Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 08-20-2008, 11:41 PM   #1
live_2race
Member#: 82199
02 WRX and S2000
Default What my BCS lines are hooked up backwards?
What if my BCS is hooked up backwards?
The hose that should be hooked up to the acuator is hooked up to the intake instead and vise versa.
live_2race is offline   Reply With Quote
Old 08-21-2008, 12:03 AM   #2
live_2race
Member#: 82199
02 WRX and S2000
I switched the hoses out. Is the correct way to hook up the BCS on my 02 WRX. Anyone done this. This is what the pic above looks like.
Old 08-21-2008, 04:21 AM   #3
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
if you hook the lines up backwards your prob just going to run wastegate boost... Thats what happend to me
StupidFastWagon is offline   Reply With Quote
Old 08-21-2008, 08:51 AM   #4
silvialost
Member#: 91021
1997 impreza
red
Subaru changed the direction of the solenoid at some point.
I have seen some both ways from the factory.
If the car runs fine and you hit proper boost leave it alone.
silvialost is offline   Reply With Quote
Old 08-21-2008, 05:23 PM   #5
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
i tried it on a GM solenoid. It changed the boost curve from high boost then taper down to low boost then spike (and since it tries to pull the spike keeps going up )
scoobdude is offline   Reply With Quote
Old 08-22-2008, 03:36 AM   #6
live_2race
Member#: 82199
02 WRX and S2000
I don't have a boost gauge. I just have mine hooked up like you see in the example on the first post. Now mine is actually backwards on the second post. It is hard to tell but it actually is backwards.
OT Electronics Geek: What do I need to hook up speakers to my TV? rice h8r Off-Topic 21 05-22-2007 01:49 PM
battery got hooked up backwards, need help finding gremlins 5spd Alcyone Electrical & Lighting 5 02-10-2007 09:35 PM
Is there a way to test if my USB connections are hooked up? Stroke Off-Topic 9 04-14-2004 11:49 AM
What wire to use to hook up my Air fuel gauge? BrysImpreza Forester Forum 3 02-22-2004 01:49 PM
How can you tell if speakers are wired up backwards. Miracle Worker Car Audio, Video & Security 11 02-14-2002 12:04 AM
