Old 08-16-2008, 05:32 PM   #1
arrowscooby
Member#: 176615
??? sleeper
rex
Default 18g 2.0 bugeye at 70000 miles - tuned by jesus!
was finally able to grab a hold of my dyno sheets. thanks to teddy at mavrik motorsports for digging them up for me. and thanks to jon (aka jesus) of hbspeed for the tune. car is a 2002 bugeye with 70,000 miles. tuned on mavrik's dynolog dyno, which i'm told reads about 20% less than a dynojet, so i'm making close to 300whp on 91 oct, and over 300whp on 93 if my car were tuned on a dynoject. stock sti's put down about 200-210whp on the dynolog dyno.
calicraptastic 91 oct map
91oct/100 oct map (effectively 93 oct)
arrowscooby is offline   Reply With Quote
Old 08-16-2008, 06:09 PM   #2
CatfaceType-R
Member#: 81102
10 second pass coming
70,000 miles, very nice
CatfaceType-R is offline   Reply With Quote
Old 08-16-2008, 06:14 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Whats going on with the dip at 5300ish Rpms and then shoots back up? Knock?
renosubby is offline   Reply With Quote
Old 08-16-2008, 06:32 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Other than the dip, THAT is the kind of torque curve I expect to see. I've been seeing them drop off a lot on recent graphs, and while people say it's normal, THIS one looks good. That's what I'm talkin aboot!
Audiosavvy is offline   Reply With Quote
Old 08-16-2008, 06:54 PM   #5
arrowscooby
Member#: 176615
??? sleeper
rex
not too sure about the dip - maybe someone can elaborate? i don't see any knock based on my knock light. it's a fairly conservative tune at 19psi peak.
Old 08-16-2008, 07:10 PM   #6
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I am talking about the dip on the torque how it goes down and then goes back up... It shouldn't do that, Should be smooth transition down!
Old 08-16-2008, 07:13 PM   #7
arrowscooby
Member#: 176615
??? sleeper
rex
i do see that...not sure though.
Old 08-16-2008, 10:41 PM   #8
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
i put down 297 whp on a mustang dyno with a vf34 with my 02 wrx with 145000 miles that was on 91 oct
bmxhotsauce is offline   Reply With Quote
Old 08-16-2008, 10:54 PM   #9
arrowscooby
Member#: 176615
??? sleeper
rex
^nice who says our cars aren't reliable?
Old 08-16-2008, 11:21 PM   #10
Nicklz
Member#: 94096
2003 WRX
reliable??
180k mile bugeye w/16g
287hp-271tq
Nicklz is offline   Reply With Quote
Old 08-17-2008, 01:46 AM   #11
Auto0utcast
Member#: 127684
2004 WRX STi
theres something wrong with that tune. either bad knock or a slipping clutch or a nasty boost leak.... possibly even motor damage causing an issue but that dip in the curves isnt cool. get ur car fixed asap.
Auto0utcast is offline   Reply With Quote
Old 08-17-2008, 11:22 AM   #12
arrowscooby
Member#: 176615
??? sleeper
rex
i guess my jesus tune sucks then?
Old 08-17-2008, 11:28 AM   #13
Zumble
Member#: 34860
2005 Forester CGM
Confess your sins and maybe he will save you...
aka, tell him its broke maybe he will fix it?
Zumble is offline   Reply With Quote
Old 08-17-2008, 12:04 PM   #14
torkeh
Member#: 182904
'02 WRX UTEC'd
AW/Prova Hood
There is not a damn dip in the graph people, the torque curve is fine, you think you are seeing a dip in the graph but its really just the two lines intersecting each other, they are just both the same color so you cant tell. Look at it closer before you tell this kid his engine is messed up. Jesus people... just wow
torkeh is offline   Reply With Quote
Old 08-17-2008, 12:33 PM   #15
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
I don't think Jon would leave a car with a crappy tune.
mapleleaf is offline   Reply With Quote
Old 08-17-2008, 12:52 PM   #16
Auto0utcast
Member#: 127684
2004 WRX STi
are you retarded?... look at the torque graph @ 4700. it spikes, drops then raises again. this is either a sign of detonation, slipping clutch or significant boost leak. the tune or car is messed up.
Old 08-17-2008, 01:35 PM   #17
arrowscooby
Member#: 176615
??? sleeper
rex
there is a dip, i do see it...maybe jon can chime in...the boost curve looks like it drops as well, that's when the torque curve dips...is there a correlation? shouldn't the hp curve be acting funky too? hp curve looks fine though right?
Old 08-17-2008, 02:52 PM   #18
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
no it doesn't look fine - you can see the HP curve flatlines for a while.
Remember that even if torque dips, HP is not going to drop since it's dependent on rpms.
The boost curve isn't really dropping - you're running an internal wastegate right? so your boost is just overshooting the target while spooling up and settling down.
Probably some timing got pulled in that rpm range - you definitely should get it check out ASAP because that's exactly what a dyno graph looks like when there's detonation but then, i'm not a tuner so i dunno. Maybe there is some explanation
verc is offline   Reply With Quote
Old 08-17-2008, 03:04 PM   #19
arrowscooby
Member#: 176615
??? sleeper
rex
jon help!
Old 08-17-2008, 03:07 PM   #20
WRBlueRex04
Member#: 164540
'04 TURBOXR
STG2 WRX
Normally that dip is associated with the TGV's position. I think that is when they decide to open up. Because when they open, you have to build that extra boost that the semi-closed TGV's were helping and therefore, your TQ drops off because your bosot drops. Not for sure though.
WRBlueRex04 is offline   Reply With Quote
Old 08-17-2008, 04:59 PM   #21
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
jon wouldnt let a car leave like that it looks like the scaling of that weird dyno did it
the afr and boost maps look perfect.
bunch of armchair t0oners scaring a newb into thinking his car is blowing up, got to love PPB.
bren wrx is offline   Reply With Quote
Old 08-17-2008, 05:27 PM   #22
Auto0utcast
Member#: 127684
2004 WRX STi
you can have perfect afr and boost but garbage timing causing knock...bren, look at that dyno plot. something is messed up...
Old 08-17-2008, 05:44 PM   #23
arrowscooby
Member#: 176615
??? sleeper
rex
more inputs please...i'm getting worried here. jon told me after the tune that there was no knock, especially since it was a semi-conservative tune on 19psi. i wanted more but jon wanted to be on the safe side. for people trying to figure out the lines, you can distinuguish between the hp/tq curves via the black squares on the torque curve. it's somewhat confusing since both lines are the same color...
Old 08-17-2008, 05:50 PM   #24
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
all dynos are not equal, if that dyno has horrible loading features and that is how it displays however JON would not let a car leave if it was like that, nor have i ever ever ever seen any of his graphs like that - the one thing in not common thing in this equation is the weird dyno he's using. Use your head.
example: look at a agile auto torque curve graph versus a dynojet p&l graph,
Old 08-17-2008, 05:51 PM   #25
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
your car is fine, nasioc is as usual
Junior tuned FP TDO5 18g 2.0 04 wrx neo277 Proven Power Bragging 11 03-29-2010 05:59 PM
Going to get new tune saturday!! E85 18g 2.0 scoobyscoobsti Proven Power Bragging 10 02-27-2010 10:56 PM
18g 2.0 in the area? akturbogti North West Impreza Club Forum -- NWIC 26 01-26-2009 07:17 PM
18g 2.0 wrx - spark plug analysis - what do you think? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-19-2007 12:53 AM
Feeler: 04 STi, 420whp, [email protected] 1/4 mile, 23k miles, tuned by Topspeed $30k sticrazy Private Vehicle 'For Sale' Classifieds 8 08-12-2006 07:57 PM
