Mid Atlantic Impreza Club
Old 08-15-2008, 03:06 PM   #1
Steveman86
Member#: 169581
2008 WRX
gray Perrin stage 1
Default 04 WRX uppipe down pipe into an 08 WRX
My friend just parted out his 04 WRX and Im interested in getting some parts from him. I was told that the 08 WRX needs a longer down pipe so that wont fit, so will the up pipe fit in my car?
Also, i just ordered perrin's stage I APv2 and is going to upload their custom map for stage 1 this weekend. If i install the up pipe, can I drive with it on a stage 1 map until I get the full tbe and go stage II?
Steveman86 is offline   Reply With Quote
Old 08-15-2008, 03:09 PM   #2
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Stage 1 AccessPORT used to be no modifications necessary at all.
I don't think the '08 has a catted uppipe so there should be no reason to replace your stock uppipe.
Jard is offline   Reply With Quote
Old 08-15-2008, 06:15 PM   #3
drwrx
Member#: 50891
You do NOT need the up-pipe.
If your looking to get a down-pipe but still want to have a cat in the system Daddys has a shorty down-pipe for the 08 WRX (and LGT) for $239. You will get a CEL, but that is defeatable.
http://www.daddysscp.com/dcart4/prod...1&cat=6&page=1
drwrx is offline   Reply With Quote
Old 08-15-2008, 07:45 PM   #4
RLR257
Member#: 176667
2006 AW WRX Ltd
PPG'd EWG'd & Dom3'd(XTR)
yea you don't NEED the uppipe like others have said, but replacing the uppipe on the 06-07 wrx (with no cat in the stock uppipe) gives you about 10whp w/o a tune. aftermarket uppipes have a larger diameter than the stock one. See David Buscher's thread.
however, i'm not sure about the size of the 08 uppipe.
RLR257 is offline   Reply With Quote
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 08:57 AM
6 spd from an 08/09 STi into an '08 WRX silentrite Subaru Conversions 2 07-30-2009 05:56 PM
Installing an 08 Sti fuel pump into an 02 WRX Vlad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-26-2009 09:55 PM
What's the Diameter of the stock down pipe on a 08 WRX? 02bugeyeFTW Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-25-2009 05:29 PM
Will an 04 sti airbag swap directly into an 03 wrx steering wheel? Nettalp Newbies & FAQs 1 01-27-2006 06:51 PM
