Notices
Old 05-09-2001, 01:16 PM   #1
LarryMak
Guest
Member#:
Unhappy HELP! My Cooling is leaking!
i need to know where is the water pump located!! because i'm not sure is the water pump or something else leaking!the leak came from belind the timing belt on front of the engine right on top of the middle..so i think it should be the water bump! but when i jack up the car and see!! it just can't find the leak coming from!!do you think is from some kind of pipe!! could any body help me with it!
Old 05-09-2001, 02:18 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Are you sure it's coolant? Or is it just condensation dripping off A/C lines? Check the drips, if they're green then worry. If they're just water, most likely no worries. Also check your coolant reseviour. If it's not going down, it's not leaking.
CosmoTheCat is offline   Reply With Quote
Old 05-09-2001, 02:19 PM   #3
v6scoobie
Member#: 1563
Post
Take it too the dealer if under warranty and they can do a pressure check to see if its leaking and where also check your hoses for loose clamps.
Randy www.i.am/imports
v6scoobie is offline   Reply With Quote
Old 05-09-2001, 03:27 PM   #4
LarryMak
Guest
Member#:
Unhappy
I'm positive sure is the green stuff coming out in some where belind the timing belt!but not sure is the water bump! anyone know where is the water bump located!!!just want to double check is the right area...is leaking out!
Old 05-09-2001, 04:10 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I believe I saw the marks for it on the driver's side of the block. The block is small so basically if you're looking at it, it will be just to the right of center, maybe 6-7".
Old 05-09-2001, 04:16 PM   #6
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
If it is minor it may be overlflow, durring the heat. If not let it idle and lay down next to it and watch it. Check your hoses it may be minor and just dripping down the engine block. This will be verified by a stong syupy/carmel smell around the car after it has been run for a while. And check your radiator fluid level as well as the resovior level. If it is minor enough I have heard of people dumping that copper stuff in the radiator and it plugs the hole. But I wuld be leary of using it. But to be honest I have never heard bad things about it...
ChosenWon is offline   Reply With Quote
Old 05-09-2001, 07:29 PM   #7
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Wink
That sucks. I would hate to lose MY cool. I just filp out!
John2.5RS is offline   Reply With Quote
Old 05-09-2001, 07:34 PM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
the water pump is located right behind the timing belt covers.....
likely you have a leak in your water pump...
sorry.... you better take it in and get it looked at pronto...
j. www.subiegal.com
Old 05-09-2001, 08:03 PM   #9
LarryMak
Guest
Member#:
Thumbs up
Thanks Guys!i will take my car, get a check up...let see what happen!
Peace.
Old 05-09-2001, 08:10 PM   #10
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Post
My waterpump **** on me a month ago and left me on the side of the road for a hour at 7AM. I was left with a huge repair bill and it overheated reallllll bad. I am afraid that I damaged the block and it will bite me in the ass down the line...most likley blow a head gasget or something. I was driving for about 5 minutes before I noticed that the cloud of dust behind me wasnt actually dust It literally hit overnight. The day before, "Mom, my car is making a fully sound." Mom: "Its nothing, youre just worrying about nothing."
NExt morning: "Mom, Dad, My car is on a Flatbed and I just got off the thruway...where do you want it towed to?"
And yes, it is located behind the timing belt cover.
[This message has been edited by kevinsUBARU (edited May 09, 2001).]
kevinsUBARU is offline   Reply With Quote
Old 05-09-2001, 08:52 PM   #11
LarryMak
Guest
Member#:
Unhappy
Thanks KevinSubaru, i think so too! because i really have trouble finding the waterbump,
what you think might cost me to fix it!! and do you think i should change the timing belt as a same time! and what is the total for all this!! for a resonlible price!
Old 05-09-2001, 09:03 PM   #12
ChosenWon
Member#: 2236
2000 Audi S4
Post
Just a side question Larry, have you ever made a post where you did not put explamation marks after every sentance?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-09-2001, 11:18 PM   #13
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Post
Isn't a waterpump under warranty for 3/36K?
Albert
Albert is offline   Reply With Quote
Old 05-10-2001, 12:45 AM   #14
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
Thanx Subaru! for locating the waterpump in the most labor intensive area of the car!!!!!!! What a bunch of morons!!!!! great so now when mine goes out I gotta pay a mechanic 4 hours worth of labor!! at $50 an hour I'll just chuck my car. Yea I'm pissed, real pissed.
WRXwannbe is offline   Reply With Quote
Old 05-10-2001, 12:57 AM   #15
ChosenWon
Member#: 2236
2000 Audi S4
Post
Um...wow. I've never seen anyone get so pissed at a problem....they don't even have yet...
Old 05-10-2001, 02:54 AM   #16
XT6Wagon
Member#: 524
04 STi
Post
WRXwannabe, I take it you haven't worked on many cars. The subaru WP's are a snap to get to/work on compared to most cars.
My SHO is about 8 million times worse. Not only is it behind the timing belt, but it takes longer to get the timing belt covers off than it does to SWAP a WP on a EA-82.
Most 4cyl cars that the Impreza/legacy competes with are also worse.
XT6Wagon is offline   Reply With Quote
Old 05-10-2001, 05:32 AM   #17
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Post
No Problem...because I overheated and lost a lot of coolant, it took them $360 of my own money for them to actually figure out what happened. Then it was time to start fixing...mmmmm.....When all was said and done, it ran me about $700. They replaced the timing belts, cam seals, waterpump, thermostat, coolant, towing, and a few other o-rings here and there. It had 58,218 miles when it happened, and I filed a warrantly claim with SOA because of the recomendation for me to do so when I called them. It is a 95 and it is over the 5 year (60 month) powertrain warranty, but it had under 60K which was remarkable according to the customer service guy. Im going to call one of these days to see how its coming along. Good luck, and its the labor that will kill your wallet!
Kevin
**update** They called this morning and are paying half of the bill
[This message has been edited by kevinsUBARU (edited May 10, 2001).]
The "guess where my oil is leaking from" game xxtwowheelfiendxx Service & Maintenance 15 03-04-2004 06:02 PM
HELP! How cool is the Livermore Service Dept.? More... dahveed Bay Area Impreza Club Forum -- BAIC 4 09-12-2002 12:12 AM
WTB - new uppipe - my upipe is leaking ! alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-12-2002 01:46 PM
My car is leaking..which dealer I should bring in to ?? PKduck Bay Area Impreza Club Forum -- BAIC 7 01-29-2002 04:03 PM
My uppipe is leaking and i have to do it again. I a have a few ?? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-16-2002 01:16 PM
