#1 |
Member#: 136919
W. Canada
Vehicle:2005 Legacy GT Wagon ABP |
Lets say compared to a honda b18c engine. We both have the same 9.7:1 Compression ratios iirc yet he has smaller displacement and makes 170bhp compared to my 135bhp. Can someone explain this or is this like comparing apples to oranges?
#2 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
He may make 170 hp, but only 100-110 ft. lbs. of torque. Whereas the EJ22 makes 135 hp, and about 140 ft. lbs. of torque. I know nothing about honda motors, so I'll assume that motor has v-tech, maybe only on the intake cam, but I have no idea. It is pretty common knowledge that v-tech and all other various forms of it add power higher in the rpm range, I guess that is where his extra ponies come from.
~Josh~ |
#3 |
Member#: 71875
Vehicle:98 2.5GT my wheels fit |
they rev higher. tq x rpm = hp
#4 |
Member#: 93309
NWIC
Vehicle:1999 OBS Black |
Better flowing heads as well I'd assume.
#5 |
Member#: 118334
SWIC
Vehicle:#555 2006 / 2005 S-AWD+TT2 WRX / RS Daily |
less parasitic loss as well.
#6 |
Member#: 179736
Vehicle:2005 Legacy GT RBP |
Its a little bit like comparing apples to oranges in a sense.
Ok to compare we'll use your 2.2L vs the 1.8L honda. Your motor is a lower reving motor, horizontally opposed, which is good for torque, but not so good for horsepower, less efficent to make it run compared to the i4 with only one head. the larger displacement makes torque better, but won't rev as high has the lower displacement with a shorter stroke. In general on N/A motors with 6 cyl or less, higher rpm makes more power. Those are the cold hard facts that are directly related to the size and style of the engine. Now the parts you cannot tell by pure numbers are the specifics of each motor. The flow of the heads, bore, stroke, weight of internals/efficeniceny (spelling is wrong i know), camshaft gind, tune, and smaller factors like operating temperature, lubrication, engine layout and drive type will make huge difference in power output. Not to mention the intake, headers and exhaust restrictions also effect power greatly. If you got more agressive cams, headers, intake and exhaust with a decent tune you'd be making more than 170 horsepower and you would have the extra torque that the vtec honda lacks. There are so many factors that go into the output of a motor, comparing any two motors of different sizes or styles is exactly like comparing apples to oranges. My eclipse's 250 horsepower v6 makes the same power some early corvette 327 (5.4L) v8s made. Every motor is different |
#7 |
Member#: 141182
Vehicle:08 Impreza Hatch Silver |
The Honda Motor has 16 valves adn V-teck. That simply gives the airflow it needs to make that kind of power. Your Ej22 is a SOHC 8 valve engine designed for off roading and towing capabilities in a much bigger car.
Race him on gravel! or rain, or snow, from a dig! Other than a sunny day at a paved track, you'll win. |
#8 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
All 4cyl EJ motors are 16v. 8v motors went when they stopped making the EA series motors.
Way too many differences in engine design to try and compare them. Jay |
#9 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
don't forget that your awd sucks up some power too
#10 |
Member#: 138997
Vehicle:0000 Nothing |
the stupid in this thread is gettin a lil too high, so ill try and steer things back to where they should have been in the first place.
firstly, your b18c/ej22e comparo is just wrong. the b18c has vtec, is dohc, and has less cubes. what we should be comparing the ej22e is to hondas workhorse engine of the same year (lets pick 1997), the f22b2 that can be found in the common accord LX. check out the hp and tq: 145hp @ 5500rpm 147tq @ 4500rpm now compare to the 97 impreza: 137hp @ 5400rpm 145tq @ 4000rpm see? theyre pretty similar. |
#11 | |
Member#: 179736
#12 |
Member#: 5218
C'mon....the thread was a goner before it had a chance.
Jay. |
#13 | |
Member#: 138997
#14 | |
Member#: 179736
You just showed him that two engines with the same displacement can have roughly the same power. Good job, that wasnt his question, and that was never before discussed in this post. This guy wanted to know why the 1.8 makes more power than a 2.2. Yes two 2.2 motors can be almost identical in bhp. But they can also be 100hp apart. EVERY MOTOR IS DIFFERENT! Noone asked you to compare two similarly displaced motors, this was a specific comparison the of two motors the author mentioned to further increase his knowledge, it had nothing to do with a f22b2, a 4g64 or any other motor. Last edited by Chocoholic005; 08-18-2008 at 01:58 PM. |
#15 |
Member#: 179736
How can you tell someone their comparrison was wrong?!?! HE'S THE ONE WHO ASKED THE QUESTION! Thats like telling someone their wrong cause they like Mountain Dew. He wanted to compare the b18c and the ej22, you can't tell him he's wrong, moron. And how the hell is the thread getting "high"? Every single post made was valid and helpful except maybe that 8 valve sohc post. I mean seriously, are you always so stupid or is today a special occasion?
#16 |
Member#: 136919
W. Canada
Sorry guys for causing trouble but thanks for the rest of you for clearing this up for me, makes sense now
#17 |
Member#: 179736
I'm glad things were cleared up for ya.
#18 |
Member#: 136919
W. Canada
so lets say I wanted to get a higher redline and better flowing heads, what direction would I have to head into to? Getting my heads ported or doing a hybrid build like getting EJ25 heads?
#19 |
Member#: 179736
The sohc heads would flow better, you could get a port and polish on your current heads which would help, maybe some oversized valves. Since you are the 2.2L you can probably up your redline as you are now and be pretty safe, however you're gonna need to tune for that higher rpm to make better power.
#20 |
Member#: 136919
W. Canada
so my heads are fine, I just need to get them ported? What about my intake manifold?
#21 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Zac86, Do a search for the NA white power paper. Read the section on the high compression frankenstein as well as Delta Cams. You can swap in a complete Ej25 for what a port and polish job would cost you. Bigger valves would be a waste of time and money. You cannot raise your redline easily. It's electronically controlled and there's not an easy fix on your car. |
#22 |
Member#: 74907
NWIC
EJ25 shortblock swap ftw.
I did that along with delta cams and an EL header, no dyno #'s, but alot more power than stock for sure. Ya the EJ22 heads dont flow as well as the EJ25 heads do, but you can make decent power and still have alot of fun with the car. Not to mention they arent that expensive to buy used. ~Josh~ |
#23 | |
Member#: 102984
Vehicle:2005 2.5RS 4EAT Platinum Silver |
#24 |
Member#: 179736
What makes you guys think he wants to swap his entire shortblock to get this power?
#25 |
Member#: 60082
Vehicle:2004 Forester STI Silver |
Zac86, do you understand the concept of power band?
HP and TQ numbers are simply that, just single numbers at a single point over the entire rev band. In this sense, the numbers themselves are pretty meaningless without knowing why there are what they are. HP = Torque x RPM / 5252 That means torque is hp, just shaped along the rpm range. Torque is good. Torque is always good. HP can be deceiving. High rpm and a highish HP rating can mask a relatively low torque value as well as tell nothing about the lower rev range that you will be in 99% of the time. Area under the curve is what matters!!! Subarus have relatively high toque numbers. They simply don't have high rpms. Also because they are mid rpm oriented, they produce a lot of midrange power but fade off near redline. This fade off in the high rpm range yields lowish hp numbers, despite relatively high torque output. There's more there than you "see" when looking at these simple HP and TQ numbers. As well, the Honda engines overstate their performance with their high rpm focus. You see high HP numbers but don't see the major lack of toque. |
| Thread Tools | |
| Display Modes | |
| Why does my clutch make a creaking sound everytime I press it in? | Malasubidude | Newbies & FAQs | 10 | 07-16-2008 06:00 PM |
| Why does my exhaust make that noise? | swaybarhelp | Normally Aspirated Powertrain | 8 | 11-02-2006 03:25 AM |
| Why does my memory cost so much? | 0260B4U | Off-Topic | 35 | 07-01-2004 12:45 AM |
| Why does my VF30 lag so damn much? | Big Turkey | Factory 2.0L Turbo Powertrain | 18 | 07-15-2003 06:08 PM |
| Why does my WRX accelerate so roughly in 2nd gear? | sajohnson | Factory 2.0L Turbo Powertrain | 43 | 01-19-2003 12:30 PM |
