Old 08-19-2008, 07:34 PM   #1
ki11switch
Member#: 176422
Default Help! Lost a cam cap during rebuild
ok, so i just took my engine into rallitek. It was all in boxes allready apart. They said that it is missing one cam cap from the set. He also said that it cannot be replaced and i have to completely get new heads if i cant find it? is this true? The heads are from a 02/03 wrx.
thanks for the help!
ki11switch is offline   Reply With Quote
Old 08-19-2008, 11:40 PM   #2
STi-Spec C
Member#: 75923
2004 18g WRX
yes that is true. the cam caps are lined bored with the heads so you can not just replace it with another cam cap from another cylinder head. If you do, your cams won't function correctly and oil will leak out from the heads. I say better start looking around your house.
STi-Spec C is offline   Reply With Quote
Old 08-19-2008, 11:45 PM   #3
Clark Turner
Member#: 178047
02 WRX STI Spec C
Not true. The head will have to be line bored with a new cam cap installed. A simple job for any machine shop.
Clark
Clark Turner is offline   Reply With Quote
Old 08-20-2008, 08:43 AM   #4
STi-Spec C
Member#: 75923
2004 18g WRX
Clark
thanks for clarifying that Clark. I guess that is the best way to go about this situation. Why didn't I think of that idea?
Old 08-20-2008, 03:09 PM   #5
ki11switch
Member#: 176422
well this is good to hear! anyone know what it would cost to get that done?
Old 08-20-2008, 03:52 PM   #6
Clark Turner
Member#: 178047
02 WRX STI Spec C
Just get a cam cap, take the head and cam caps with the cam to a machinist. They will check the clearances and bore out the new cam cap if needed. There is an access hole for the machine tool to do this on the head. THis is why the head cover gasket has that half moon section in it. THis wont be expensive.
Clark
Old 08-20-2008, 08:01 PM   #7
ki11switch
Member#: 176422
ok. anyone know where i can get a exhaust cam cap from for the first cylinder?
Old 08-20-2008, 08:35 PM   #8
Clark Turner
Member#: 178047
02 WRX STI Spec C
Call Subaru, Raw performance (Axis power racing) and IA performance in tucson AZ.
CLark
Cam caps maybe lost...what to do?! Jpizzzle Built Motor Discussion 11 08-23-2008 11:33 PM
need help- looking for STi cam cap BOLTS taossti Private 'Wanted' Classifieds 1 01-23-2008 02:13 PM
WTB: EJ25 Dual Cam left bank Cylinder Head or Cam Caps!!! illusionauto NWIC Private Classifieds 1 11-03-2006 08:48 PM
need help finding cam cap off 2.5dohc heads lotusdrift Mid Atlantic Impreza Club -- MAIC 6 02-03-2006 09:08 AM
Help! Lost rare JDM center caps! dmross Tire & Wheel 0 07-07-2004 10:03 AM
