With Quote
Old 08-14-2008, 12:07 AM   #11
Taras
Member#: 146018
how much are the sensors?
Old 08-14-2008, 12:23 AM   #12
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Discount Tire has them for around $60 apiece.
Dirtyhobo010 is offline   Reply With Quote
Old 08-14-2008, 09:17 AM   #13
waktasz
Member#: 86356
2015 s1000r
wheelie monster
It's illegal to do a lot of mods to your car.
waktasz is offline   Reply With Quote
Old 08-14-2008, 11:42 AM   #14
Tire Rack Moderator
Member#: 1215
ext. 4362
it's not really Firestones fault ... it's the Government and their 'tread act' legislation which was enacted after the Ford Explorer / Firestone issues but, that was more of a Ford issue than a Firestone issue. Considering the limited amount of info realeased to the public I can understand why your initial thought would be Firestone but, that is not where a majority of the blame belongs.
Old 08-14-2008, 11:44 AM   #15
Tire Rack Moderator
Member#: 1215
ext. 4362
At The Tire rack they are either $45.00 or $43.00 each depending upon which one you need, as ther are two different versions.
1 note you should remember ... not all wheels are designed to properly accept the sensors so, verify compatibility before you purchase anything
call me if you need them
Old 08-14-2008, 01:11 PM   #16
vica153
Member#: 76586
2006 9-2x Aero
LOL this reminded me of "With all due respect....." from talledega nights.
vica153 is offline   Reply With Quote
oil pressure light turned on after going threw a puddle greco2030 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-14-2011 12:17 AM
Canadian 08+ STIs and tire pressure monitoring system (TPMS) j y Vancouver Impreza Club Forum -- VIC 6 09-01-2009 12:04 PM
Tire pressure light in 2008 WRX Troa Service & Maintenance 9 07-06-2008 06:56 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 10:33 PM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 06:12 PM
