Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 08-16-2008, 11:54 AM   #1
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Smile chris's 03 bug eye build 550+ on pump gas
Hello my name is chris. I bought this car brand new in 04 as a left over for my first car, it all started with buying a body kit, and has transformed from there :-). This car was my daily driver for three or four years, and one day i was driving it home from work in boston and the car was misfiring and i dropped it down a gear and leaned out the motor and it blew. After that i put it in the garage and im completly re-doing it to the way i wanted it sense now i have all the time in the world to do it right. And im doing all the work myself (i went to wyotech and did work as a mechanic) except the short block build and the head work beacuse i don't have the paitence. but thats the story hope you like it :-D
Updates
8/16/08 motor removal and tear down page 1
8/26/08 new heads page 2
8/26/08 polished parts and such page 2
10/21/08 new cams and pedals page3
11/28/08 new motor buld page 4
1/2/09 custom AN breather setup and modifed engine harness page 5
2/28/09 PPG gears arrived page 6
3/15/09 removed and dissasembled front suspesion page 7
3/15/09 beadblasted and painted front suspesion page 7
3/17/09 stripped shaved and repainted engine bay page 8
6/4/09 spec-c vent install page 10
6/14/09 started re-working front bumper page 10
7/17/09 finished modifing/ fitting front bumper page 12
7/17/09 started trans re-assembly page 12
7/21/09 got side skirts ready for paint page 12
7/28/09 GOT NEW CAMERA!!!!!!!! :-)
8/8/09 dog box DONE!!! page 13
8/12/09 tranny installedpage 15
8/15/09 motor installedpage 15
(many other things happend in-between also :-)
List of mods so far (upated frequntly :-)
17x7.5 et-48 black racing rims (bronze)
falken azinis rt-615 tires
18x9.5 et-38 enkie PRF-1 limited edition SBC
toyo proxis r888 255/35/18
rays short lug nuts
jetspeed (replica) front bumper held on my moroso 1/4 clips
chargespeed mirrors
charspeed vortex generator
zero sport side skirts
spec-c roof vent
sti grill with S202 badge
carbon fiber b pillars
carbon fiber gas door
sti head lights
hella super tones
kaminari reverse cowl hood
aero catch locking hood pins
VIS carbon trunk
sti carbon side markers
seibon carbon tail covers
varis carbon heat sheild
AEM stand alone
aem IAT sensor
aem 3.5 bar MAP sensor
aem UEGO wide band
axis stage 5 block (2.5L sleeved)
axis oil pump
polished valve covers
full-race twin scroll with borg warner turbo
polished thermostat housing
polished alternator and p/s bracket
polished thing that goes to the upper rad hose
axis racing track seris heads
rc engineering 1200cc
aqua mist HSF-6
ngk (one step colder) plugs
forsa stock orentation manifold
grimm speed phenolic spacers (8mm)
PKN 70mm billet throttle body
turbo xs rfl BOV
perrin front mount
JUN oil cap
ingals pitch stop mount (soild)
cusco catch can
koyo radiator
greddy water temp adapter
turbo xs rad. hoses
gruppe-s rad shroud carbon fiber
unorthadox racing underdrive pullys
tein hood dampers
gates racing timing belt
gates serp belt
tomei timing belt guide
external oil cooler and filter relocation kit
walbro 255lph in-tank pump
aeromotive a1000 external fuel pump
aeromotive injected bypass fuel regulator
aeromotive fuel rails
fjo injector driver
immense harware obd2 simulator
tial 50mm bov
custom p/s tank
custom expansion tank
custom overflow
custom meth/surge tank
**** ton of AN plumbing
PPG 1-4 straight cut dog box
PPG 5th gear syncro hub
PPG shift interlocker
good rich ss clutch hose
ACT 6 puck unspring clutch
ACT pro lite flywheel
DSS 750hp front axles
ACPT carbon conversion driveshaft
kart boy front and rear shifter bushings
B&M short shifter
whiteline crossmember bushings
STI 07' R180 rear end
DSS 500hp rear conversion axles
white line rear end bushings
white line subframe lock
beatrush rear dfferential suppport
BC Racing coilovers
cusco front 21 mm sway bar
cusco rear 22mm sway bar
COBB adjustable rear sway mounts
cusco latteral bars
cusco trailing arms
cusco front strut bar
willwood 6 piston front with 2 peice 13 inch rotor
willwood 4 piston rear with 2 peice 12.2 in rotor
cusco master cylinder brace
agency power front and rear endlinks
perrin P.S.R.S.
whiteline roll-center adjustment
super Pro sterring rack bushings
oswald performance light weight front subframe
auto power 6-point
status ring kevlar seats
status bases, sliders, side mounts
zerosport 3 gauge pod with clock carbon fiber
2 autometer roll cage pods
cluster 2 gauge pod
hks type-1 turbo timer
davtron inter cooler temp gauge
perrin shift knob
zerosport shift boot
sti shift trim
sparco racer 2 wheel
nrg quick relase
sparco hub adapter
prodrive floor mats
PDE-USA adjustable pedals
defi v2 controll
defi BF boost
defi BF EGT
defi BF water temp
defi BF oil temp
defi BF oil press.
aem uego
auqamist flow gauge and controller
shaved headliner wrapped in black suede
shaved B/C pillars wrapped in black suede
door inserts back seude
aluminum o **** handle deletes
clear blue cluster
ma audio 7 inch flip out dvd
4 ma door speakers
other mods-
A/C deleted
AN crank case breaher setup
shaved engine bay
front supension re-painted
removed ABS
fluids:
willwood high temp dot 3 fluid
richmond gear 75w 140 lsd oil
redline 75w90 shockproof gear lube
Parts left to buy :-(
takata 4 point belts
subie12345 is offline   Reply With Quote
Old 08-16-2008, 11:58 AM   #2
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Default car pics
new motor to get your attention :-)
PS these are old pics from lk 4 years ago
Old 08-16-2008, 11:59 AM   #3
birchwood
Member#: 120988
2007 LGT Spec B.
DGM hotness
$26,000? All that money spent, and you didnt buy a camera. Wheres the pics?
birchwood is offline   Reply With Quote
Old 08-16-2008, 12:00 PM   #4
birchwood
Member#: 120988
2007 LGT Spec B.
DGM hotness
Ok scratch that. Looks good. Havent seen those wheels in a while, they look great on sonic yellow
Old 08-16-2008, 12:03 PM   #5
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Wink some parts
these are some random parts i took pics of.... a lot of the parts never even made it on the car before the motor went and some i bought after i blew the motor
Old 08-16-2008, 12:07 PM   #6
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Default front bumper
thats the new front bumper.. the old zero sport one got kicked off and i didnt want to fix it again.. the whole bumper is held on by moroso 1/4 clips no bolts or screws :-) and the sti replica grill .... the perrin front mount fits perfect in the opening you can only see about 1/4 inch of each end tank :-D sporry no pics on my comp
Old 08-16-2008, 12:12 PM   #7
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Angry been in the garage for 1.5+
the motor **** the bed about a year and a half ago luckyly my freind has an 03 yellow bug eye he lets me drive somtimes ;-) im waiting for the heads to get back from ron williams at axis racing and once i have them im ordering the sleved STI block :-) then ill just need my new turbo kit and injectors and misc and i can put the motor back in and i have to repaint the engine bay front subframe and suspension parts :-D
Old 08-16-2008, 12:25 PM   #8
RR02wrx
Member#: 99614
00 Impreza
BRP
Yo Chris! It's Ryan from Wyotech - Damn man, I haven't seen or heard anything about you in awhile - I lost my phone and all the numbers in it i've had a new number for over a year now. I told you your engine would kick the bucket sooner or later haha... Glad to see your building it back up. Im gonna send you a PM with my number, we gotta catch up
RR02wrx is offline   Reply With Quote
Old 08-16-2008, 12:53 PM   #9
TopSecret_Gold
Member#: 113994
2004 WRX Impreza
Intake manifold looks all business. Clean looking car, just need some better pics
TopSecret_Gold is offline   Reply With Quote
Old 08-16-2008, 12:57 PM   #10
RICEREX
Member#: 111914
3/6 WRX TE37 SL
06 EVO MR /03 MAZIORA WRB
nice car
any BBK?
RICEREX is offline   Reply With Quote
Old 08-16-2008, 01:48 PM   #11
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
I like everything except that front bumper.
thrasher is online now   Reply With Quote
Old 08-16-2008, 04:31 PM   #12
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
whats up roooopppssss.. i hung out with tim a while back and went to the street races in hartrford CT and mopped up some civics hahaha i kno i tried calling u b4 and the number was gone so trim said he would give me ur new number but i didnt end up getting it
Old 08-16-2008, 04:33 PM   #13
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
whats up yea it took me a while to get the manifold and 1st time i got it they sent me an sti manifold but the cable mount wasnt on it and the throttle body bolts were a diffrent size but its all straigh now what kinda better pics do u want?
Old 08-16-2008, 04:34 PM   #14
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Originally Posted by RICEREX View Post
nice car
any BBK?
thankss... im new to the fourum stuff whats BBK?
Old 08-16-2008, 04:36 PM   #15
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
HATER haha jk the new one or old one... i didnt wanna buy another zerosport front bumper beacause i crashed with it once and had to fix it and then some one kicked off the front lip peice i fixed it 1/2 way but gave up plus when they kicked it off the broke 2 of the headlight mounting points were the grill usually mounts so idk...
Old 08-16-2008, 04:39 PM   #16
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
Same here. Too busy, too much for the car.
dave_88 is online now   Reply With Quote
Old 08-16-2008, 04:44 PM   #17
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Default some more pics i found
old pics and some new pics one with the nrg quick release no motor u kno.. the a/c is now completly removed and cruise control and boost solennoid
Old 08-16-2008, 04:50 PM   #18
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Default willwood brakes
rear will woods 4 piston 12.19" 2 peice rotor with ss hoses brand new 1.5 years ago still unused
fronts 6 piston with 12.9" 2 peice rotors and ss hoses only 3-400 miles on them i never really got to use them
Old 08-16-2008, 05:12 PM   #19
DOOKWAGON
Member#: 167129
03 Wagon Mafia
Too Low for Nasioc Mb#013
BBK is big brake kit and you've answered that question without even knowing it by posting the Wilwoods.... looks great.
DOOKWAGON is offline   Reply With Quote
Old 08-16-2008, 07:39 PM   #20
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
hahaha ok.. yes i actually put the fronts on on a sunday and the motor went that wendsay and then senses it has been parked i put the rears on so i never really got to try em out
Old 08-17-2008, 02:34 PM   #21
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
orderd brian crower 280 intake/exhaust cams today :-)
Old 08-19-2008, 05:26 PM   #22
subie12345
Member#: 132783
2003 wrx 480 whp
08 silverado 98 ek
Default heads on there way
ron williams called today and said my heads are being shipped out today ordering axis racing block this week or next (sti short block wit sleeves pistons rods modified crank and balanced to 10,000 rpm)
Old 08-19-2008, 05:35 PM   #23
1stockwrx
Member#: 162365
i hate going to build threads, too much drooling is needed...
nice bug man!!!
1stockwrx is offline   Reply With Quote
Old 08-19-2008, 05:50 PM   #24
Bov_Rider
Member#: 142667
2006 WRX TR
Metallic Gray
long project .... !! good income?! :P
Bov_Rider is offline   Reply With Quote
Old 08-19-2008, 05:53 PM   #25
state
Member#: 118560
2002 2.5 RS
looking great
state is offline   Reply With Quote
For love of the Bug-Eye build thread DemiSlayer Rocky Mountains Impreza Club Forum -- RMIC 23 11-27-2009 01:26 AM
03 bug eye build. ASPENWRXstg4 MWSOC Private Classifieds 1 11-13-2008 01:29 PM
TRADE OF BUY!! 03-04 front end. I have the 03 bug eyes, I want the 04 front end streetlegal? Exterior/Styling 12 04-20-2007 07:11 PM
Used 02 - 03 Bug Eyed Headlights for WRX felixwrx Private 'Wanted' Classifieds 0 03-07-2005 07:28 PM
NY: 02-03 bug eye NewAtThis Private 'For Sale' Classifieds 6 08-08-2004 03:14 PM
