Welcome to the North American Subaru Impreza Owners Club Monday October 20, 2014
Old 08-16-2008, 11:16 AM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default Does anyone make dampers for the 08 WRX (and soon to be 09)?
this is kind of deja vu from 2001 when we had no dampers to upgrade to, save the oe v7 STi inverted ones
anyone know of anything or anything in the works?
Old 08-23-2008, 10:04 PM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
OK I'll take that as a no
Old 08-23-2008, 11:13 PM   #3
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
Considering the 09 WRX's are significantly stiffer damped and sprung than the 08's and after talking to a couple of ppl I know who work for Subiesport that drove the car at the test sessions a lot of wrecked 09's are going to be cannibalized for 08 upgrades. From first reports all the 09's seem to really need are some stiffer sways.
QuikWgn is offline   Reply With Quote
Old 08-24-2008, 03:28 AM   #4
jamal
Member#: 71875
98 2.5GT
my wheels fit
KW, tein, and cusco have coilovers out. No struts though it seems, although it might be possible to use legacy stuff. The rear suspension is a little different, I'll have to pay closer attention next time I'm under them.
jamal is offline   Reply With Quote
Old 08-24-2008, 07:23 AM   #5
Arctic Penguin
Member#: 119532
2006 WRX
GFL
it took kyb HOW LONG to make the GD AGX???
holding your breath will just make you turn blue
Arctic Penguin is offline   Reply With Quote
Old 08-24-2008, 08:25 AM   #6
BIGSKYWRX
Member#: 7958
09 GH B+
clearly the 09 struts/shocks will be sought after by the 08 guys- springs too
while the WRX is similar to the "new" Legacy, I don't think it's similar enough to swap parts though
I know a fellow at a company that begins w/ K and ends w/ i, I'll give him a shout
Old 08-24-2008, 09:30 AM   #7
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I am using 05+ legacy Koni's.
It is an insert/cut/install on the front, and rears you have to swap the bottom bushing.
But, huge improvement, and I am running them with the SPT/STI pinks.
HTH
aross is offline   Reply With Quote
Old 08-24-2008, 09:35 AM   #8
aross
Member#: 831
11 Blurple WRX
03 BH MBP
oh, and had to enlarge the rear top hat centre slot a little, to make the larger bore Leggie size strut shaft to fit.
I had leggie struts - and tops to play with.
Leggie rear tops don't work.
Makes the car handle really nice now - even the wife approves.
Sways next for me.
In SS for autocross now - due to the springs.
Old 08-24-2008, 07:52 PM   #9
jamal
Member#: 71875
98 2.5GT
my wheels fit
oh, neat little feature about the spec b front struts is that the housing is extended like 3/4" below the clevis for more bump travel. So if I was going to try to use legacy stuff on my 08/09 I'd get some of those.
Old 08-24-2008, 09:38 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
hmmmm- that's interesting- I wonder what the spec B housing would do for camber???
someone should take the time to measure the stroke on the oe struts- guessing it will be close to the previous Imprezas, but would still be good to know
just so I'm clear here you are using the Koni 8610 1447 inserts up front and no fitment issues at all?
in the rear your using the 8010 1053 shocks? Would you mind providing a little more detail on what needs to be done w/ the rears? Wouldn't have pics of what you had to do by chance?
tia
Old 08-24-2008, 09:49 PM   #11
aross
Member#: 831
11 Blurple WRX
03 BH MBP
tia
Front, no problem.
Rear, had to swap the bottom bushing form the 08 wrx to the koni, enlarge the 08 top hat center area with a drill, and bolt in.
Old 08-24-2008, 09:51 PM   #12
BIGSKYWRX
Member#: 7958
09 GH B+
this may be a pretty easy thing for Koni to resolve in the rear
do those part #'s jive w/ what you have?
Old 08-25-2008, 12:31 AM   #13
jamal
Member#: 71875
98 2.5GT
my wheels fit
tia
I expect the front geometry is identical between legacies and the 08 (sti excluded). Next time I have the struts off one I'll measure some things.
Old 08-25-2008, 07:39 AM   #14
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I know there is a guy running around with some $4500 custom AST struts, but I'm guessing that is not what you are looking for
ButtDyno is offline   Reply With Quote
Old 08-25-2008, 09:18 AM   #15
BIGSKYWRX
Member#: 7958
09 GH B+
that would be great
^ probably not unless your springing for them John
on the rear mount, the new Group N catalog shows a rear top that has a 22mm opening- would that by chance be the same as the Legacy (the WRX being smaller)???
Old 08-26-2008, 10:35 AM   #16
BIGSKYWRX
Member#: 7958
09 GH B+
good news from Koni the 08/09 WRX strut/shock is in the works as we speak. Lee already has part #'s, he is hoping for an early winter (Dec) release, but cautioned it could be a little later.
they will enjoy the same wide range of damping that is Koni's trademark
Old 08-26-2008, 01:07 PM   #17
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
I won't be picking up an 09 until 2011 (unless the STi sedan surfaces) so hopefully the aftermarket will be effectively saturated with 08/09 parts by then.
Old 08-26-2008, 02:16 PM   #18
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
You looking for just strut and not a full coilover?
slowscooby is offline   Reply With Quote
Old 08-26-2008, 08:29 PM   #19
obs2008
Member#: 163068
08 outback sport
iv been lookin for struts as all 4 of mine are blown out already, all were leaking at 9k. iv emailed kyb, tokico, koni, no one has said anything about them yet. its good to hear koni has some in development
obs2008 is offline   Reply With Quote
Old 08-26-2008, 08:37 PM   #20
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I'm enjoying my Koni's now.
Old 08-26-2008, 08:48 PM   #21
obs2008
Member#: 163068
08 outback sport
lol must be nice, i figure im either going to get the 09 struts or the koni that someone else said are supposed to be released sooner or later. the 08 factory struts are real ****ty
Old 08-26-2008, 08:54 PM   #22
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Yeah, my 08 "showas" really sucked. Interesting design inside - kinda like inverted.
Old 08-26-2008, 09:24 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
I mentioned to Lee that at least one guy was using the LGT Koni setup- (Lee was instrumental in developing those btw) he stated that they were very similar platforms. I'll be curious to see if the front part #'s are the same????
Old 08-27-2008, 10:48 AM   #24
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Me too..
The rears will be different, as the bottom bushing is different, and the LGT shaft is thicker.
Old 08-27-2008, 02:09 PM   #25
obs2008
Member#: 163068
08 outback sport
as long as someone makes them soon i dont care what they do to them. i got my whole suspension done and its being held back by these crappy blown out struts
08 wrx owners, want to be as fast as an 09? Its easy. Franko Impreza Forum 12 06-16-2009 10:29 PM
very soon to be 09 sti owner tgraci Newbies & FAQs 2 05-14-2009 11:42 AM
Does anyone make projectors for the 2005 STi's sti.2005.blk Interior & Exterior Modification 10 12-23-2007 11:18 AM
Does anyone make cams for the 2.2L cybin Normally Aspirated Powertrain 31 12-03-2003 03:46 AM
Does anyone make rims like the Advan Model 7s in gold and lightweight? Andrew Brakes, Steering & Suspension 14 11-07-2001 02:58 AM
