Old 08-15-2008, 07:38 PM   #26
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
That would be tough to get, as for it to REALLY be a real worthwhile comparison, it would have to be the same car, on the same dyno. But its been well documented that up to about 100 octane (slightly higher, but 100 is the rule of thumb) produces gains.
Anyone that questions it, needs to try it some time. Then go read my "if someone posts a question, should you answer it" thread
Basically if they say it does nothing, then they almost 100% chance have no firsthand experience with it. That or they are expecting WAY more than it will give. If you are expecting HUGE power, you will obviously be dissapointed.
But its simple black and white stuff. Run a car on 93 pump (even 94) and datalog the ignition advance multiplier. It wont be maxed out. Now run that same car on 100 octane, and datalog it, and see how much more timing you are getting. More timing=more power (to a point, and in this case, you can say that timing=power)
The gains are definately a lot bigger if you tune for the 100 though.
Defiant Autospeed is offline   Reply With Quote
Old 08-16-2008, 12:35 AM   #27
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Originally Posted by CynicX View Post
Oh and I recommend Unabomber taking all of this information, putting his name on it, placing it in the manifesto and deleting this thread... jk...Good work Davenow...
4wdrift is offline   Reply With Quote
Old 08-16-2008, 01:56 AM   #28
GearHead27
Member#: 172252
2005 Saab 9-2x Aero
Desert Silver
Nice job! It's already taught me a few tings I didn't know before.
GearHead27 is offline   Reply With Quote
Old 08-16-2008, 10:25 AM   #29
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Saturday is a BUSY day for me, likely no updates today.
But more updates will be coming
Old 08-16-2008, 11:09 AM   #30
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
can you tell me if PE510cc's are the same as sti pink 565cc's?
what injector size is recommended for a big 18g with upgraded top mount and stage 2 on a 2.0?
ez
jake
maxpowr is offline   Reply With Quote
Old 08-16-2008, 11:50 AM   #31
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
They arent the same.
650s would be fine, 750s would give you more headroom.
And I recommend Deatschwerks over all of them
Sorry for being so breif, Im swamped right now.
Old 08-16-2008, 03:36 PM   #32
el_guapo
Member#: 132038
funk er chicks
serious bidness
Good info, I didn't know about the ocatane thing myself.
I think one topic that is a must for the thread is the OL / CL topic aka "Which cars can run downpipes safely without tunes?" etc... I see this question in here almost every day in some form or fashion.
el_guapo is offline   Reply With Quote
Old 08-17-2008, 02:47 PM   #33
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
02-03 WRX
04 STI
05 STI
Beyond that, EM is a must. Even then, you will see BIG benefits from a good tune.
I will add it in in a bit
Old 08-17-2008, 05:11 PM   #34
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
answered my question. so 510's won't support the big 18g how bout a big 16g?
Old 08-17-2008, 05:27 PM   #35
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Pinks are 565 and barely support a normal 16G if you run a good amount of boost.
FYI a "big 16G" is only a hair smaller than an 18G.
16G=35lb compressor wheel
big 16G=37lb compressor wheel
EVOIII 16G=39lb compressor wheel
18G=40lb compressor wheel. No such thing as a big or small 18G. Just proper 18G in the larger compressor housing, and a cheap garbage 18G in the small compressor housing. Both use the same compressor wheel.
On the big 16G, my advice would be dont bother with it. Either do a normal 16G, or do an EVOIII 16G. The "big 16G" doesnt get you much more power, but it does get you less than the EVOIII. Basically a big 16G wont make power you will really see on a dyno over the normal 16G, but the EVOIII will make a good bit more.
Why am I not saying skip that for an 18G if they are only 1lb apart? Because the EVOIII16G has long been established as an AWESOME turbo for a 2.0L Its pretty much the ultimate street turbo for a 2.0L. On the 2.5L the 18G is the smallest to do really.
Its not just the compressor wheel, there is a little more to it, efficiency and such for the motor size. The EVOIII16G uses the small compressor housing, and while I think that wheel would probably work better in the larger compressor housing, it has proven itself in the current configuration over and over when it comes to performing on the 2.0L motors.
Old 08-17-2008, 07:19 PM   #36
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you have become a friend request
Old 08-17-2008, 07:35 PM   #37
Miercoles Cansado
Member#: 166820
my ignore list
Very nice! You managed to cover a lot of basic info.
Miercoles Cansado is offline   Reply With Quote
Old 08-17-2008, 10:10 PM   #38
MF Goon
Member#: 121408
2002 Impreza WRX
Silver w/ a few bolt-ons
great great great write-up!
nice job sir!
MF Goon is offline   Reply With Quote
Old 08-17-2008, 10:55 PM   #39
hypoxvi
Member#: 173002
I'm pretty sure the OEM up pipes don't have a flex section in them. If I read correctly, that's what you were trying to say.
hypoxvi is offline   Reply With Quote
Old 08-17-2008, 11:03 PM   #40
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Umm... No. They do have a flex section.
RP31 is offline   Reply With Quote
Old 08-19-2008, 08:31 AM   #41
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
I think this needs to be addressed: TD04 on 06-07 WRX's DO NOT creep, they spike, big difference.
cucamelsmd15 is offline   Reply With Quote
Old 08-19-2008, 09:10 AM   #42
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
They also gag cough and wheeze on a motor about 2x too big for them
Old 08-19-2008, 09:11 AM   #43
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
They do. Its there, and its aweful.
Old 08-19-2008, 09:29 AM   #44
cucamelsmd15
Member#: 122980
Well, yeah, of course.
Old 08-19-2008, 09:48 AM   #45
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I am thinking I am going to add something about what size injector for what setup. That will have to be a "guidelines" type thing, since there is a bit of a range, but at least it may help some people decide.
Old 08-19-2008, 11:59 AM   #46
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Please Do.
Old 08-19-2008, 12:19 PM   #47
wrxgeneration
Member#: 170790
2006 wrx cobb stg. 2
cgm
Couldn't have done better, this is an awesome write up for the nubes.
wrxgeneration is offline   Reply With Quote
Old 08-21-2008, 04:05 PM   #48
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Still working on getting a minute to update it..
Old 08-21-2008, 04:08 PM   #49
Burnsi477
Member#: 176677
2002 WRX WAGON
Midnight Black
thanks guys
Burnsi477 is offline   Reply With Quote
Old 08-21-2008, 04:18 PM   #50
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
So if I drive up to the local Sunoco 100 octane pump and drop a c-note, I can expect 10-15 more whp? What about on track? Is this safe on a stock motor?
Zebe is offline   Reply With Quote
BOV FAQ: The REAL dirt on BOVs. Ups AND downs. Lets dispell some myths. Davenow Newbies & FAQs 792 09-11-2016 11:57 PM
please help me answer a few AP questions about doing a turbo njhxc27 AccessPort 3 05-05-2010 02:12 AM
Dispell the myth. RS and WRX wheels are the same for the 05 but.... 3DF Tire & Wheel 10 07-07-2005 09:34 PM
Questions and Need Some Help impr25rs Brakes, Steering & Suspension 2 05-30-2004 11:48 PM
Bay Area WRXers - Questions and maybe some Help!? lionfish42 Bay Area Impreza Club Forum -- BAIC 20 01-09-2004 04:45 PM
