Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-11-2002, 01:04 PM   #1
WRxednEffect
Member#: 13105
Default going to dyno at tapps tommrow
ill be their at 1, come if u like
WRxednEffect is offline   Reply With Quote
Old 03-11-2002, 01:37 PM   #2
SubaruStu
Member#: 8972
2003 WRX Wagon
Tapps is off Merivale @ Cleopatra? I don't think that I can get
away from work. Too Bad.
FWIW, a friend had his new 255HP Maxima done there. He was
disappointed to get 199. I haven't spoken to him lately about
why it was so low (HP overated?, Dyno wrong, ????). Over 20%
loss for a FWD car is kind of suspicious.
Good Luck!
Stu
SubaruStu is offline   Reply With Quote
Old 03-11-2002, 01:43 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Default Here's a map......
I'll probably show up...... working from home tomorrow....
Robin
Robin2 is offline   Reply With Quote
Old 03-11-2002, 09:31 PM   #4
bingo
Member#: 13665
2004 sti
rally blue
Hey guys,
I am from Montreal and know nothing of this company. They have a 4 wheel dyno? What do they charge per hour?
Thanks
bingo is offline   Reply With Quote
Old 03-12-2002, 12:25 AM   #5
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
AFAIK there are no 4WD dynos in Canada yet. Take the car to Lachute Subaru and in about 2 hours they can swap your centre diff for one that turns your car into a FWD. You dyno that and then swap the original diff back in to drive it.
-Michael
d00f is offline   Reply With Quote
Old 03-12-2002, 12:29 AM   #6
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
hey i work 2 minutes from there. Too bad I work from 10am to 10pm.
Good luck.
Stefan
Freeskier is offline   Reply With Quote
Old 03-12-2002, 07:52 AM   #7
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Good luck.
Stefan
Have you changed location? No longer at the end location?
Robin
Old 03-12-2002, 08:31 AM   #8
SubaruStu
Member#: 8972
2003 WRX Wagon
Good luck.
Stefan
You work at the Silver Dollar?
Old 03-12-2002, 08:32 AM   #9
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
HEHE! I remember that dump! We used to go there after work (Costco)....
Robin
Old 03-12-2002, 08:33 AM   #10
SubaruStu
Member#: 8972
2003 WRX Wagon
-Michael
Actually there are a couple, but they are not open to the public,
which basically amounts to the same thing. It is looking pretty
promising that there will be one in Toronto sometime this
summer and there are rumours of another one gong in out west
in Vancouver as well.
Stu
Old 03-12-2002, 10:33 AM   #11
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Have you changed location? No longer at the east end location?
Yes Robin, I got transfered a month ago.
Old 03-12-2002, 10:37 PM   #12
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
How was the dyno session, post your results here.... I'll show you mine if you show me yours.
JoeT is offline   Reply With Quote
Old 03-13-2002, 09:20 AM   #13
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Default Here's a pic...
This was at Tapp's yesterday......
Robin
Old 03-13-2002, 10:18 AM   #14
d00f
Member#: 6000
BRP
210RWhp is the best I saw. If the stock unit has 185 at the wheels then that's 42hp drivetrain loss so 252hp with Tom's car. I may also note that Ben fixed the high EGT problem.
-Michael
Old 03-13-2002, 10:10 PM   #15
WRxednEffect
Member#: 13105
bad meaningless post
Old 03-13-2002, 10:12 PM   #16
WRxednEffect
Member#: 13105
Well, after 9 hrs labour with lachute, 150 bux to tapp, a full day of driving and eating ****ty take out food; i got tuned. Everything went as planned, except me getting lost twice. Strapper her to the dyno and gave er the gears. FIrst pull was 190, we eventually got it up to 210whp with 15pds of boost and tuned saftly and with good det margins. Car runs very strong as it should. My egts barely get over 1500 and only for a second in third now, i have better mpg and its faster. Knock corretion averages about 8 degrees or so. From what im told wrx's generally dyno at 175 at the wheels stock,so this is a healthy bump. Im sure im hitting 215whp, my tires are oversized in diamter, i read somewhere that makes a slight difference. But i dont really care. We could of gone more, but i felt their was no need for more power. I have dyno sheets, but i forgot them in ottawa! SO LETS SAY 215hp, 210 torque over the board. I got boost at 2800 and full at 3100. Im not sure what that translates into crank hp, but im guessin 250ish - 255ish. I dont know how much i lose to drivetrain. It was also dyno'd in rwd
although if that equates to 255, then maybe i lost the 5 hp from my tires.
Old 03-14-2002, 10:13 AM   #17
STI RDY
Member#: 5738
2002 WRX Sedan
Sedona Red Pearl
I was told that the guys at Tapp Auto are the authorized Unichip tuner for Porsche. So, they know what they are doing and looks like they are really good (they out-tuned Shiv in this case, right?). Great to have such resource locally!
Wonder if they will ever invest in a 4 wheel dyno...
STI RDY is offline   Reply With Quote
Old 03-14-2002, 12:56 PM   #18
WRxednEffect
Member#: 13105
Well it turns out I was a bit misinformed, i thought their were some map changes made but i guess not, their were only slight ones made. But not 10hp worth.. I spoke with shiv today, he called lachute and they told him all was good. I dont mean to slanderize or dicredit shiv. But if no maps were changed than im kinda a dumbass .... Turned out my first run was at 14 psi. You really do have to watch what u post, in my case the first run wasnt really a good one. So dont bother with it. Vishnu has been nothing but helpful, they respond quickly and are always willing to help. A HUGE THANKS to shiv, joel, ben and julian. I just wanted to set the record straight.
Old 03-14-2002, 10:57 PM   #19
NIL8GM
Member#: 14574
2002 WRX sedan
WR Blue
Just curious how you dynoed on a 2 wheel dyno. Did you change the center section?? If so how long did that take and where did you get it from?? Did you use Tapps wide band O2?? If so what were the AF ratios at WOT??
Thanks
Rick
NIL8GM is offline   Reply With Quote
Old 03-15-2002, 01:37 AM   #20
WRxednEffect
Member#: 13105
they change the centre diff, and ya i used tapps dyno but used bens motec wideband
Anyone going to be at the on snow demo at snowbasin this week? toddguy Rocky Mountains Impreza Club Forum -- RMIC 3 02-02-2009 01:34 AM
Anyone in the North West Area Going to Dyno Day? superblkwrx South West Impreza Club Forum -- SWIC 0 11-17-2006 06:45 PM
Where to go to Dyno? mossie4 North West Impreza Club Forum -- NWIC 3 07-13-2005 09:32 AM
Anybody from New Castle area going to dyno days? 20024door Mid Atlantic Impreza Club -- MAIC 4 02-05-2005 01:11 AM
So, who again, is going to be at Sears tomorrow to RACE? 98kPa Bay Area Impreza Club Forum -- BAIC 3 09-07-2002 12:11 PM
