Old 03-11-2002, 10:40 PM   #1
aarneson
Member#: 3383
Question gear ratios MY99 & MY00
I was wondering if the gear ratios for the rear diff were the same for these model years of 2.5RS. I am thinking about trying to get a used LSD from a MY00 for my MY99.
I am sure I would need the axles too.
Anyone know?
Thanks Arne
aarneson is offline   Reply With Quote
Old 03-11-2002, 10:49 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You can use the LSD from a 2000/2001, and it will drop right in .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 03-11-2002, 10:51 PM   #3
aarneson
Member#: 3383
Hey thanks for the quick response brian!
So I guess I would need the axels too?
Old 03-11-2002, 11:47 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
From what I've heard you do not... it's a straight swap, one for the other.
Brian
Old 03-12-2002, 03:14 AM   #5
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Brian
You'll need the MY00 axles because the splines between the LSD and regular dif are different.
Other than that, it's a straight swap.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Final Drive ratio & 6th gear ratio? scuzzy Transmission (AT/MT) & Driveline 1 11-09-2013 10:54 AM
07 STi 3rd & 4th gear ratios on 05 STi shafts...? bertune Transmission (AT/MT) & Driveline 2 12-31-2008 02:43 AM
97L gear ratios vs. RS ratios? (MT) Murray Transmission (AT/MT) & Driveline 7 08-12-2003 11:26 AM
Gear ratios and differential ratio for 95 legacy and 95 imprezza ciper Transmission (AT/MT) & Driveline 0 06-14-2002 06:58 PM
WRX weight distribution & gear ratios ?? WeRX General Forum Archive 5 01-20-2001 05:06 PM
