Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Canada Region Vendor Classifieds
Old 08-14-2008, 10:39 AM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE and Whiteline(Dales Alignment is now a distributor) suspension pre-order.
We are now taking orders for RCE tarmac II and Tarmac Zero coilovers. This also includes anything under the KW brand. Estimated delivery time is 6wks from initial order. I have decided to do increased bulk orders in order to save on shipping costs and delivery time.
Racecomp Engineering Tarmac Zero Coilovers, our new more affordable coilover entry based on our highly successful RCE Tarmac 2s.
Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course.
Linear spring rates:
400 lbs/in front
340 lbs/in rear
Front and rear helper springs included. Can be used with camber plates or Group N strut top mounts.
Racecomp Engineering Swaybars Another option for GD Impreza owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
The settings for the front are 25.5 and 28.5mm.
Rear are 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
Racecomp Engineering Tarmac II Coilovers
Separate bump and rebound adjustability
500 lbs/in front and 400 lbs/in rear spring rates
Custom spring rates available
ASSEMBLED AND PRESET RIDE HEIGHT AND DAMPING
We are now a distributor for Whiteline suspension products
The first major order is going in this Friday. We already have 04+STi and WRX swaybars, bushings etc. in transit or in stock but if there is anything else please let us know.
MY08 STI and WRX suspension products from Whiteline such as swaybars, stressbars, bushings etc. are now available. I will have different pieces coming with the first shipment but call us if you need something.
Jason
www.dalesalignment.com
www.dalesmotorsport.com
dalesalignment&brake is offline   Reply With Quote
RCE SWAYBARS!!!! Pre-order now!!!!! Turn in Concepts Suspension/Brakes/Handling 4 12-01-2008 03:30 PM
RCE and Whiteline(Dales Alignment is now a distributor) suspension pre-order. dalesalignment&brake VIC Vendor Classifieds 1 08-13-2008 04:24 PM
Happy Holidays from RCE....and what do you want for your suspension for x-mas? RaceComp Engineering Brakes, Steering & Suspension 32 12-25-2004 08:49 PM
My new Clutch and Fly wheel is now in! yebokmj New England Impreza Club Forum -- NESIC 3 08-20-2001 09:26 PM
when is it too late to pre-order? whiteWRX WRX Forum Archive 5 02-11-2001 10:42 AM
