Old 08-14-2008, 11:25 AM   #1
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
Default Lamco Oil Temp gauge not reading after oil change
I have the factory Lamco oil temp gauge and it's no longer reading. I changed my oil last night and the only thing different is I used a plastic/nylon crush washer. Do I need a copper one for the temperature sender to work, or is it possible I have a bad sender?
Impreza WR Rex is offline   Reply With Quote
Old 08-14-2008, 11:11 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The sensor grounds through the drain plug and oil pan, so you can't use a nonmetallic washer. Use either an OEM crush washer or a copper one.
Old 08-15-2008, 10:19 AM   #3
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
Found the solution last night. It seems the plastic crush washer doesn't matter. I went under the car and checked the wires for any shorts. Then I went inside and smacked the gauge with my palm a few times and it started working again.
FS NY: Lamco Voltmeter Gauge, Lamco Oil Temp Gauge, Lamco Wiring woody06967 Interior/Dressup/Audio & Security 1 11-17-2010 02:17 PM
Coolant Temp gauge not reading badchad Legacy Forum 6 07-16-2008 12:32 AM
Oil temp gauge not working theo79 Electrical & Lighting 1 10-03-2007 09:35 PM
Transmission Temp gauge not reading? cjx17 Transmission (AT/MT) & Driveline 3 06-12-2007 11:47 AM
oil temp gauge not working correctly? Penguinking Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-21-2002 07:22 PM
