Old 08-16-2008, 11:36 AM   #1
STiGMATA
Member#: 47564
06 STi
black w/black BBS
Default odd problem with car, need help diagnosing
ok whats up everyone... here is the deal ....my car has been running just fine... now 4 days ago while driving home from work i give the car some gas, and it pulled nicely, and when i let off the gas i noticed a little cloud of smoke come out of the exhaust.....well i get off the expressway and get home,turn the car off and go to sleep.. well i start the car when im leaving for work around 12hrs later, car starts fine...well i back out of my driveway and as i start to pull away as i accellerate it sounds as if the turbo is in the car with me spooling.....well i have a front mount so after i get off of work i decide to double check all the connections in the piping none are leaking....so i baby it home, cause now the car wont build any boost at part throttle (like when you re-activate the cruise control) it hits 0 vacume and thats the farthest it goes...so by this point i am stumped... car is idling fine at 20vac, i check the intake piping and all spots after the maf are nice and sealed.....and yet when i get on the gas it sounds as if my car is a deisel (not the engine, but the turbo) ....i checked the exhaust for leaks and pulled off the downpipe and the turbine wheel looks fine....well i have a one piece header, but after checking all the welds are still sound...and the only place on it that i feel it may be leaking from is the flex joint where the downpipe meets the header.... i have yet to check the compressor side of the turbo to see if there is excessive play or damage to the wheel.....so please if anyone has any ideas on what could be the problem please let me know.... thank you
STiGMATA is offline   Reply With Quote
Old 08-16-2008, 11:47 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
CN: car has fmic, no apparent leaks, -20 in/hg vac, won't build boost.
Old 08-16-2008, 11:53 AM   #3
STiGMATA
Member#: 47564
06 STi
black w/black BBS
ha ha thanks .....
Old 08-17-2008, 11:44 PM   #4
STiGMATA
Member#: 47564
06 STi
black w/black BBS
anyone????
Old 08-18-2008, 12:21 AM   #5
STINOMORMONEY
Member#: 183029
2007 STI- 402whp/436
OBP- uncorr./SAE-Mustang
so no boost at all?? it sits at -20 on wot
STINOMORMONEY is offline   Reply With Quote
Old 08-18-2008, 11:24 AM   #6
Mitsu
Member#: 93557
2002 STid wagon-SOLD
check to make sure that the wastegate isnt stuck open. Take off the downpipe and check everything out.
Mitsu is offline   Reply With Quote
Old 08-18-2008, 11:37 AM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
no boost at all but it won't go past 0psi @ wot.
Old 08-18-2008, 02:14 PM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
If the wastegate arm didn't get disconnected then the turbo's shaft is seized.
Haelan is offline   Reply With Quote
Old 08-18-2008, 03:31 PM   #9
th1rd3y3
Member#: 83054
'11 SWP
STI
+1 on this suggestion. Check the wastegate acutator arm as well. I had one of those c-clips pop off of mine for no apparent reason and it did the exact same thing.
th1rd3y3 is offline   Reply With Quote
Old 08-18-2008, 06:12 PM   #10
02subbysnack
Member#: 176393
2002 vr7 sti wrb
wastgate or turbo seized
02subbysnack is offline   Reply With Quote
Problem with power, need help necratis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-08-2009 11:40 AM
problem with UTEC. need help vipmooneyes Engine Management & Tuning 2 08-28-2005 02:54 PM
Problem with acceleration, Need Help wlchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-29-2003 10:20 PM
problems with purchase..need help oppie590 Brakes, Steering & Suspension 6 05-12-2001 10:45 PM
