Old 08-15-2008, 04:51 PM   #1
Spitfire999
Member#: 143011
2012 128i M-sport
Default Access help...can't figure this out...
This is probably really easy, but here is the deal. I have an input form and it has one field where you input a $ value. The engineering guys like to pretend this field isn't there...I want to remind them to fill it out when they don't.
So, when I click the exit button, if that field is blank, I want a message to pop up and say please put something in there.
Private Sub CloseForm_Click()
_________________________________
If Final_Price_$ = "" Or IsNull(Final_Price_$) Then
MsgBox "Need pricePrice"
End If
__________________________________
On Error GoTo Err_CloseForm_Click
DoCmd.Close
Exit_CloseForm_Click:
Exit Sub
Err_CloseForm_Click:
MsgBox Err.Description
Resume Exit_CloseForm_Click
End Sub
The part sectioned off is the code I am working on. At the moment when I run that it will always display the message even if it is filled in and then skip to the would you like to save input changes window (I think I may need to use the .setfocus if it is blank).
Final_Price_$ is the name of the input box btw.
Help would be great
Thanks
Ben
Spitfire999 is offline   Reply With Quote
Old 08-15-2008, 05:01 PM   #2
charlie_tuna
Member#: 101713
2001 F-150
Work Truck White
I'm not totally up on my VB, but I think that "IsNull(Final_Price_$)" is not the right logical test.
charlie_tuna is offline   Reply With Quote
Old 08-15-2008, 05:09 PM   #3
imprezton
Member#: 22958
2008 She cheat me
and taked my salts!-Crees
Code:
Goto EndSubWithoutClosing
End If
DoCmd.Close
Exit Sub
EndSubWithoutClosing:
End Sub
Your message logic is fine. The problem is that you do nothing to preven the close operation after you've raised the message.
imprezton is offline   Reply With Quote
Old 08-15-2008, 05:14 PM   #4
Spitfire999
Member#: 143011
2012 128i M-sport
Originally Posted by imprezton View Post
Code:
End If
DoCmd.Close
Exit Sub
End Sub
I felt like my logic was correct as well, but it always displays the message, even if "Final_price_$" is not equal to null.
Old 08-15-2008, 06:04 PM   #5
imprezton
Member#: 22958
2008 She cheat me
Then try this:
Code:
If Final_Price_$ = "" Then
Else if IsNull(Final_Price_$) Then
End If
End If
DoCmd.Close
Exit Sub
End Sub
Old 08-15-2008, 06:18 PM   #6
imprezton
Member#: 22958
2008 She cheat me
Or this:
Code:
If Final_Price_$ = "" Or Final_Price_$ Is Null Then
End If
DoCmd.Close
Exit Sub
End Sub
Old 08-15-2008, 06:56 PM   #7
pgtkid
Member#: 32810
2006 Impreza 2.5i
Sandstone Metallic
Is the input box connected to a table to which you input that data youre requesting?
If so just go into the table and make that field a required field and access will generate an automated prompt no to leave that field empty.
pgtkid is offline   Reply With Quote
I can't figure this out | Power steering pump problem. Hyelude Factory 2.0L Turbo Powertrain 2 07-27-2009 12:56 PM
Overheating at low revs. New Thermostat, HG, and waterpump. I can't figure this out. Surestick Normally Aspirated Powertrain 48 07-16-2009 05:38 PM
Oh crap i can't figure this out and I'm teaching it tomorrow Gerkins31 Off-Topic 32 10-09-2007 11:44 AM
ok im sick of this noise, please somebody help me figure this out. BoneStock03 Transmission (AT/MT) & Driveline 2 06-19-2006 02:23 PM
arggggg! Can't figure this out! (recording streaming vid) biggreen96 Off-Topic 4 10-27-2005 05:52 PM
Message Board Statistics All times are GMT -4. The time now is 10:42 AM.
