Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 08-18-2008, 08:18 PM   #1
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
Smile Heat shields: How well do they work? Pics inside!
After doing my exhaust install this week I completely forgot to install my heatshield. After reading around with 5000 different opinions on how good or bad it is to drive around without your heat shield on I decided to find out. I just happen to have access to a 60 thousand dollar infared camera and decided to take a few shots today after driving an hour and a half home. I'm going to go ahead and post some pics I took after the drive WITHOUT the heat shield. Hopefully this weekend I'll put it back on and we'll recreate the same sitaution and see the difference. I'm also going to take some pics after letting the car idle in place since a lot of people are saying that's when most of the heat soak occurs. Hope this helps clear up any "unknowns" on heatsoaking and everyone finds this interesting, here ya go!
Note: Red = to high for the IR camera to read without setting the range higher (mostly just the turbo is red)
khellen9 is offline   Reply With Quote
Old 08-18-2008, 08:18 PM   #2
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
Old 08-18-2008, 08:31 PM   #3
teiva-boy
Member#: 22825
That is very very cool. Please make sure to follow through and update with more info
teiva-boy is offline   Reply With Quote
Old 08-18-2008, 08:37 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
That's great. Looking forward to the pics with heat shields. Should be a noticeable difference...
wrxdrvr is offline   Reply With Quote
Old 08-18-2008, 08:50 PM   #5
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
Will do! Possibly will have the pics of the idling without heatshield tomorrow. The heatshield I'm going to put on is the Cobb heatshield but if the popularity of the thread goes up I may try the cut stocker as well to see the benefits between the two.
Old 08-18-2008, 08:50 PM   #6
Tgui
Member#: 44771
Please share what kind of camera you're using!
Tgui is offline   Reply With Quote
Old 08-18-2008, 08:58 PM   #7
shaman
Member#: 164259
It would be really interesting to see pics with a alky system installed.
shaman is offline   Reply With Quote
Old 08-18-2008, 11:40 PM   #8
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I doubt you would see much difference in the heat around the turbo. In fact turbo temps will probably be higher on meth because you tend to run more boost.
The pics are very cool - it would be more interesting to see the temps of some of the pieces/parts that are near the turbo, since you will not be able to photog the turbo directly after the heat shield is installed. The intercooler temps will be interesting. Apples to apples if everything else is held constant (which is hard to do).
bcblues is offline   Reply With Quote
Old 08-18-2008, 11:40 PM   #9
bcblues
Member#: 17256
04 STi
Yeah, what kind of camera??
Old 08-19-2008, 02:39 AM   #10
halfelite
Member#: 120680
My test showed the same as your pics. The stock Heat shield didnt help very much on the stock turbo. I used a IR FlexCam T. Using the 20mm 32-662f range.
halfelite is offline   Reply With Quote
Old 08-22-2008, 02:06 PM   #11
BGPKR
Member#: 41842
2006 LGT LTD 5SM
Can't wait to see the heatshield installed pics.
BGPKR is offline   Reply With Quote
Old 08-23-2008, 10:59 AM   #12
bcblues
Member#: 17256
04 STi
I have wondered about heatshields. I have a Cobb HS that I had double-coated with JetHot Sterling. Looks great, but seeing it installed I cannot help but think it does little to control heat under the hood. I also have a fully-coated turbo, and I bought a turbo wrap kit but never installed it. It would be VERY interesting to do some direct comparisons among the different HS/coatings/wraps/heat control devices and see how they REALLY shake out!
Old 08-23-2008, 11:19 AM   #13
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
djerickd is offline   Reply With Quote
Old 08-23-2008, 11:20 AM   #14
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I totally forgot the heatshielding deathatch!!:
http://www.stage-infinity.com/2008/0...-deathmatch/3/
Old 08-23-2008, 11:55 AM   #15
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
neat camera...id like to see back to back the heat difference between the metal coolant header tank vs the newer plastic one if it makes that much a difference in radiant heat toward the TMIC. Either way 51-83 C on the endtank is pretty freaking hot.
fastnoypi is offline   Reply With Quote
Old 08-23-2008, 12:23 PM   #16
03_Impreza_Al
Member#: 146606
Pretty cool. I got the stocker and Cusco on top of that.
03_Impreza_Al is offline   Reply With Quote
Old 08-23-2008, 02:11 PM   #17
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Heat shields, coatings, wraps all work. Put them together and they do wonders for the TMIC... I have ZERO heat soak and consider my TMIC as good as a FMIC, I can get colder than ambient IAT out of my stock TMIC and into throttle practically any time. That is an increase from 59% efficiency on average to an 85% efficiency on average...with a 93% efficiency when you need it the most on a 40*C day/104*F I got that number...
Old 08-23-2008, 03:20 PM   #18
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
All great posts, I'll look into doing some shots of some other pieces by request after we finish up with this one, I'm not going to be able to put the heat shield on this weekend but next week I should be able to. I'll keep you guys updated!
Edit: forgot to mention, I'm not sure how much this will affect the heat soak on the IC but I do have open vents on my hood. I'll post a pic of my hood later today but I'm not sure how much this will help in keeping it cool under hood, having a place for heat to escape may be causing slightly cooler temps under hood. Maybe I'll throw the stocker back on for a day to compare hoods as well! Just figured I'd let everyone know the playing field so you can make an even more informed choice when choosing your setup. Also, just picked up an SSAC ebay TMIC so we'll test that as well, stay tuned!
Old 08-23-2008, 04:51 PM   #19
rico_q808
Member#: 155896
Chapter/Region: HIIC
2006 WrX
bLuE
intresting, i cant wait to see what all the temps are like. what the average temp for you location.
rico_q808 is offline   Reply With Quote
Old 08-25-2008, 08:09 PM   #20
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
As of lately about 25-30C. Temp around here has been pretty stable. I'll make sure to record the ambient temp next time.
Going to have to move my pics, seems I ate up all the bandwidth of the site I had those posted on. I'll switch them over when I can.
Old 09-02-2008, 07:17 PM   #21
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
I would be intrested to see these pics I am running my 18 with out a heatshield. I am wondering if it makes a big difference and it's its worth the 50 bucks to put an aftermarket one on.
fearmywrx is offline   Reply With Quote
How well do air to water intercoolers work w/ an air to air heat exchanger? sumfoo1 Water/Methanol Injection, Nitrous & Intercooler Cooling 5 07-30-2007 09:31 PM
Rock/Bug Deflectors... how well do they actually work? jandree22 Interior & Exterior Modification 4 05-08-2006 08:10 AM
How well do the stock 03 WRX shocks handle H&Rs?Will they work with the stock rubber? Kwyjibo Brakes, Steering & Suspension 0 12-04-2002 01:16 AM
how well do silencers work? booger Normally Aspirated Powertrain 0 05-21-2001 09:20 PM
Big brakes, who has them & how well do they work? MD20 General Forum Archive 1 06-16-2000 07:26 PM
