Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 08-20-2008, 07:18 PM   #1
Member#: 112713
2014 BRZ, CBR Race
Default Need help with ECU plugs
Car is a 1998 impreza rs with 2006 WRX swap
I need to replace the ecu plugs/connectors on my harness because the pins on the inside were damaged by various shops and there is no way to repair them (trust me i've tried). So i am going to have to cut and splice in new ecu connectors.
my question is this, for this operation, does it matter if I use 07 WRX or 07/06 STI ecu connectors? I know 04/05 sti ecu connectors work as well, but im not sure if the wires are the same
salvator_rizzo is offline   Reply With Quote
Need help with ECU pins! fuzibuni Electrical & Lighting 0 05-27-2007 05:59 PM
Need help with ecu reflash timberwolfmedia Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2007 08:05 PM
I need help with spark plugs???? happy69 Built Motor Discussion 6 01-15-2007 09:56 PM
need help with ECU pinouts (RPM/speed) on STi 1QUICKMF Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-19-2004 09:02 PM
need help with ECU/fuse problem eric m. Service & Maintenance 0 01-03-2003 01:45 PM
