Old 08-14-2008, 02:59 PM   #1
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Default JDM STI ECU: What pin is "Ignition Switch?"
Hi,
I am wiring up an 02 JDM STI engine in a 98 2.5RS. I have the service manual for the rest of world (not japan) STI from that year. I also found a site online that has the pinout from the JDM STi but its not an official document.
The question is, which pin on the ECU is from the ignition switch?
The service manual says B134 pin 14. But the other document says that is the "Test Mode Connector" and that the wire is orange. Another inconstancy is that service manual has "Test mode connector" as pin 5 on B134 and the other doc does not list a connection but has the wire color as green/red.
If you have the service manual or the "Engine Control Module (ECM) I/O Signal" section of the manual (English preferred but Japanese is OK too) that would help me a lot.
Some information about the donor car.
Model: GDBA4EH
Engine: EJ207DW3CR
Transmission: TY856WB1CA
Thanks a lot.
johnpaul76 is offline   Reply With Quote
Old 08-15-2008, 02:40 AM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Ignition switch - B134 pin 5
Test mode connector - b134 pin 14
http://www.northursalia.com/modifica...ng/wrxpin.html
I know this site it right becuase my V7 STi ecu works fine.
RS_to_WRX_swap is offline   Reply With Quote
Old 08-15-2008, 10:27 AM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
134 pin 5 is power from the fuse box going to the fuel pump relay, ecu and coils. Pin 14 is the test mode which would go to the orange test mode wire coming off of your ECU.
Z
Zephyr is offline   Reply With Quote
Old 08-15-2008, 11:44 AM   #4
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Thanks a lot. That makes sense. I wanted to check before I put 12V where it wasn't supposed to be.
One last question, Is B135 pin 9 (Sensor power supply) an input or an output?
Thanks a lot for your help.
Old 08-15-2008, 03:56 PM   #5
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I belive thats how the engine sensors get power from the ECU, so its an output.
Old 08-15-2008, 06:24 PM   #6
silentt
Member#: 119995
2004 Outback XT
Peachy
It's a 5V power supply for the sensors.
Hi,
Orange = Test Mode Connector
Green/Red = Ignition switch.
silentt is offline   Reply With Quote
Old 08-17-2008, 09:59 PM   #7
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Thanks a lot for the all the responses. That worked. The car started. Add another RSTi to the list. Now to find out why its burning oil.
Old 08-17-2008, 10:09 PM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
Oil could have seeped into the seals due to the engine sitting for a while. Drive around for a few days then check to see if it is still burning oil. If so...
Old 09-07-2008, 12:08 PM   #9
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Just thought I post an update on the oil issue. Turns out that either the car was rolled or the clip was placed on its side at some point so there was oil in the heat sheilds and that was burning off. So, no majors problems with oil.
Old 07-05-2009, 04:57 PM   #10
arnephie
Member#: 216156
2004 Subaru
red orange
arnephie is offline   Reply With Quote
Old 07-05-2009, 07:16 PM   #11
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Hi,
The STi addendum is here:
http://pdftown.com/PDF-Subaru-Imprez...ce-Manual.html
and the Wrx service manual is here:
http://pdftown.com/Impreza-WRX-2002-Service-Manual.html
Also, I found the 2004 manual here
All of them have the wiring diagrams. I think they are for the European spec impreza but 99% of the wires are correct. I used them to wire my car. For the rest, I pumped this site through google translate.
http://impreza.pekori.jp/gdb_tuning/gd_tuning34.html
It requires some interpretation, but the information is there.
What are car are you starting with and what are you putting in it? I can help you out if you need.
Old 07-14-2009, 01:08 PM   #12
bluetaxi
Member#: 170504
2003 STI ver 8 JDM
John,
TQ! for the link to the JDM ECU. but do u know where to find the GDB-E/F ECU pinout?? I think there is some diffrent between the GDB-C/D.
bluetaxi is offline   Reply With Quote
Old 07-14-2009, 03:05 PM   #13
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Hi,
Sorry, I don't know where to find an E/F pinout. The diagrams above were what I used with my GDB-A. Some of the wires that I wasn't 100% sure about I traced by hand. It was a pain, but worth it.
JDM STI V8 Steering wheel with colum, switchs etc.. s3n3ch Interior/Dressup/Audio & Security 2 10-02-2009 11:59 PM
2005 JDM STi Power Folding Mirrors WITH RARE Switch! rallyespec Exterior/Styling 22 07-30-2009 03:45 PM
2002 wrx with 05 sti motor...WHAT SUSPENSION IS NEEDED. BigEag205 Subaru Conversions 4 04-10-2009 12:34 AM
JDM STi Headlight Leveling Switch 6-pin mca Private 'For Sale' Classifieds 1 02-26-2004 02:17 AM
STi gurus: What turbo is on it? Texas25RS STi Forum Archive 1 04-30-2003 06:48 PM
